Trouble with rtems-libbsd
Mon Sep 17 04:59:43 UTC 2018
On 14/09/2018 16:08, Jeff Mayes wrote:
> [1329/2017] Compiling freebsd/sys/arm/at91/at91_mci.c
> In file included from
> /home/tester/rtems/rtems-libbsd/freebsd/sys/sys/systm.h:42:0,
> from ../../freebsd/sys/arm/at91/at91_mci.c:36:
> /home/tester/rtems/rtems-libbsd/freebsd/sys/powerpc/include/machine/cpufunc.h:166:1:
> error: redefinition of 'eieio'
> eieio(void)
> /home/tester/rtems/kernel/ppc/powerpc-rtems5/mcp750/lib/include/bsp.h:14:0,
> from
> /home/tester/rtems/kernel/ppc/powerpc-rtems5/mcp750/lib/include/bsp/fdt.h:18,
> from
> /home/tester/rtems/rtems-libbsd/rtemsbsd/include/rtems/bsd/local/opt_platform.h:1,
> from ../../freebsd/sys/arm/at91/at91_mci.c:30:
> /home/tester/rtems/kernel/ppc/powerpc-rtems5/mcp750/lib/include/libcpu/io.h:53:20:
> note: previous definition of 'eieio' was here
> static inline void eieio(void)
The problem is just as the compiler says. You have two conflicting
definitions of the eieio() function, one in the BSP and one in libbsd.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
