Doxygen Guidelines: @brief for @file?
Wed Apr 3 13:44:25 UTC 2019
On 03/04/2019 15:10, Joel Sherrill wrote:
> On Wed, Apr 3, 2019 at 3:11 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> Hello,
> I rework currently the Doxygen Guidelines in the RTEMS Software
> Engineering manual. I am not sure what we want to do with the
> @brief in
> the @file blocks. For me it is important that each file belongs to a
> group, so an @ingroup should be mandatory. With an @ingroup the
> @brief
> seems to be redundant (the group should have an @brief and a detailed
> description). This is my proposal for the @file blocks:
> Files
> Place an ``@file`` block at the top of each file.  The ``@file``
> block
> should
> precede the license header.  This placement reduces the chance of
> merge
> conflicts in imported third-party code.  The ``@file`` block shall be
> put into
> a group with ``@ingroup``.  The ``@file`` block shall not have
> additional
> content, e.g. a ``@brief`` description.
> .. code:: c
>       * @file
>       * @brief RTEMSScoreThread
> The @brief shows up in at least the list of files and table of
> contents when PDF. It should
> be a short English description of the files. I feel STRONGLY that we
> and that it is better English than the example above.
> Here is an example in HTML output of where it is used:
> http://www.icu-project.org/apiref/icu4c/files.html
> FWIW the daily built Doxygen is inaccessible so I can't show you what
> it looks like in our
> documentation.
We have about 5000 files which should be in a group. I don't want to
write prosaic text for each file. What about this approach:
  * @file
  * @ingroup RTEMSScoreThread
  * @brief
  * @copybrief RTEMSScoreThread
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
