Four SMP tests fails after recent commit
Wed Sep 19 10:00:58 UTC 2018
Hello Daniel,
On 19/09/2018 11:32, Daniel Hellstrom wrote:
> Hi,
> When I rebased earlier this week four SMP test now fails (smp03,
> smppsxaffinity01, smpschedaffinity04, smpschedaffinity05). After some
> testing it turns out that after commit
> cfc4231d8fe1056fa501508a929c8ccaa1dd11be ("score: Add flexible per-CPU
> data") the tests fails when
> creating tasks with rtems_task_create() due to Task stack allocation
> fails.
>  0)
> _Heap_Allocate_aligned_with_boundary(alloc_size=4096,alignment=0,boundary=0)
>  1) stack_addr = (*stack_allocate_hook)( the_stack_size );
>  2) _Thread_Stack_Allocate( the_thread, stack_size );
>  3) _Thread_Initialize()
>  4) rtems_task_create()
these tests didn't fail on ARM and PowerPC. I guess this is due to an
overestimate of the workspace size. Could you please check if the
following commit fixed the issue on SPARC:
https://git.rtems.org/rtems/commit/?id=776464aad46cd317b9707870acc5f6be5531e15a
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
