[PATCH] leon3, ckinit: avoid unsued code warnings when drvmgr is enabled
Daniel Hellstrom daniel at gaisler.com
Wed Sep 19 14:13:28 UTC 2018
 bsps/sparc/shared/btimer/tlib_ckinit.c | 9 ++++++---
 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/bsps/sparc/shared/btimer/tlib_ckinit.c b/bsps/sparc/shared/btimer/tlib_ckinit.c
index 3e2feb1..6643335 100644
--- a/bsps/sparc/shared/btimer/tlib_ckinit.c
+++ b/bsps/sparc/shared/btimer/tlib_ckinit.c
@@ -67,14 +67,17 @@ struct ops {
  * clock (tick) timer in SMP configuration.
+#ifndef RTEMS_SMP
 /* "simple timecounter" interface. Only for non-SMP. */
 static const struct ops ops_simple;
+#else
 /* Hardware support up-counter using LEON3 %asr23. */
 static const struct ops ops_timetag;
 /* Timestamp counter available in some IRQ(A)MP instantiations. */
 static const struct ops ops_irqamp;
 /* Separate GPTIMER subtimer as timecounter */
 static const struct ops ops_subtimer;
+#endif
 struct clock_priv {
   const struct ops *ops;
@@ -174,6 +177,7 @@ static rtems_device_driver tlib_clock_install_isr(rtems_isr *isr)
   return RTEMS_SUCCESSFUL;
+#ifndef RTEMS_SMP
 /** Simple counter **/
 static uint32_t simple_tlib_tc_get(rtems_timecounter_simple *tc)
@@ -257,6 +261,8 @@ static const struct ops ops_simple = {
   .shutdown_hardware  = NULL,
+#else
 /** Subtimer as counter **/
 static uint32_t subtimer_get_timecount(struct timecounter *tc)
@@ -316,7 +322,6 @@ static const struct ops ops_subtimer = {
   .shutdown_hardware  = subtimer_shutdown_hardware,
-#if defined(LEON3)
 /** DSU timetag as counter **/
 static uint32_t timetag_get_timecount(struct timecounter *tc)
@@ -346,9 +351,7 @@ static const struct ops ops_timetag = {
   .timecounter_tick   = timetag_timecounter_tick,
-#endif
-#if defined(LEON3)
 /** IRQ(A)MP timestamp as counter **/
 static uint32_t irqamp_get_timecount(struct timecounter *tc)
2.7.4
