[PATCH 3/4] bsps/riscv: UART - Comment code that queries UART interrupts
Tue Apr 2 05:03:21 UTC 2019
On 31/03/2019 16:33, Hesham Almatary wrote:
> * Different RISC-V DTBs use different names for UART interrupts such as
> "interrupts" and "interrupts-extended", so it is not portable.
> * polling functions are currently used, so there is no need to query interrupts.
>   bsps/riscv/riscv/console/console-config.c | 9 ++++++++-
>   1 file changed, 8 insertions(+), 1 deletion(-)
> diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
> index 04d0b28361..81e46f304f 100644
> --- a/bsps/riscv/riscv/console/console-config.c
> +++ b/bsps/riscv/riscv/console/console-config.c
> @@ -183,13 +183,20 @@ static void riscv_console_probe(void)
>         ctx->clock = fdt32_to_cpu(val[0]);
> -      val = (fdt32_t *) fdt_getprop(fdt, node, "interrupts", &len);
> +      /* XXX Different RISC-V DTBs use different property names for interrupt
> +      sources. If an interrupt-driven driver is needed, uncomment, replace the
> +      "interrupts-extended" string below with your target's DTB name for UART
> +      interrupts, and use interrupt-driven UART functions instead of
> +      ns16550_polled_* functions */
> +      /* val = (fdt32_t *) fdt_getprop(fdt, node, "interrupts-extended", &len);
>         if (val == NULL || len != 4) {
>           bsp_fatal(RISCV_FATAL_NO_NS16550_INTERRUPTS_IN_DEVICE_TREE);
>         ctx->irq = RISCV_INTERRUPT_VECTOR_EXTERNAL(fdt32_to_cpu(val[0]));
>         if (node == console_node) {
>           riscv_console.context = &ctx->base;
The driver uses interrupts:
rtems_status_code console_initialize(
   rtems_device_major_number major,
   rtems_device_minor_number minor,
   void *arg
     rtems_termios_device_install(
       path,
       &ns16550_handler_interrupt,
       NULL,
       &ctx->base
In the long run we need some standard support for device trees similar
to what Linux or FreeBSD has. Unfortunately, this is a multiple man-week
work package.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
