[PATCH 1/6] pppd: Remove unused get_pty() function
Sebastian Huber
Wed Sep 26 08:30:43 UTC 2018
Update #3526.
cpukit/pppd/pppd.h | 1 -
cpukit/pppd/sys-rtems.c | 14 --------------
2 files changed, 15 deletions(-)
diff --git a/cpukit/pppd/pppd.h b/cpukit/pppd/pppd.h
index 98c49e8f20..d1408a16a6 100644
--- a/cpukit/pppd/pppd.h
+++ b/cpukit/pppd/pppd.h
@@ -365,7 +365,6 @@ void sys_cleanup(void); /* Restore system state before exiting */
int sys_check_options(void); /* Check options specified */
void sys_close(void); /* Clean up in a child before execing */
int ppp_available(void); /* Test whether ppp kernel support exists */
-int get_pty(int *, int *, char *, int); /* Get pty master/slave */
int open_ppp_loopback(void); /* Open loopback for demand-dialling */
int establish_ppp(int); /* Turn serial port into a ppp interface */
void restore_loop(void); /* Transfer ppp unit back to loopback */
diff --git a/cpukit/pppd/sys-rtems.c b/cpukit/pppd/sys-rtems.c
index 3fdca9ee0c..f973795b2c 100644
--- a/cpukit/pppd/sys-rtems.c
+++ b/cpukit/pppd/sys-rtems.c
@@ -443,20 +443,6 @@ setdtr(
ioctl(fd, (on? TIOCMBIS: TIOCMBIC), &modembits);
- * get_pty - get a pty master/slave pair and chown the slave side
- * to the uid given. Assumes slave_name points to >= 12 bytes of space.
-int
-get_pty(
- int *master_fdp,
- int *slave_fdp,
- char *slave_name,
- int uid)
- return 1;
* open_ppp_loopback - open the device we use for getting
2.16.4
