[PATCH 11/25] Merge sapi/Makefile.am into cpukit/Makefile.am
Fri Sep 21 13:19:27 UTC 2018
On 17/09/2018 07:33, Chris Johns wrote:
> On 17/09/2018 15:13, Sebastian Huber wrote:
>> On 17/09/2018 05:23, Chris Johns wrote:
>>> On 17/09/2018 08:46, Joel Sherrill wrote:
>>>> On Sat, Sep 15, 2018 at 12:58 AM Chris Johns <chrisj at rtems.org
>>>> <mailto:chrisj at rtems.org>> wrote:
>>>>       On 14/9/18 11:18 pm, Sebastian Huber wrote:
>>>>       >  cpukit/Makefile.am                    | 79
>>>>       >  cpukit/configure.ac<http://configure.ac>                    |  1 -
>>>>       >  cpukit/sapi/Makefile.am               | 63 ----------------------------
>>>>       >  cpukit/{sapi => }/vc-key.sh           |  0
>>>>       >  cpukit/{sapi => }/version-vc-key.h.in<http://version-vc-key.h.in>  |  0
>>>>       >  cpukit/wrapup/Makefile.am             |  2 +-
>>>>       >  6 files changed, 79 insertions(+), 66 deletions(-)
>>>>       >  delete mode 100644 cpukit/sapi/Makefile.am
>>>>       >  rename cpukit/{sapi => }/vc-key.sh (100%)
>>>>       >  rename cpukit/{sapi => }/version-vc-key.h.in
>>>>       (100%)
>>>>       Could you please explain why you are performing this merge?
>>>>       I am not against such a change however I would like to understand what
>>>> the plan
>>>>       is and where this is going?
>>>>       The coverage tool and covoar work is using the internally built
>>>> libraries to
>>>>       group functionality, for example score. If the cpukit build is completely
>>>>       fattened I think that tool may need to change to manage the grouping.
>>>> The coverage analysis has always assumed that the directories and the
>>>> sub-libraries created imply areas of functionality that a developer would
>>>> like to know the coverage of independently of other areas. For example,
>>>> should the score, fatfs, and shell be lumped into one coverage report
>>>> or would it be IMO preferable to generate them on each area?
>>> This makes sense. Any user or organisation wanting coverage information will
>>> only be interested in specific areas and not everything that could be run. We
>>> need to provide what we see as the standard groupings and I suspect we will need
>>> to allow that data to be specialised where a more accurate and controlled
>>> profile is needed.
>>>> We need to recognize that some code analysis needs to know the logical
>>>> grouping of code. How do you propose this happen when the information
>>>> implicit in the sub-libraries is lost?
>>> We have a growing set of data with RTEMS. Some of the files under this tree in
>>> the tester are an example:
>>> https://git.rtems.org/rtems-tools/tree/tester/rtems
>>> I see the grouping of source as another set of data we need to maintain. The
>>> current use of libraries is implementation specific ...
>>> https://git.rtems.org/rtems-tools/tree/tester/rtems/testing/coverage/symbol-sets.ini
>>> ... and we would need to find a workable solution for this patch to be merged.
>>> I am starting to wonder if this data is held in the RTEMS repo and it gets
>>> installed?
>> I was not aware that this set of temporary build system artefacts was used
>> outside the build tree for some other purposes.
> That is understandable.
>> I think this grouping of
>> coverage analysis should be done independent of build system internals.
> Agreed, it was a means to an end and dates back to the very first
> implementations of coverage. I updated covoar recently to use the ELF symbols
> directly ...
> https://git.rtems.org/rtems-tools/tree/tester/covoar/DesiredSymbols.cc
> That again was a small step.
>> In the
>> DWARF debug information of an object file you have the DW_TAG_compile_unit tag
> https://git.rtems.org/rtems-tools/tree/rtemstoolkit/rld-dwarf.h#n605
>> and DW_AT_name attribute:
> https://git.rtems.org/rtems-tools/tree/rtemstoolkit/rld-dwarf.h#n627
>> A path pattern could be used for the grouping, e.g. in
>> replace the [libraries] with regular expressions for path patterns.
> Yeap, I suspect this is the most sensible way forward. It is agreeing on a
> format for this data and then a framework to access it. We are seeing repeated
> patterns with this type of data. I can see this grouping being used beyond
> coverage. Take the BSP data, I think being able to read and generate XML or JSON
> data from the INI files would be useful, for example as an input to a buildbot
> instance or something that parses the test result emails and determines the tier
> ranks.
> I should mention I think the current approach of archives for grouping is an
> approximation because inlines are in the archives and this needs to be managed
> when working at the DWARF level and CUs. You end up with questions such as "Is
> an score inline in a file system call part of the file system coverage map or
> the score?".
>> This relies
>> on the source tree layout which should be more or less static after our header
>> file and BSP movement.
> This is the reason I raised the idea of moving this data to rtems.git. It could
> be installed into the `$prefix/share/rtems/..` when RTEMS is installed.
How do we want to proceed with this? Should I fix the coverage tool to
use the compilation unit source path for the grouping? I don't know how
the coverage tool works so this would require a considerable time for me
to get started.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
