Doxygen Guidelines: @brief for @file?
Thu Apr 4 05:35:50 UTC 2019
On 03/04/2019 15:48, Joel Sherrill wrote:
> On Wed, Apr 3, 2019 at 8:44 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 03/04/2019 15:10, Joel Sherrill wrote:
>     > On Wed, Apr 3, 2019 at 3:11 AM Sebastian Huber
>     <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>     What about this approach:
>       * @file
>       * @ingroup RTEMSScoreThread
>       * @brief
>       * @copybrief RTEMSScoreThread
> This is OK as a default but it shouldn't be the only option. I
> wouldn't delete
> a comment that was more specific or use that when a more specific
> comment is better.
> We don't want comments to exist just to improve a comments to code ratio.
> They are supposed to be meaningful. IMO the copybrief adds no value to
> the file when reading it.
The file path, file name and @ingroup gives you already a good
indication to which area a file belongs.
> It only adds value when the file is processed and
> you are reading the Doxygen output. So use this as a default but don't
> delete @brief's which are better and this does not stop someone from
> writing a more meaningful brief.
What about this:
Each source or header file shall have an ``@file`` block at the top of the
file.  The ``@file`` block should precede the license header separated
by one
blank line.  This placement reduces the chance of merge conflicts in
imported
third-party code.  The ``@file`` block shall be put into a group with
``@ingroup GroupName``.  The ``@file`` block should have an ``@brief``
description and a detailed description if it is considered helpful. Use
``@brief @copybrief GroupName`` as a default to copy the ``@brief``
description
from the corresponding group and omit the detailed description.
.. code:: c
      * @file
      * @brief @copybrief RTEMSScoreThread
.. code:: c
      * @file
      * @brief Some helpful brief description.
      * Some helpful detailed description.
Unclear:
Should the @brief in Title Case or should it be a normal sentence?
Some hints what helpful is would be nice. What is the threshold to write
something special?
> I still don't know where in the output, text beyond the @brief on a file
> block goes. Any ideas?
It goes to the "Detailed Description" of the file documentation.
https://docs.rtems.org/doxygen/branches/master/score_2thread_8h.html#details
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
