[PATCH] Add Test suite for inttypes.h (psxinttypes.exe) in testsuites/psxtests
Vaibhav Gupta vaibhavgupta40 at gmail.com
Wed Apr 3 17:59:35 UTC 2019
 testsuites/psxtests/Makefile.am               |   7 +
 testsuites/psxtests/configure.ac              |   1 +
 testsuites/psxtests/psxinttypes01/init.c      | 154 ++++++++++++++++++
 .../psxtests/psxinttypes01/psxinttypes01.doc  |  57 +++++++
 .../psxtests/psxinttypes01/psxinttypes01.scn  |  28 ++++
 5 files changed, 247 insertions(+)
 create mode 100644 testsuites/psxtests/psxinttypes01/init.c
 create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.doc
 create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.scn
diff --git a/testsuites/psxtests/Makefile.am
b/testsuites/psxtests/Makefile.am
index 749258cc0c..f619dd9ae9 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -22,6 +22,13 @@ psx01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psx01) \
        $(support_includes) -I$(top_srcdir)/include
 endif
+if TEST_psxinttypes01
+psx_tests += psxinttypes01
+psxinttypes01_SOURCES = psxinttypes01/init.c
+psxinttypes01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxinttypes01) \
+       $(support_includes)
+endif
 if HAS_POSIX
 if TEST_psx02
 psx_tests += psx02
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
configure.ac
index cdd6ee7e4e..e032a6f5ec 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -140,6 +140,7 @@ RTEMS_TEST_CHECK([psxtimes01])
 RTEMS_TEST_CHECK([psxualarm])
 RTEMS_TEST_CHECK([psxusleep])
 RTEMS_TEST_CHECK([lib_a])
+RTEMS_TEST_CHECK([psxinttypes01])
 AC_CONFIG_FILES([Makefile])
 AC_OUTPUT
diff --git a/testsuites/psxtests/psxinttypes01/init.c
b/testsuites/psxtests/psxinttypes01/init.c
new file mode 100644
index 0000000000..1c6340afe2
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/init.c
@@ -0,0 +1,154 @@
+ *  @file
+ *  @brief Test suite for inttypes.h methods
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019, Vaibhav Gupta
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
THE
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/test.h>
+#include <inttypes.h>
+#include <stdio.h>
+#include <errno.h>
+#include <tmacros.h>
+#include <stdint.h>
+#include <stddef.h>
+const char rtems_test_name[] = "PSXINTTYPE 01";
+/* forward declarations to avoid warnings */
+rtems_task Init(rtems_task_argument ignored);
+  int       base     = 10;
+  char     *nptr1    = "123abc";
+  char     *endptr1  = NULL;
+  wchar_t  *nptr2    = L"-123junk";
+  wchar_t  *endptr2  = NULL;
+  intmax_t  status1;
+  uintmax_t status2;
+  TEST_BEGIN();
+  puts( "\nChecking invalid base value" );
+  rtems_test_assert( base >=2 && base <= 36 );
+  /*Test for strtoimax  */
+  puts( "Strtoimax Testcases...." );
+  puts( "Generating Status" );
+  status1 = strtoimax( nptr1, &endptr1, base );
+  rtems_test_assert( status1 != 0);
+  rtems_test_assert( base != EINVAL);
+  puts( "Checking Garbage end of endptr" );
+  rtems_test_assert( *endptr1 != '\0' );
+  puts( "Checking Underflow Case" );
+  rtems_test_assert( status1 >= INTMAX_MIN );
+  puts( "Checking Overflow Case" );
+  rtems_test_assert( status1 <= INTMAX_MAX ) ;
+  printf( "status = %jd \n" , status1 );
+  /*Test for strtoumax  */
+  puts( "Strtoumax Testcases...." );
+  status2 = strtoumax( nptr1, &endptr1, base );
+  rtems_test_assert( status2 != 0);
+  rtems_test_assert( status2 <= UINTMAX_MAX );
+  printf( "status = %ju \n", status2 );
+  /*Test for wcstoimax  */
+  puts( "Wcstoimax Testcases...." );
+  status1 = wcstoimax( nptr2, &endptr2, base );
+  rtems_test_assert( *endptr2 != '\0' );
+  printf( "status = %jd \n", status1 );
+  /*Test for wcstoumax  */
+  puts( "wcstoumax Testcases...." );
+  status2 = wcstoumax( nptr2, &endptr2, base );
+  TEST_END();
+  rtems_test_exit(0);
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS            1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
index 0000000000..f9e0951786
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
@@ -0,0 +1,57 @@
+ *  @file
+ *  @brief Doc for Test suite for inttypes.h methods
+ * are met:
IS"
THE
PURPOSE
THE
+This File describes the concepts tested by this test suite.
+inttypes.h - fixed size integer types
+test suite name: PSXINTTYPE 01
+- Checks for invalid base value
+- Checks for Strtoimax Testcases
+       - checks for Garbage end of endptr
+       - checks for Underflow Case
+       - checks for Overflow Case
+- Checks for Strtoumax Test Cases
+- Checks for Wcstoimax Testcases
+- Checks for Wcstoumax Testcases
diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
index 0000000000..cdd56b327d
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
@@ -0,0 +1,28 @@
+*** PSXINTTYPE 01 TEST ***
+Checking invalid base value
+Strtoimax Testcases....
+Generating Status
+Checking Garbage end of endptr
+Checking Underflow Case
+Checking Overflow Case
+status = 123
+Strtoumax Testcases....
+Generating Status
+status = 123
+Wcstoimax Testcases....
+Generating Status
+status = -123
+wcstoumax Testcases....
+Generating Status
+status = 18446744073709551493
+*** END OF PSXINTTYPE 01 TEST ***
2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190403/91972937/attachment.html>
