[PATCH 2/3] config: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE
Mon Sep 17 10:04:50 UTC 2018
RTEMS had the configuration option CONFIGURE_HAS_OWN_MOUNT_TABLE since
1999.  This configuration option was broken since RTEMS 4.11.  Remove
this broken configuration option.
Update #3488.
 cpukit/include/rtems/confdefs.h | 7 ++++---
 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 1fd3a6c5ae..661efac7f0 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -504,10 +504,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
       #endif
       CONFIGURE_FILESYSTEM_NULL
-  #endif
-  #if !defined(CONFIGURE_HAS_OWN_MOUNT_TABLE) && \
-    !defined(CONFIGURE_APPLICATION_DISABLE_FILESYSTEM)
     #if defined(CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM)
       static devFS_node devFS_root_filesystem_nodes [CONFIGURE_MAXIMUM_DEVICES];
       static const devFS_data devFS_root_filesystem_data = {
@@ -3443,6 +3440,10 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #warning "The CONFIGURE_HAS_OWN_FILESYSTEM_TABLE configuration option is obsolete since RTEMS 5.1"
 #endif
+#ifdef CONFIGURE_HAS_OWN_MOUNT_TABLE
+  #warning "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
 #ifdef CONFIGURE_NUMBER_OF_TERMIOS_PORTS
   #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is obsolete since RTEMS 5.1"
 #endif
2.13.7
