[PATCH 26/28] doxygen: Added RTEMS Test Framework to API
Wed Apr 3 23:58:38 UTC 2019
On 4/4/19 12:43 am, Sebastian Huber wrote:
> On 03/04/2019 14:57, Joel Sherrill wrote:
>> I should have spotted it when the file t.h was added but we should avoid
>> adding files to the top of the include tree. This space is primarily owned by
>> POSIX, C, and applications.
>> Also t.h is very short with no value to being short. Being used in the tests,
>> it could be arbitrarily long like t_test_framework.h and really wouldn't matter.
> I searched for <t.h> and it seems nobody else was crazy enough to use such a
> header file. Originally, the test framework had an RTEMS independent name.
> Maybe, we should move it to <rtems/test.h> and move the current <rtems/test.h>
> to <rtems/legacy-test.h>.
I am ok with renaming these files.
Chria
