Kernel-space ctypes.h support?
Thu Sep 13 16:11:17 UTC 2018
This makes sense to me. I tracked also the newlib C locale discussion
before, because it caused some problems for me in some baremetal
applications. I agree with having some light-weight options, and we
might even consider how to expose them later to avoid pulling in
newlib string functions to allow tinier footprints at the loss of
standard-compliance.
On Thu, Sep 13, 2018 at 11:35 AM, Sebastian Huber
> ----- Am 13. Sep 2018 um 14:07 schrieb joel joel at rtems.org:
>> On Thu, Sep 13, 2018, 3:28 AM Sebastian Huber <
>>> Hello,
>>> I test currently the tqm8xx BSP which worked fine until RTEMS 5. The
>>> problem is that this BSP uses strtoul() to get some system configuration
>>> parameters from the boot loader. The Newlib used by RTEMS 5 has now
>>> support for C locales in strtoul(). The C locale support needs an
>>> executing thread with a valid Newlib reentrancy structure. This is
>>> definitely not the case during bsp_start().
>> Why do we now longer have a global reentrancy structure to fall back on?
> I think having a global reentrancy as a fall back just for the lowest level system start without an idle thread is a bit of overkill.
> The heavy weight C local support which was recently introduced in Newlib is not really the right thing for the embedded systems I know.  There were several complaints about this on the Newlib mailing list as well.  The root cause for this is the C standard. So, basically the C standard strtoul() is unsuitable for embedded systems. The FreeBSD (sys/kern/strtoul.c) and Linux (lib/kstrtox.c) kernel have their own implementations.
>> If you disable newlib reentrancy via confdefs.h, what happens?
> This configuration option is not really great. It results in
> #if defined(RTEMS_NEWLIB)
>   struct _reent *__getreent(void)
>     #ifdef CONFIGURE_DISABLE_NEWLIB_REENTRANCY
>       return _GLOBAL_REENT;
>     #else
>       return _Thread_Get_executing()->libc_reent;
>     #endif
> #endif
> Since the configuration object is normally directly presented to the linker, we have a reference to _global_impure_ptr which is a heavy weight object. For low end targets, we need something better.
> devel mailing list
> devel at rtems.org
