New Coverity Scan Results for RTEMS Available
Thu Sep 27 15:59:06 UTC 2018
On Thu, Sep 27, 2018 at 3:00 AM, Sebastian Huber
> On 26/09/2018 15:42, Joel Sherrill wrote:
>> On Wed, Sep 26, 2018 at 7:04 AM Sebastian Huber
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>     On 26/09/2018 14:02, Sebastian Huber wrote:
>>     > void rtems_task_delete_self() RTEMS_NORETURN;
>>     Alternative would be
>>     void rtems_task_exit(void) RTEMS_NORETURN;
>> I don't want to change APIs to make any static analysis tool happy.
> Yes, just adding APIs to make a static analysis tool happy is not that
> great, however, we have to consider also the compiler which has a similar
> problem with the rtems_task_delete(RTEMS_SELF) function. We already tell the
> compiler that some functions do not return and I think an rtems_task_exit()
> would make sense too. For example we have in Newlib:
> void    pthread_exit (void *__value_ptr) __dead2;
I think this is acceptable in case it spans multiple tools in a
relatively general way. For sure, we must avoid tool-specific
annotations.
>> I used
>> Grammatech CodeSonar on RTEMS a few years ago and if we made it
>> happy, we would be very unhappy.
>> The best solution would be to figure out the Coverity modeling and
>> annotation.
>> Then we could teach it our memory allocators, internal locks, etc..  I
>> have a model
>> uploaded in our configuration but I admit to not having any confidence in
>> making
>> Scan do anything with it. I found this:
>> https://stackoverflow.com/questions/42197018/how-do-i-use-coverity-modelling-to-mark-a-method-as-non-returning
>> But that looks to modify the source. I don't want to do more than simple
>> annotation.
>> I don't want hacks like that in the real source.
>> I have an attempt at a model here
>> (https://git.rtems.org/rtems-testing/tree/coverity)
>> and have uploaded it.
> Maybe Coverity understands the clang thread safety annotations and the GCC
> attributes
> __attribute__((__malloc__))
> __attribute__((__alloc_size__(n, x)))
I have a project that will put some time in to improving static
analysis of RTEMS over the next year or so. I will try to put some
effort into these problematic areas.
> devel mailing list
> devel at rtems.org
