Problem with rtems-libbsd build
Jeff Mayes
Jeff.Mayes at OARcorp.com
Fri Sep 28 15:18:49 UTC 2018
Hi
Pulled rtems and rtems-libbsd yesterday. Then, built rtems for powerpc and qoriq_core_0 successfully. Trying to build rtems-libbsd now, but getting this error below. Any ideas?
Thanks in advance
[1433/2034] Compiling freebsd/sys/dev/sdhci/fsl_sdhci.c
../../freebsd/sys/dev/sdhci/fsl_sdhci.c:70:10: fatal error: powerpc/mpc85xx/mpc85xx.h: No such file or directory
#include <powerpc/mpc85xx/mpc85xx.h>
compilation terminated.
Waf: Leaving directory `/home/tester/rtems/rtems-libbsd/build/powerpc-rtems5-qoriq_core_0-default`
Build failed
-> task in `bsd` failed (exit status 1):
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180928/e2cc21fb/attachment.html>
