GR740-SMP BSP test results (gcc-7.2)
Fri Sep 21 09:01:46 UTC 2018
On 21/09/2018 10:57, Chris Johns wrote:
>> On 21 Sep 2018, at 5:23 pm, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> I did a test run on a N2X of RTEMS version 4221d932b43094f3aaf4a8dca1aa6bd4db13df4e. There are no test failures (686 tests produced the begin/end of test message).
> Nice.
> Could the rtems-test results please be posted to builds at rtems.org so the BSP’s tier 1 can be recorded?
I didn't run the tests with rtems-test, but I work on a support for this
target. We have currently an undergraduate trainee who wrote a simple
HTTPS server in Python which receives an ELF file and executes it on a
target. I plan to use this via an SSH tunnel to a remote server which
can run tests on this board and locally use rtems-test to drive it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
