[PATCH 26/28] doxygen: Added RTEMS Test Framework to API
Wed Apr 3 13:43:06 UTC 2019
On 03/04/2019 14:57, Joel Sherrill wrote:
> I should have spotted it when the file t.h was added but we should
> avoid adding files to the top of the include tree. This space is
> primarily owned by POSIX, C, and applications.
> Also t.h is very short with no value to being short. Being used in the
> tests, it could be arbitrarily long like t_test_framework.h and really
> wouldn't matter.
I searched for <t.h> and it seems nobody else was crazy enough to use
such a header file. Originally, the test framework had an RTEMS
independent name. Maybe, we should move it to <rtems/test.h> and move
the current <rtems/test.h> to <rtems/legacy-test.h>.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
