[PATCH 18/25] Merge libdebugger/Make*.am into cpukit/Makefile.am
Fri Sep 14 13:18:46 UTC 2018
 cpukit/Makefile.am             | 21 ++++++++++++++++++++-
 cpukit/configure.ac            |  1 -
 cpukit/libdebugger/Makefile.am | 22 ----------------------
 3 files changed, 20 insertions(+), 24 deletions(-)
 delete mode 100644 cpukit/libdebugger/Makefile.am
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 14f8df7653..32a0758a6c 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -346,7 +346,6 @@ _SUBDIRS += libmd
 _SUBDIRS += libgnat
 _SUBDIRS += libdl
 _SUBDIRS += libstdthreads
-_SUBDIRS += libdebugger
 _SUBDIRS += wrapup
 # other libraries
@@ -365,6 +364,26 @@ libftpd_a_SOURCES =
 libftpd_a_SOURCES += ftpd/ftpd.c
 libftpd_a_SOURCES += ftpd/ftpd-init.c
+if LIBDEBUGGER
+project_lib_LIBRARIES += libdebugger.a
+$(PROJECT_LIB)/libdebugger.a: libdebugger.a
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/libdebugger.a
+TMPINSTALL_FILES += $(PROJECT_LIB)/libdebugger.a
+libdebugger_a_SOURCES =
+libdebugger_a_SOURCES += rtems-debugger-block.c
+libdebugger_a_SOURCES += rtems-debugger-cmd.c
+libdebugger_a_SOURCES += rtems-debugger-remote.c
+libdebugger_a_SOURCES += rtems-debugger-remote-tcp.c
+libdebugger_a_SOURCES += rtems-debugger- at RTEMS_CPU@.c
+libdebugger_a_SOURCES += rtems-debugger-server.c
+libdebugger_a_SOURCES += rtems-debugger-target.c
+libdebugger_a_SOURCES += rtems-debugger-threads.c
+endif
 include $(top_srcdir)/automake/subdirs.am
 include $(top_srcdir)/automake/local.am
 include $(srcdir)/headers.am
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 5c1efa0860..6b7c719bdd 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -509,7 +509,6 @@ libi2c/Makefile
 libmd/Makefile
 libdl/Makefile
 libstdthreads/Makefile
-libdebugger/Makefile
 zlib/Makefile
 telnetd/Makefile
 pppd/Makefile
diff --git a/cpukit/libdebugger/Makefile.am b/cpukit/libdebugger/Makefile.am
deleted file mode 100644
index 6ff35d197f..0000000000
--- a/cpukit/libdebugger/Makefile.am
+++ /dev/null
@@ -1,22 +0,0 @@
-include $(top_srcdir)/automake/compile.am
-if LIBDEBUGGER
-project_lib_LIBRARIES = libdebugger.a
-libdebugger_a_SOURCES = \
-  rtems-debugger-block.c \
-  rtems-debugger-cmd.c \
-  rtems-debugger-remote.c \
-  rtems-debugger-server.c \
-  rtems-debugger-target.c \
-  rtems-debugger-remote-tcp.c \
-  rtems-debugger-threads.c \
-  rtems-debugger- at RTEMS_CPU@.c
-$(PROJECT_LIB)/libdebugger.a: libdebugger.a
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/libdebugger.a
-TMPINSTALL_FILES = $(PROJECT_LIB)/libdebugger.a
-endif
-include $(top_srcdir)/automake/local.am
2.13.7
