[PATCH 10/25] Remove specialized CPPFLAGS from Makefile.am
Fri Sep 14 13:18:38 UTC 2018
 cpukit/dtc/libfdt/Makefile.am         | 1 -
 cpukit/libcrypt/Makefile.am           | 2 --
 cpukit/libcsupport/Makefile.am        | 2 --
 cpukit/libmd/Makefile.am              | 1 -
 cpukit/libmisc/Makefile.am            | 1 -
 cpukit/librpc/Makefile.am             | 2 --
 cpukit/libstdthreads/Makefile.am      | 1 -
 cpukit/mghttpd/Makefile.am            | 2 --
 cpukit/posix/Makefile.am              | 1 -
 cpukit/pppd/Makefile.am               | 1 -
 cpukit/rtems/Makefile.am              | 1 -
 cpukit/score/Makefile.am              | 1 -
 cpukit/score/cpu/arm/Makefile.am      | 1 -
 cpukit/score/cpu/bfin/Makefile.am     | 1 -
 cpukit/score/cpu/epiphany/Makefile.am | 2 --
 cpukit/score/cpu/i386/Makefile.am     | 1 -
 cpukit/score/cpu/lm32/Makefile.am     | 1 -
 cpukit/score/cpu/m32c/Makefile.am     | 1 -
 cpukit/score/cpu/m68k/Makefile.am     | 1 -
 cpukit/score/cpu/mips/Makefile.am     | 1 -
 cpukit/score/cpu/moxie/Makefile.am    | 1 -
 cpukit/score/cpu/nios2/Makefile.am    | 2 --
 cpukit/score/cpu/no_cpu/Makefile.am   | 1 -
 cpukit/score/cpu/or1k/Makefile.am     | 2 --
 cpukit/score/cpu/powerpc/Makefile.am  | 1 -
 cpukit/score/cpu/riscv/Makefile.am    | 1 -
 cpukit/score/cpu/sh/Makefile.am       | 1 -
 cpukit/score/cpu/v850/Makefile.am     | 1 -
 cpukit/score/cpu/x86_64/Makefile.am   | 1 -
 cpukit/telnetd/Makefile.am            | 1 -
 30 files changed, 37 deletions(-)
diff --git a/cpukit/dtc/libfdt/Makefile.am b/cpukit/dtc/libfdt/Makefile.am
index 0782303891..012923861d 100644
--- a/cpukit/dtc/libfdt/Makefile.am
+++ b/cpukit/dtc/libfdt/Makefile.am
@@ -2,7 +2,6 @@ include $(top_srcdir)/automake/compile.am
 noinst_LIBRARIES = libfdt.a
-libfdt_a_CPPFLAGS = $(AM_CPPFLAGS) -I$(srcdir)
 libfdt_a_SOURCES =
 libfdt_a_SOURCES += fdt_addresses.c
 libfdt_a_SOURCES += fdt.c
diff --git a/cpukit/libcrypt/Makefile.am b/cpukit/libcrypt/Makefile.am
index cb8dbe129a..5aecfe131f 100644
--- a/cpukit/libcrypt/Makefile.am
+++ b/cpukit/libcrypt/Makefile.am
@@ -2,8 +2,6 @@ include $(top_srcdir)/automake/compile.am
 noinst_LIBRARIES = libcrypt.a
-libcrypt_a_CPPFLAGS = $(AM_CPPFLAGS)
 libcrypt_a_SOURCES =
 libcrypt_a_SOURCES += crypt.c
 libcrypt_a_SOURCES += crypt-md5.c
diff --git a/cpukit/libcsupport/Makefile.am b/cpukit/libcsupport/Makefile.am
index e59dfd586b..00bbdfc9b9 100644
--- a/cpukit/libcsupport/Makefile.am
+++ b/cpukit/libcsupport/Makefile.am
@@ -2,8 +2,6 @@ include $(top_srcdir)/automake/multilib.am
 noinst_LIBRARIES = libcsupport.a libcalloc.a
-libcsupport_a_CPPFLAGS = $(AM_CPPFLAGS)
-libcalloc_a_CPPFLAGS = $(AM_CPPFLAGS)
 ## rtems
 ##  General stuff
diff --git a/cpukit/libmd/Makefile.am b/cpukit/libmd/Makefile.am
index b56aff7ca5..ce502f2265 100644
--- a/cpukit/libmd/Makefile.am
+++ b/cpukit/libmd/Makefile.am
@@ -9,7 +9,6 @@ if SHA
 libmd_a_SOURCES += sha256c.c
 libmd_a_SOURCES += sha512c.c
 endif
-libmd_a_CPPFLAGS = $(AM_CPPFLAGS)
 endif
 include $(top_srcdir)/automake/local.am
diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
index 2d6e36879f..9f4ac64f41 100644
--- a/cpukit/libmisc/Makefile.am
+++ b/cpukit/libmisc/Makefile.am
@@ -158,7 +158,6 @@ libuntar_a_SOURCES = untar/untar.c untar/untar_txz.c untar/untar_tgz.c \
 ## stringto
 noinst_LIBRARIES += libstringto.a
-libstringto_a_CPPFLAGS = $(AM_CPPFLAGS) -I$(srcdir)/stringto
 libstringto_a_SOURCES = stringto/stringtodouble.c stringto/stringtofloat.c \
     stringto/stringtolongdouble.c \
     stringto/stringtoint.c stringto/stringtolong.c stringto/stringtolonglong.c \
diff --git a/cpukit/librpc/Makefile.am b/cpukit/librpc/Makefile.am
index b0af51bf70..7cdcfd818b 100644
--- a/cpukit/librpc/Makefile.am
+++ b/cpukit/librpc/Makefile.am
@@ -6,7 +6,6 @@ if LIBNETWORKING
 man_MANS =
 noinst_LIBRARIES = libxdr.a
-libxdr_a_CPPFLAGS = $(AM_CPPFLAGS)
 libxdr_a_SOURCES = src/xdr/xdr.c src/xdr/xdr_array.c src/xdr/xdr_float.c \
     src/xdr/xdr_mem.c src/xdr/xdr_rec.c src/xdr/xdr_reference.c \
@@ -19,7 +18,6 @@ if LIBNETWORKING
 man_MANS += $(libxdr_mans)
 noinst_LIBRARIES += librpc.a
-librpc_a_CPPFLAGS = $(AM_CPPFLAGS)
 librpc_a_SOURCES = src/rpc/auth_none.c src/rpc/auth_unix.c \
     src/rpc/authunix_prot.c src/rpc/bindresvport.c src/rpc/clnt_generic.c \
diff --git a/cpukit/libstdthreads/Makefile.am b/cpukit/libstdthreads/Makefile.am
index 7d6192724d..1cb1bf0381 100644
--- a/cpukit/libstdthreads/Makefile.am
+++ b/cpukit/libstdthreads/Makefile.am
@@ -3,7 +3,6 @@ include $(top_srcdir)/automake/compile.am
 noinst_LIBRARIES = libstdthreads.a
 libstdthreads_a_CFLAGS = -std=c11
-libstdthreads_a_CPPFLAGS = $(AM_CPPFLAGS)
 libstdthreads_a_SOURCES =
 libstdthreads_a_SOURCES += call_once.c
diff --git a/cpukit/mghttpd/Makefile.am b/cpukit/mghttpd/Makefile.am
index 5058f8b85e..4f17609e29 100644
--- a/cpukit/mghttpd/Makefile.am
+++ b/cpukit/mghttpd/Makefile.am
@@ -8,8 +8,6 @@ $(PROJECT_LIB)/libmghttpd.a: libmghttpd.a
 	$(INSTALL_DATA) $< $(PROJECT_LIB)/libmghttpd.a
 TMPINSTALL_FILES = $(PROJECT_LIB)/libmghttpd.a
-libmghttpd_a_CPPFLAGS = $(AM_CPPFLAGS)
 libmghttpd_a_SOURCES = mongoose.c mongoose.h
 endif
 endif
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index 12d7c0def4..a59affc507 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
 noinst_LIBRARIES = libposix.a
-libposix_a_CPPFLAGS = $(AM_CPPFLAGS)
 libposix_a_SOURCES =
 # Some POSIX functions that are nice to always have
diff --git a/cpukit/pppd/Makefile.am b/cpukit/pppd/Makefile.am
index 5fdfb5ef30..799b2a9556 100644
--- a/cpukit/pppd/Makefile.am
+++ b/cpukit/pppd/Makefile.am
@@ -12,7 +12,6 @@ libpppd_a_SOURCES = auth.c ccp.c ccp.h chap.c chap.h chap_ms.c chap_ms.h \
     options.c upap.c upap.h utils.c sys-rtems.c \
     rtemsmain.c rtemspppd.c rtemspppd.h pppd.h patchlevel.h pathnames.h \
     rtemsdialer.h
-libpppd_a_CPPFLAGS = $(AM_CPPFLAGS)
 endif
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index 7af4ec7deb..2f00922829 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -2,7 +2,6 @@ include $(top_srcdir)/automake/multilib.am
 noinst_LIBRARIES = librtems.a
-librtems_a_CPPFLAGS = $(AM_CPPFLAGS)
 # include
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index cdd9740d41..b89aab89f6 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -16,7 +16,6 @@ endif
 noinst_LIBRARIES = libscore.a
 libscore_a_SOURCES =
-libscore_a_CPPFLAGS = $(AM_CPPFLAGS)
 # We only build multiprocessing related files if HAS_MP was defined
 if HAS_MP
diff --git a/cpukit/score/cpu/arm/Makefile.am b/cpukit/score/cpu/arm/Makefile.am
index 865a750477..b114d6bda3 100644
--- a/cpukit/score/cpu/arm/Makefile.am
+++ b/cpukit/score/cpu/arm/Makefile.am
@@ -1,6 +1,5 @@
 noinst_LIBRARIES = libscorecpu.a
-libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
 libscorecpu_a_SOURCES =
 libscorecpu_a_SOURCES += __aeabi_read_tp.c
 libscorecpu_a_SOURCES += __tls_get_addr.c
diff --git a/cpukit/score/cpu/bfin/Makefile.am b/cpukit/score/cpu/bfin/Makefile.am
index 7febda59b6..151b4beb15 100644
--- a/cpukit/score/cpu/bfin/Makefile.am
+++ b/cpukit/score/cpu/bfin/Makefile.am
@@ -5,7 +5,6 @@ libscorecpu_a_SOURCES = cpu.c cpu_asm.S
 libscorecpu_a_SOURCES += ../no_cpu/cpucounterfrequency.c
 libscorecpu_a_SOURCES += ../no_cpu/cpucounterread.c
 libscorecpu_a_SOURCES += bfin-exception-frame-print.c
 include $(srcdir)/headers.am
diff --git a/cpukit/score/cpu/epiphany/Makefile.am b/cpukit/score/cpu/epiphany/Makefile.am
index 0c75bcdcd5..a0ab8ec64a 100644
--- a/cpukit/score/cpu/epiphany/Makefile.am
+++ b/cpukit/score/cpu/epiphany/Makefile.am
@@ -11,8 +11,6 @@ libscorecpu_a_SOURCES += epiphany-context-initialize.c
 libscorecpu_a_SOURCES += setjmp.S
 all-local: $(PREINSTALL_FILES)
diff --git a/cpukit/score/cpu/i386/Makefile.am b/cpukit/score/cpu/i386/Makefile.am
index b03d8593c4..e61fc78924 100644
--- a/cpukit/score/cpu/i386/Makefile.am
+++ b/cpukit/score/cpu/i386/Makefile.am
@@ -4,7 +4,6 @@ noinst_LIBRARIES = libscorecpu.a
diff --git a/cpukit/score/cpu/lm32/Makefile.am b/cpukit/score/cpu/lm32/Makefile.am
index 795a6be283..b867dc0083 100644
--- a/cpukit/score/cpu/lm32/Makefile.am
+++ b/cpukit/score/cpu/lm32/Makefile.am
@@ -5,7 +5,6 @@ libscorecpu_a_SOURCES = cpu.c cpu_asm.S irq.c
 libscorecpu_a_SOURCES += lm32-exception-frame-print.c
diff --git a/cpukit/score/cpu/m32c/Makefile.am b/cpukit/score/cpu/m32c/Makefile.am
index 6695d35c77..596585a1ea 100644
--- a/cpukit/score/cpu/m32c/Makefile.am
+++ b/cpukit/score/cpu/m32c/Makefile.am
@@ -6,7 +6,6 @@ libscorecpu_a_SOURCES = cpu.c cpu_asm.c context_switch.S context_init.c \
 libscorecpu_a_SOURCES += m32c-exception-frame-print.c
diff --git a/cpukit/score/cpu/m68k/Makefile.am b/cpukit/score/cpu/m68k/Makefile.am
index e02b4ab600..dea4d548b8 100644
--- a/cpukit/score/cpu/m68k/Makefile.am
+++ b/cpukit/score/cpu/m68k/Makefile.am
@@ -1,7 +1,6 @@
diff --git a/cpukit/score/cpu/mips/Makefile.am b/cpukit/score/cpu/mips/Makefile.am
--- a/cpukit/score/cpu/mips/Makefile.am
+++ b/cpukit/score/cpu/mips/Makefile.am
diff --git a/cpukit/score/cpu/moxie/Makefile.am b/cpukit/score/cpu/moxie/Makefile.am
index d5e8952693..989028cfef 100644
--- a/cpukit/score/cpu/moxie/Makefile.am
+++ b/cpukit/score/cpu/moxie/Makefile.am
@@ -8,7 +8,6 @@ noinst_LIBRARIES = libscorecpu.a
 libscorecpu_a_SOURCES = cpu.c moxie-exception-frame-print.c cpu_asm.S
diff --git a/cpukit/score/cpu/nios2/Makefile.am b/cpukit/score/cpu/nios2/Makefile.am
index a0ecab3345..e94afaf179 100644
--- a/cpukit/score/cpu/nios2/Makefile.am
+++ b/cpukit/score/cpu/nios2/Makefile.am
@@ -30,8 +30,6 @@ libscorecpu_a_SOURCES += nios2-mpu-disable-protected.c
 libscorecpu_a_SOURCES += nios2-mpu-reset.c
 libscorecpu_a_SOURCES += nios2-thread-dispatch-disabled.c
diff --git a/cpukit/score/cpu/no_cpu/Makefile.am b/cpukit/score/cpu/no_cpu/Makefile.am
index 0d89f5af2b..dd493e7b8f 100644
--- a/cpukit/score/cpu/no_cpu/Makefile.am
+++ b/cpukit/score/cpu/no_cpu/Makefile.am
 libscorecpu_a_SOURCES += cpucounterfrequency.c
 libscorecpu_a_SOURCES += cpucounterread.c
diff --git a/cpukit/score/cpu/or1k/Makefile.am b/cpukit/score/cpu/or1k/Makefile.am
index 732f7c3d69..9d7690d0e3 100644
--- a/cpukit/score/cpu/or1k/Makefile.am
+++ b/cpukit/score/cpu/or1k/Makefile.am
@@ -15,8 +15,6 @@ libscorecpu_a_SOURCES += or1k-exception-default.c
 libscorecpu_a_SOURCES += or1k-exception-frame-print.c
 libscorecpu_a_SOURCES += or1k-exception-handler-low.S
diff --git a/cpukit/score/cpu/powerpc/Makefile.am b/cpukit/score/cpu/powerpc/Makefile.am
index 05ab2f480d..8a115b69ed 100644
--- a/cpukit/score/cpu/powerpc/Makefile.am
+++ b/cpukit/score/cpu/powerpc/Makefile.am
@@ -6,7 +6,6 @@ libscorecpu_a_SOURCES += ppc-context-volatile-clobber.S
 libscorecpu_a_SOURCES += ppc-context-validate.S
 libscorecpu_a_SOURCES += ppc-isr-disable-mask.S
 libscorecpu_a_SOURCES += ppc-isr-vector-install.c
diff --git a/cpukit/score/cpu/riscv/Makefile.am b/cpukit/score/cpu/riscv/Makefile.am
index bf1c43f01d..3aa992d135 100644
--- a/cpukit/score/cpu/riscv/Makefile.am
+++ b/cpukit/score/cpu/riscv/Makefile.am
@@ -1,6 +1,5 @@
 libscorecpu_a_SOURCES += riscv-exception-handler.S
 libscorecpu_a_SOURCES += riscv-exception-frame-print.c
diff --git a/cpukit/score/cpu/sh/Makefile.am b/cpukit/score/cpu/sh/Makefile.am
index 37188443ff..7f732ede9a 100644
--- a/cpukit/score/cpu/sh/Makefile.am
+++ b/cpukit/score/cpu/sh/Makefile.am
@@ -5,7 +5,6 @@ libscorecpu_a_SOURCES = cpu.c context.c
 libscorecpu_a_SOURCES += sh-exception-frame-print.c
diff --git a/cpukit/score/cpu/v850/Makefile.am b/cpukit/score/cpu/v850/Makefile.am
index 8db039c9f5..f93ecb7866 100644
--- a/cpukit/score/cpu/v850/Makefile.am
+++ b/cpukit/score/cpu/v850/Makefile.am
@@ -6,7 +6,6 @@ libscorecpu_a_SOURCES += cpu_asm.S
 libscorecpu_a_SOURCES += v850-exception-frame-print.c
diff --git a/cpukit/score/cpu/x86_64/Makefile.am b/cpukit/score/cpu/x86_64/Makefile.am
index db4bd15cd5..19afe5c031 100644
--- a/cpukit/score/cpu/x86_64/Makefile.am
+++ b/cpukit/score/cpu/x86_64/Makefile.am
@@ -6,7 +6,6 @@ libscorecpu_a_SOURCES += ../no_cpu/cpucounterfrequency.c
 libscorecpu_a_SOURCES += x86_64-context-initialize.c
 libscorecpu_a_SOURCES += x86_64-context-switch.S
diff --git a/cpukit/telnetd/Makefile.am b/cpukit/telnetd/Makefile.am
index 7051b368c3..7d9e543e67 100644
--- a/cpukit/telnetd/Makefile.am
+++ b/cpukit/telnetd/Makefile.am
@@ -8,7 +8,6 @@ $(PROJECT_LIB)/libtelnetd.a: libtelnetd.a
 TMPINSTALL_FILES = $(PROJECT_LIB)/libtelnetd.a
 libtelnetd_a_SOURCES = check_passwd.c des.c pty.c telnetd.c telnetd-init.c
-libtelnetd_a_CPPFLAGS = $(AM_CPPFLAGS)
 endif
2.13.7
