[PATCH 11/25] Merge sapi/Makefile.am into cpukit/Makefile.am
Mon Sep 24 07:55:38 UTC 2018
On 24/09/2018 08:35, Chris Johns wrote:
> On 24/09/2018 15:44, Sebastian Huber wrote:
>> A quick and dirty fix could look like this:
>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>> b/tester/rtems/testing/coverage/symbol-sets.ini
>> index 2685ef4..d9afe85 100644
>> --- a/tester/rtems/testing/coverage/symbol-sets.ini
>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>> @@ -29,9 +29,10 @@
>>   [symbol-sets]
>> -sets =
>> score,rtems,sapi,libdl,posix,libirfs,libdosfs,libdevfs,libimfs,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
>> +sets =
>> cpukit,score,rtems,sapi,libdl,posix,libirfs,libdosfs,libdevfs,libimfs,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
>>   [libraries]
>> +cpukit        = @BUILD-TARGET@/c/@BSP@/cpukit/libcpukit.a
>>   score         = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>   rtems         = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>   sapi          = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/libsapi.a
>> Then build up a regular expression using all libraries other than libcpukit.a,
>> e.g. '(cpukit/score)|(cpukit/rtems)|(cpukit/sapi)'. Then use this regular
>> expression in cache.load_symbols (symbols, regex, true) to filter the symbols.
> We need the complete set of symbols for a "component" so we can determine the
> level of coverage. I am not sure we can have a symbols in more than one
> component, ie cpukit and cpukit/score?
The approach above would keep the cover tool compatible with the
existing build tree and the new build tree with a reduced library set.
> Is this grouping on source path or still via libraries? Using internal libraries
> seems fragile to me. If we completely flatten the build to create a single
> library, which could happen, we would need to use source paths.
The grouping would be based on the source path.
>> We would have to go from the symbol to the ELF file to the DWARF info of the
>> compilation unit.
> All info should be directly via the ELF and DWARF format. I do not know if we
> need to reference the ELF symbol table or we can just use the DWARF CU data. The
> use of objdump should be avoided.
I only briefly look into this, but you have to go from the
rld::symbols::symbol to the DWARF info somehow if DesiredSymbols.cc:95
is the right spot to add this stuff.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
