Kernel-space ctypes.h support?
Sebastian Huber
Mon Sep 17 06:33:53 UTC 2018
On 14/09/2018 18:57, Joel Sherrill wrote:
> On Fri, Sep 14, 2018 at 12:57 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 14/09/2018 04:27, Joel Sherrill wrote:
> > On Thu, Sep 13, 2018, 9:25 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>
> > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
> > On 14/09/2018 10:13, Joel Sherrill wrote:
> > > On Thu, Sep 13, 2018, 5:40 PM Chris Johns
> <chrisj at rtems.org <mailto:chrisj at rtems.org>
> <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>>> wrote:
> > > On 14/09/2018 02:30, Joel Sherrill wrote:
> > > > On Thu, Sep 13, 2018, 10:34 AM Sebastian Huber
> <mailto:sebastian.huber at embedded-brains.de>>>
> <mailto:sebastian.huber at embedded-brains.de>>>>>
> > > > wrote:
> > > > ----- Am 13. Sep 2018 um 14:07 schrieb joel
> > joel at rtems.org <mailto:joel at rtems.org> <mailto:joel at rtems.org
> <mailto:joel at rtems.org>>
> > > <mailto:joel at rtems.org <mailto:joel at rtems.org>
> <mailto:joel at rtems.org <mailto:joel at rtems.org>>>
> <mailto:joel at rtems.org <mailto:joel at rtems.org>>>>:
> > > > > On Thu, Sep 13, 2018, 3:28 AM Sebastian Huber <
> <mailto:sebastian.huber at embedded-brains.de>>>>> wrote:
> > > > >> Hello,
> > > > >> I test currently the tqm8xx BSP which worked fine
> > until RTEMS 5. The
> > > > >> problem is that this BSP uses strtoul() to
> get some
> > system
> > > configuration
> > > > >> parameters from the boot loader. The Newlib
> used by
> > RTEMS 5 has now
> > > > >> support for C locales in strtoul(). The C locale
> > support needs an
> > > > >> executing thread with a valid Newlib reentrancy
> > structure. This is
> > > > >> definitely not the case during bsp_start().
> > > > > Why do we now longer have a global reentrancy
> > structure to fall back on?
> > > > I think having a global reentrancy as a fall
> back just
> > for the lowest
> > > level
> > > > system start without an idle thread is a bit of
> overkill.
> > > > The heavy weight C local support which was recently
> > introduced in
> > > Newlib is
> > > > not really the right thing for the embedded
> systems I
> > know. There were
> > > > several complaints about this on the Newlib mailing
> > list as well. The
> > > root
> > > > cause for this is the C standard. So, basically
> the C
> > standard
> > > strtoul() is
> > > > unsuitable for embedded systems. The FreeBSD
> > (sys/kern/strtoul.c) and
> > > Linux
> > > > (lib/kstrtox.c) kernel have their own
> implementations.
> > > > FWIW the FACE Technical Standard does not include wide
> > characters in ANY
> > > profile
> > > > as of Edition 3.0. None of the RTOS vendors knew of any
> > avionics users. It
> > > > wasn't viewed as a necessary feature. We could consider
> > disabling it by
> > > default.
> > > Is this something we could ot would want to control with
> > newlib via a config
> > > option?
> > > We don't turn on locale for h8, m32c and maybe not epiphany. I
> > am pretty sure.it <http://sure.it> <http://sure.it>
> > > <http://sure.it> is an option. And should be a documented RSB
> > option to turn it
> > > back on. Should be a size savings for most users.
> > We turn on or off as an option?
> > Based on Sebastian's observation, I think off.
> > Does this impact wide characters and multibyte?
> > We will need to document the impact. I suspect it removes some
> POSIX
> > support in a base build.
> This problem with the C locale support used in strtoul() has
> absolutely
> nothing to do with the wide character or iconv() support.
> Currently it is not possible to disable the C locale support in
> Newlib.
> Would such an option be the preferred way instead of a custom
> strtoul()
> etc. API and implementation?
> I think so. It would result in smaller footprint which is desirable for an
> unlikely to be used feature.
> I would like to know the impact of only having a single default locale
> though.
It seems there is already some work in progress in this direction:
https://sourceware.org/ml/newlib/2018/msg00889.html
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
