[PATCH 2/3] README.waf: Update waf URL and sis->erc32
Mon Sep 24 23:00:55 UTC 2018
 README.waf | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/README.waf b/README.waf
index dd339f4..bf379ae 100644
--- a/README.waf
+++ b/README.waf
@@ -3,7 +3,7 @@ RTEMS Waf
 You can find the Waf project here:
- http://code.google.com/p/waf/
+ https://waf.io
 Simple instructions on How to set up Waf is here:
@@ -28,14 +28,14 @@ Steps
 5. Configure with your specific settings. In this case the path to the tools
    and RTEMS and provided on the command line and so do not need to be in your
-   path or environment [1] and we limit the build to 'sparc/sis' BSP:
+   path or environment [1] and we limit the build to 'sparc/erc32' BSP:
     $ waf configure --rtems=$HOME/Development/rtems/build/4.11 \
                     --rtems-tools=$HOME/Development/rtems/4.11 \
-                    --rtems-bsps=sparc/sis
+                    --rtems-bsps=sparc/erc32
    You can use '--rtems-archs=sparc,i386' or
-   '--rtems-bsps=sparc/sis,i386/pc586' to build for more than BSP at a time.
+   '--rtems-bsps=sparc/erc32,i386/pc586' to build for more than BSP at a time.
 6. Build:
1.8.3.1
