RTEMS on ARMv8
Tue Apr 2 12:20:55 UTC 2019
On 02/04/2019 14:15, Jeff Kubascik wrote:
> How capable is the device tree support in RTEMS? I did notice some device tree
> code in the IMX BSP layer, but it appeared to reference fixed nodes. Does RTEMS
> perform driver probing based on the device tree?
The device tree support in RTEMS is quite rudimentary. However, in the
BSP you don't need much. You just have to deal with the interrupt
controller, the clock driver and an UART driver. Maybe also I2C and SPI,
but these are simple things. The more complex drivers are in libbsd
(USB, MMC/SDCard, Ethernet). Here we have the device tree support from
FreeBSD. It is not as good as the device tree support from Linux
especially if it comes down to pins and clocks since this is a real mess
usually.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
