[PATCH 00/28] Doxygen group changes
Wed Apr 3 07:31:33 UTC 2019
Andreas Dachsberger (28):
  doxygen: User Extensions Implementation group now in Internal->Classic
  doxygen: Added Mainpage to RTEMSAPIClassic
  doxygen: Added further groups to RTEMSAPIClassic
  doxygen: Added toplevel group for device drivers
  doxygen: Added libmisc group and libmisc mouse group
  doxygen: Added subgroup Generic to BSP->SPARC64
  doxygen: Added Management to Example CPU Architecture
  doxygen: Removed XXX group
  doxygen: Added some subgroups to IO Library
  doxygen: Added Frame Buffer Device Driver Interface to Device Drivers
  doxygen: Added Version to API->Classic
  doxygen: Added I2C Driver to Device Drivers
  doxygen: Added some subgroups to API->Classic
  doxygen: Put C Library Support and POSIX in Internal
  doxygen: Put SPI Driver into group Device Drivers
  doxygen: Real Time Clock Time of Day API Definition in BSP->Shared
  doxygen: Put Print Support in Classic API
  doxygen: Put Real-Timer Clock Driver Interface into group Device
    Drivers
  doxygen: Benchmark Timer Driver Interface now in Device Drivers
  doxygen: Time Test 27 now in Device Drivers
  doxygen: Mouse now in Device Drivers
  doxygen: Print Support now in API->IO
  doxygen: Zero and Null Device Drivers now in Device Drivers
  doxygen: Added subclasses to API->Classic
  doxygen: Added inttypes.h to Print Support
  doxygen: Added RTEMS Test Framework to API
  doxygen: New API subgroup Tracing
  doxygen: Split up "libmisc" subgroups and removed libmisc
 bsps/sparc64/include/arch/mm/doxygen.h            |  8 ++++
 bsps/sparc64/include/boot/align.h                 |  2 +-
 bsps/sparc64/include/boot/gentypes.h              |  2 +-
 bsps/sparc64/include/kernel/align.h               |  2 +-
 cpukit/doxygen.h                                  | 55 +++++++++++++++++++++++
 cpukit/include/dev/i2c/i2c.h                      |  2 +
 cpukit/include/dev/spi/spi.h                      |  2 +
 cpukit/include/rtems/assoc.h                      |  4 +-
 cpukit/include/rtems/bdbuf.h                      |  5 ++-
 cpukit/include/rtems/bsd.h                        |  2 +
 cpukit/include/rtems/bspIo.h                      |  2 +
 cpukit/include/rtems/bspcmdline.h                 |  7 +--
 cpukit/include/rtems/btimer.h                     |  2 +
 cpukit/include/rtems/capture.h                    |  2 +-
 cpukit/include/rtems/cpuuse.h                     |  7 ++-
 cpukit/include/rtems/devnull.h                    |  2 +-
 cpukit/include/rtems/devzero.h                    |  2 +-
 cpukit/include/rtems/dumpbuf.h                    |  2 +-
 cpukit/include/rtems/extensionimpl.h              |  2 +-
 cpukit/include/rtems/fb.h                         |  2 +-
 cpukit/include/rtems/ftpfs.h                      |  2 +
 cpukit/include/rtems/inttypes.h                   |  2 +
 cpukit/include/rtems/libcsupport.h                |  2 +
 cpukit/include/rtems/libi2c.h                     |  2 +
 cpukit/include/rtems/libio_.h                     |  2 +
 cpukit/include/rtems/media.h                      |  2 +
 cpukit/include/rtems/mw_uid.h                     |  7 ++-
 cpukit/include/rtems/posix/posixapi.h             |  2 +
 cpukit/include/rtems/print.h                      |  2 +
 cpukit/include/rtems/profiling.h                  |  2 +
 cpukit/include/rtems/recorddata.h                 |  2 +
 cpukit/include/rtems/rtc.h                        |  2 +
 cpukit/include/rtems/rtems/barrierdata.h          |  2 +-
 cpukit/include/rtems/rtems/mainpage.h             |  2 +-
 cpukit/include/rtems/rtl/rap.h                    |  2 +
 cpukit/include/rtems/rtl/rtl.h                    |  2 +
 cpukit/include/rtems/stackchk.h                   |  7 ++-
 cpukit/include/rtems/status-checks.h              |  2 +
 cpukit/include/rtems/stringto.h                   |  7 ++-
 cpukit/include/rtems/test.h                       |  2 +
 cpukit/include/rtems/timecounter.h                |  2 +
 cpukit/include/rtems/tm27-default.h               |  4 +-
 cpukit/include/rtems/tod.h                        |  2 +-
 cpukit/include/rtems/untar.h                      |  2 +-
 cpukit/include/rtems/version.h                    |  4 +-
 cpukit/include/t.h                                |  2 +
 cpukit/sapi/src/version.c                         |  2 +-
 cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h |  8 ++++
 48 files changed, 156 insertions(+), 39 deletions(-)
2.16.4
