[PATCH 2/2] Remove CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
Mon Sep 17 10:05:05 UTC 2018
Close #3489.
Close #3490.
 c-user/configuring_a_system.rst | 33 +++++++--------------------------
 1 file changed, 7 insertions(+), 26 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 7697694..3e44239 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -2045,32 +2045,6 @@ NOTES:
     Typically the memory allocation will be too low when an application does
     not account for all message queue buffers or task stacks.
-.. index:: CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
-.. _CONFIGURE_HAS_OWN_CONFIGURATION_TABLE:
-CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
-CONSTANT:
-    ``CONFIGURE_HAS_OWN_CONFIGURATION_TABLE``
-DATA TYPE:
-    Boolean feature macro.
-RANGE:
-    Defined or undefined.
-DEFAULT VALUE:
-    This is not defined by default.
-DESCRIPTION:
-    This configuration parameter should only be defined if the application is
-    providing their own complete set of configuration tables.
-NOTES:
-    None.
 C Library Support Configuration
@@ -4850,6 +4824,13 @@ CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
 This configuration option was introduced in RTEMS 4.9.0 and is obsolete since
 RTEMS 5.1.
+.. index:: CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
+CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
+This configuration option is obsolete since RTEMS 5.1.
 .. index:: CONFIGURE_HAS_OWN_BDBUF_TABLE
2.13.7
