Four SMP tests fails after recent commit
Daniel Hellstrom daniel at gaisler.com
Wed Sep 19 10:23:50 UTC 2018
Thanks for looking into it Sebastian. I will try it out now.
On 2018-09-19 12:00, Sebastian Huber wrote:
> Hello Daniel,
> On 19/09/2018 11:32, Daniel Hellstrom wrote:
>> Hi,
>> When I rebased earlier this week four SMP test now fails (smp03,
>> smppsxaffinity01, smpschedaffinity04, smpschedaffinity05). After some
>> testing it turns out that after commit
>> cfc4231d8fe1056fa501508a929c8ccaa1dd11be ("score: Add flexible
>> per-CPU data") the tests fails when
>> creating tasks with rtems_task_create() due to Task stack allocation
>> fails.
>>  0)
>> _Heap_Allocate_aligned_with_boundary(alloc_size=4096,alignment=0,boundary=0)
>>  1) stack_addr = (*stack_allocate_hook)( the_stack_size );
>>  2) _Thread_Stack_Allocate( the_thread, stack_size );
>>  3) _Thread_Initialize()
>>  4) rtems_task_create()
> these tests didn't fail on ARM and PowerPC. I guess this is due to an
> overestimate of the workspace size. Could you please check if the
> following commit fixed the issue on SPARC:
> https://git.rtems.org/rtems/commit/?id=776464aad46cd317b9707870acc5f6be5531e15a
