RTEMS on ARMv8
Joel Sherrill
joel at rtems.org
Mon Apr 1 13:45:03 UTC 2019
On Mon, Apr 1, 2019 at 7:54 AM Jeff Kubascik <Jeff.Kubascik at dornerworks.com>
wrote:
> On 3/28/2019 8:00 AM, Sebastian Huber wrote:
> > Hello Jeff,
> > On 27/03/2019 19:11, Jeff Kubascik wrote:
> >> Hello,
> >> I am interested in porting RTEMS to run as a Xen guest on our distro
> for the
> >> Xilinx Zynq UltraScale+ MPSoC. The MPSoC has an ARM Cortex-A53
> processor, which
> >> is based on the ARMv8 architecture.
> >> I have noticed that RTEMS already runs on a few Zynq 7000 boards.
> However, those
> >> are using the Cortex-A9 processor, which is based on the ARMv7
> architecture.
> >> Looking at the source code, I didn't see any ARMv8 cpu code.
> >> I was curious if there has been any work done to port RTEMS to an ARMv8
> based
> >> platform?
> > AArch64 is a completely new architecture port. I think nobody is working
> > on that. We may work on AArch32 support for the Zynq UltraScale+ this
> year:
> > http://devel.rtems.org/ticket/3682
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone : +49 89 189 47 41-16
> > Fax : +49 89 189 47 41-09
> > E-Mail : sebastian.huber at embedded-brains.de
> > PGP : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Sebastian,
> We were able to hack up the xilinx-zynq BSP to get it running on the
> Ultra96 in
> AArch32 mode. Surprisingly, it didn't require too many code changes. Our
> key
> findings were
> - Set the CP15BEN bit in the SCTLR register to enable legacy memory barrier
> system instructions. This is used in the arm-cp15 cache operations.
> - Clear the TRE bit in the SCTLR register to disable TEX remap. This was
> causing
> the page table attributes to show up as strongly ordered, resulting in an
> unaligned memory exceptions in the newlib memcpy.
> - Update peripheral addresses, IRQs, clock rates to match the MPSoC.
> - Update the MMU peripheral region mappings.
> - Change the system clock source to clock-generic-timer.
> - Change the cache implementation to cache-cp15.
> With the above changes, we are able to run all the applications under the
> testsuites/samples directory on the Ultra96 via JTAG boot.
> Over the weekend, I started putting together a new xilinx-zynqmp BSP layer
> to
> support the Xilinx UltraScale+ MPSoC platform, including the Ultra96
> development
> board. If the RTEMS community is interested in these patches, we are
> looking to
> submit them later in the week.
Cool! Sounds of interest.
This sounds like it would be a variant on the existing xilinx 32-bit BSP.
Right?
Most of the code is unchanged but some conditionals.
Were there changes outside the BSP?
If strictly BSP, then it needs a name and then could be a variant of the
existing
BSP. That basically boils down to a config/*.cfg file with the BSP variant
name,
some mods to configure.ac to give you an automake variable to switch the
timer
to clock-generic-time in the Makefile.am, and something to trip the various
ifdef's
on.
Then some instructions in the Users Guide on how you ran it.
Of course, that's if I am understanding the magnitude of the change.
> -Jeff Kubascik
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190401/030648d8/attachment.html>
