rtems-bsp-builder .ini file syntax question (for epiphany)
Joel Sherrill
joel at rtems.org
Fri Sep 7 14:59:13 UTC 2018
On Thu, Sep 6, 2018 at 9:07 PM Chris Johns <chrisj at rtems.org> wrote:
> On 6/9/18 9:00 am, Joel Sherrill wrote:
> > https://lists.rtems.org/pipermail/build/2018-September/000997.html
> still has
> > epiphany
> > failures. Not sure what else is going on. Do you see the pattern?
> The 'debug' build is not adding '--disable-networking' as the BSP builder
> is not
> tracking defaults or more specifically enabled by default. The SMP works
> because
> the default is disabled while networking has a default of enabled.
Yes. That's clearly the problem. Any ideas on how to address this? I can
always
force networking off for epiphany in the cpukit. We were talking about that
anyway.
Would it be better if exclude implied --disable?
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180907/0288ab24/attachment-0002.html>
