GR740-SMP BSP test results (gcc-7.2)
Fri Sep 21 07:23:36 UTC 2018
On 20/09/2018 08:59, Daniel Hellstrom wrote:
> Hello Sebastian,
> On 2018-09-20 07:32, Sebastian Huber wrote:
>> Hello Daniel,
>> thanks for your status report. The RSB uses currently GCC 7.3.0
>> without patches and the Newlib commit
>> d13c84eb07e35984bf7a974cd786a6cdac29e6b9.
> Thanks for the information, our toolchain was built using
> 916ef5fb8865f72d0f5ad3f4f479adac44ea94b1. I will update newlib at
> least going forward.
>> On 19/09/2018 14:46, Daniel Hellstrom wrote:
>> spfatal07 - problem with the test itself.
>> CONFIGURE_INTERRUPT_STACK_SIZE is too small, the boot process fails
>> before reaching the check. This is a new behavior since interrupt
>> stack is also used by the CPU for initialization/boot process.
>> Ok, thanks for the pointer. I changed the interrupt/initialization
>> stack machinery recently. I think that this internal error is
>> superfluous now or needs to be adjusted. This ticket is related to
>> this topic:
>> https://devel.rtems.org/ticket/3480
> Thanks for your comments, it is helpful.
I removed this fatal error and changed the stack checker to check the
interrupt stack better.
I did a test run on a N2X of RTEMS version
4221d932b43094f3aaf4a8dca1aa6bd4db13df4e. There are no test failures
(686 tests produced the begin/end of test message).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
