GR740-SMP BSP test results (gcc-7.2)
Daniel Hellstrom daniel at gaisler.com
Thu Sep 20 06:59:23 UTC 2018
Hello Sebastian,
On 2018-09-20 07:32, Sebastian Huber wrote:
> Hello Daniel,
> thanks for your status report. The RSB uses currently GCC 7.3.0
> without patches and the Newlib commit
> d13c84eb07e35984bf7a974cd786a6cdac29e6b9.
Thanks for the information, our toolchain was built using
916ef5fb8865f72d0f5ad3f4f479adac44ea94b1. I will update newlib at least
going forward.
> On 19/09/2018 14:46, Daniel Hellstrom wrote:
>> Hi,
>> I just wanted to share the current test status for the GR740 I have
>> today, using the todays master with some additional test fixes which
>> I plan to submit shortly. The test have been run both on TSIM and
>> hardware.
>> Current test results for the RTEMS test-suite with GCC-7.2 toolchain
>> for the GR740 quad-core LEON4 BSP in SMP driver manager configuration:
>>   # RTEMS TESTSUITE FAILURE SUMMARY
>>   # Result Test ExecRes ConsoleRes ExitCode1 ExitCode2
>>   # FAIL: minimum OK N/A 0 5
> Ok, known issue, the test has no output.
>>   # FAIL: spcpucounter01 OK FAIL 5 0
> This was a bug. It should be fixed with this commit:
> https://git.rtems.org/rtems/commit/?id=b3cf79b9c472ed8c219f8c9a9d8fb571671f3815
Aah, I missed this, even looking at that line of code I could not see
the typo. This fix will remove a warning too.
>>   # FAIL: spfatal07 FAIL N/A N/A N/A
>>   # FAIL: spinternalerror01 OK N/A -559038737 1611526157
> This is a known issue. Test exit before the device enumeration.
>>   # FAIL: sptimecounter01 OK N/A 5 0
>>   # SUMMARY
>>   #  Tests failing:    5
>>   #  Tests successful: 624
>> spfatal07 - problem with the test itself.
>> CONFIGURE_INTERRUPT_STACK_SIZE is too small, the boot process fails
>> before reaching the check. This is a new behavior since interrupt
>> stack is also used by the CPU for initialization/boot process.
> Ok, thanks for the pointer. I changed the interrupt/initialization
> stack machinery recently. I think that this internal error is
> superfluous now or needs to be adjusted. This ticket is related to
> this topic:
> https://devel.rtems.org/ticket/3480
Thanks for your comments, it is helpful.
