[PATCH 1/2] c-user: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE
Sebastian Huber
Mon Sep 17 10:05:04 UTC 2018
Close #3488.
c-user/configuring_a_system.rst | 40 +++++++---------------------------------
1 file changed, 7 insertions(+), 33 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index f35d2bb..7697694 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -2112,39 +2112,6 @@ File System Configuration Parameters
This section defines File System related configuration parameters.
-.. index:: CONFIGURE_HAS_OWN_MOUNT_TABLE
-.. _CONFIGURE_HAS_OWN_MOUNT_TABLE:
-CONFIGURE_HAS_OWN_MOUNT_TABLE
-CONSTANT:
- ``CONFIGURE_HAS_OWN_MOUNT_TABLE``
-DATA TYPE:
- Undefined or an array of type ``rtems_filesystem_mount_table_t``.
-RANGE:
-DEFAULT VALUE:
- This is not defined by default.
-DESCRIPTION:
- This configuration parameter is defined when the application provides their
- own filesystem mount table. The mount table is an array of
- ``rtems_filesystem_mount_table_t`` entries pointed to by the global
- variable ``rtems_filesystem_mount_table``. The number of entries in this
- table is in an integer variable named ``rtems_filesystem_mount_table_t``.
-.. COMMENT: XXX - is the variable name for the count right?
-NOTES:
- None.
-.. COMMENT: XXX - Please provide an example
.. index:: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
.. _CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM:
@@ -4891,6 +4858,13 @@ CONFIGURE_HAS_OWN_BDBUF_TABLE
This configuration option was introduced in RTEMS 4.7.0 and is obsolete since
RTEMS 4.10.0.
+.. index:: CONFIGURE_HAS_OWN_MOUNT_TABLE
+CONFIGURE_HAS_OWN_MOUNT_TABLE
+This configuration option is obsolete since RTEMS 5.1.
.. index:: CONFIGURE_NUMBER_OF_TERMIOS_PORTS
2.13.7
