Kernel-space ctypes.h support?
Sebastian Huber
Fri Sep 14 05:57:52 UTC 2018
On 14/09/2018 04:27, Joel Sherrill wrote:
> On Thu, Sep 13, 2018, 9:25 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 14/09/2018 10:13, Joel Sherrill wrote:
> > On Thu, Sep 13, 2018, 5:40 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
> > On 14/09/2018 02:30, Joel Sherrill wrote:
> > > On Thu, Sep 13, 2018, 10:34 AM Sebastian Huber
> > > <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>
> <mailto:sebastian.huber at embedded-brains.de>>
> <mailto:sebastian.huber at embedded-brains.de>>>>
> > > wrote:
> > > ----- Am 13. Sep 2018 um 14:07 schrieb joel
> joel at rtems.org <mailto:joel at rtems.org>
> > <mailto:joel at rtems.org <mailto:joel at rtems.org>>
> <mailto:joel at rtems.org <mailto:joel at rtems.org>>>:
> > > > On Thu, Sep 13, 2018, 3:28 AM Sebastian Huber <
> <mailto:sebastian.huber at embedded-brains.de>>>> wrote:
> > > >> Hello,
> > > >> I test currently the tqm8xx BSP which worked fine
> until RTEMS 5. The
> > > >> problem is that this BSP uses strtoul() to get some
> system
> > configuration
> > > >> parameters from the boot loader. The Newlib used by
> RTEMS 5 has now
> > > >> support for C locales in strtoul(). The C locale
> support needs an
> > > >> executing thread with a valid Newlib reentrancy
> structure. This is
> > > >> definitely not the case during bsp_start().
> > > > Why do we now longer have a global reentrancy
> structure to fall back on?
> > > I think having a global reentrancy as a fall back just
> for the lowest
> > level
> > > system start without an idle thread is a bit of overkill.
> > > The heavy weight C local support which was recently
> introduced in
> > Newlib is
> > > not really the right thing for the embedded systems I
> know. There were
> > > several complaints about this on the Newlib mailing
> list as well. The
> > root
> > > cause for this is the C standard. So, basically the C
> standard
> > strtoul() is
> > > unsuitable for embedded systems. The FreeBSD
> (sys/kern/strtoul.c) and
> > Linux
> > > (lib/kstrtox.c) kernel have their own implementations.
> > > FWIW the FACE Technical Standard does not include wide
> characters in ANY
> > profile
> > > as of Edition 3.0. None of the RTOS vendors knew of any
> avionics users. It
> > > wasn't viewed as a necessary feature. We could consider
> disabling it by
> > default.
> > Is this something we could ot would want to control with
> newlib via a config
> > option?
> > We don't turn on locale for h8, m32c and maybe not epiphany. I
> am pretty sure.it <http://sure.it>
> > <http://sure.it> is an option. And should be a documented RSB
> option to turn it
> > back on. Should be a size savings for most users.
> We turn on or off as an option?
> Based on Sebastian's observation, I think off.
> Does this impact wide characters and multibyte?
> We will need to document the impact. I suspect it removes some POSIX
> support in a base build.
This problem with the C locale support used in strtoul() has absolutely
nothing to do with the wide character or iconv() support.
Currently it is not possible to disable the C locale support in Newlib.
Would such an option be the preferred way instead of a custom strtoul()
etc. API and implementation?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
