[PATCH 2/3] rtems: Add rtems_scheduler_get_processor()
Fri Apr 5 07:15:09 UTC 2019
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
 bsps/powerpc/qoriq/start/bsprestart.c         |  2 +-
 bsps/sparc/leon3/start/bspclean.c             |  2 +-
 cpukit/include/rtems/rtems/smp.h              | 19 ---------
 cpukit/include/rtems/rtems/tasks.h            | 34 +++++++++++++++
 cpukit/libmisc/capture/capture.c              |  4 +-
 cpukit/libtest/t-test-rtems-measure.c         |  2 +-
 cpukit/libtest/testparallel.c                 |  2 +-
 cpukit/rtems/src/getcurrentprocessor.c        |  4 +-
 testsuites/smptests/smp01/init.c              |  2 +-
 testsuites/smptests/smp01/tasks.c             |  2 +-
 testsuites/smptests/smp02/init.c              |  2 +-
 testsuites/smptests/smp02/tasks.c             |  2 +-
 testsuites/smptests/smp03/init.c              |  2 +-
 testsuites/smptests/smp05/init.c              |  4 +-
 testsuites/smptests/smp07/init.c              |  4 +-
 testsuites/smptests/smp08/init.c              |  2 +-
 testsuites/smptests/smp09/init.c              |  2 +-
 testsuites/smptests/smpatomic01/init.c        |  6 +--
 testsuites/smptests/smpcache01/init.c         | 12 +++---
 testsuites/smptests/smpcapture01/init.c       |  4 +-
 testsuites/smptests/smpclock01/init.c         |  4 +-
 testsuites/smptests/smpfatal01/init.c         |  4 +-
 testsuites/smptests/smpfatal02/init.c         |  4 +-
 testsuites/smptests/smpipi01/init.c           |  4 +-
 testsuites/smptests/smpmigration01/init.c     |  2 +-
 testsuites/smptests/smpmigration02/init.c     |  4 +-
 testsuites/smptests/smpmrsp01/init.c          | 42 +++++++++----------
 testsuites/smptests/smpmutex01/init.c         |  4 +-
 testsuites/smptests/smppsxmutex01/init.c      |  6 +--
 testsuites/smptests/smppsxsignal01/init.c     |  8 ++--
 testsuites/smptests/smpschedaffinity01/init.c |  2 +-
 testsuites/smptests/smpschedaffinity02/init.c |  4 +-
 testsuites/smptests/smpschedaffinity03/init.c |  2 +-
 testsuites/smptests/smpschedaffinity04/init.c |  4 +-
 testsuites/smptests/smpschedaffinity05/init.c |  4 +-
 testsuites/smptests/smpscheduler02/init.c     | 14 +++----
 testsuites/smptests/smpscheduler04/init.c     |  6 +--
 testsuites/smptests/smpsignal01/init.c        |  8 ++--
 testsuites/smptests/smpthreadpin01/init.c     | 60 +++++++++++++--------------
 testsuites/tmtests/tmcontext01/init.c         |  2 +-
 40 files changed, 158 insertions(+), 143 deletions(-)
diff --git a/bsps/powerpc/qoriq/start/bsprestart.c b/bsps/powerpc/qoriq/start/bsprestart.c
index 283b242a0f..228d74c231 100644
--- a/bsps/powerpc/qoriq/start/bsprestart.c
+++ b/bsps/powerpc/qoriq/start/bsprestart.c
@@ -69,7 +69,7 @@ static void restart_interrupt(void *arg)
   _SMP_barrier_State_initialize(&bs);
   _SMP_barrier_Wait(&restart_barrier, &bs, _SMP_Processor_count);
-  cpu_self_index = rtems_get_current_processor();
+  cpu_self_index = rtems_scheduler_get_processor();
   thread_index = cpu_self_index % QORIQ_THREAD_COUNT;
   if (cpu_self_index == 0) {
diff --git a/bsps/sparc/leon3/start/bspclean.c b/bsps/sparc/leon3/start/bspclean.c
index 7d5448fdb3..6cdc43e4d5 100644
--- a/bsps/sparc/leon3/start/bspclean.c
+++ b/bsps/sparc/leon3/start/bspclean.c
@@ -48,7 +48,7 @@ void bsp_fatal_extension(
        * processor.
       uint32_t max_wait = 1234567;
-      uint32_t self_cpu = rtems_get_current_processor();
+      uint32_t self_cpu = rtems_scheduler_get_processor();
       uint32_t cpu_count = rtems_get_processor_count();
       uint32_t halt_mask = 0;
       uint32_t i;
diff --git a/cpukit/include/rtems/rtems/smp.h b/cpukit/include/rtems/rtems/smp.h
index 2e0fd67d99..046c306290 100644
--- a/cpukit/include/rtems/rtems/smp.h
+++ b/cpukit/include/rtems/rtems/smp.h
@@ -49,25 +49,6 @@ extern "C" {
 uint32_t rtems_get_processor_count(void);
- * @brief Returns the index of the current processor.
- * On uni-processor configurations a value of zero will be returned.
- * On SMP configurations an architecture specific method is used to obtain the
- * index of the current processor in the system.  The set of processor indices
- * is the range of integers starting with zero up to the processor count minus
- * one.
- * Outside of sections with disabled thread dispatching the current processor
- * index may change after every instruction since the thread may migrate from
- * one processor to another.  Sections with disabled interrupts are sections
- * with thread dispatching disabled.
- * @return The index of the current processor.
-uint32_t rtems_get_current_processor(void);
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
index 4a04e71349..630a5c5295 100644
--- a/cpukit/include/rtems/rtems/tasks.h
+++ b/cpukit/include/rtems/rtems/tasks.h
@@ -583,6 +583,40 @@ rtems_status_code rtems_scheduler_ident_by_processor_set(
   rtems_id        *id
+ * @brief Returns the index of the current processor.
+ * In uniprocessor configurations, a value of zero will be returned.
+ * In SMP configurations, an architecture specific method is used to obtain the
+ * index of the current processor in the system.  The set of processor indices
+ * is the range of integers starting with zero up to the processor count minus
+ * one.
+ * Outside of sections with disabled thread dispatching the current processor
+ * index may change after every instruction since the thread may migrate from
+ * one processor to another.  Sections with disabled interrupts are sections
+ * with thread dispatching disabled.
+ * @return The index of the current processor.
+uint32_t rtems_scheduler_get_processor( void );
+ * @deprecated
+ * Use rtems_scheduler_get_processor() instead.
+RTEMS_DEPRECATED RTEMS_INLINE_ROUTINE uint32_t
+rtems_get_current_processor( void )
+  return rtems_scheduler_get_processor();
  * @brief Gets the set of processors owned by the specified scheduler instance.
diff --git a/cpukit/libmisc/capture/capture.c b/cpukit/libmisc/capture/capture.c
index 4d40b8f630..6accd509e7 100644
--- a/cpukit/libmisc/capture/capture.c
+++ b/cpukit/libmisc/capture/capture.c
@@ -356,7 +356,7 @@ void
 rtems_capture_record_lock (rtems_capture_record_lock_context* context)
   rtems_capture_per_cpu_data* cpu;
-  cpu = capture_per_cpu_get (rtems_get_current_processor ());
+  cpu = capture_per_cpu_get (rtems_scheduler_get_processor ());
   rtems_interrupt_lock_interrupt_disable (&context->lock_context);
   context->lock = &cpu->lock;
   rtems_interrupt_lock_acquire_isr (&cpu->lock, &context->lock_context);
@@ -379,7 +379,7 @@ rtems_capture_record_open (rtems_tcb*                         tcb,
   size += sizeof (rtems_capture_record);
   rtems_capture_record_lock (context);
diff --git a/cpukit/libtest/t-test-rtems-measure.c b/cpukit/libtest/t-test-rtems-measure.c
index 207aef7afa..242855f19f 100644
--- a/cpukit/libtest/t-test-rtems-measure.c
+++ b/cpukit/libtest/t-test-rtems-measure.c
@@ -115,7 +115,7 @@ load_worker(rtems_task_argument arg)
 	chunk = lctx->chunk;
 	chunk_size = ctx->chunk_size;
 	cache_line_size = ctx->cache_line_size;
-	token = (unsigned int)rtems_get_current_processor();
+	token = (unsigned int)rtems_scheduler_get_processor();
 	token = dirty_data_cache(chunk, chunk_size, cache_line_size, token);
 	wakeup_master(ctx);
diff --git a/cpukit/libtest/testparallel.c b/cpukit/libtest/testparallel.c
index 1182242a7b..ea805a3cf4 100644
--- a/cpukit/libtest/testparallel.c
+++ b/cpukit/libtest/testparallel.c
@@ -74,7 +74,7 @@ static void run_tests(
       rtems_interrupt_local_disable(level);
       _SMP_barrier_Wait(&ctx->barrier, &bs, ctx->worker_count);
-      worker_index = rtems_get_current_processor();
+      worker_index = rtems_scheduler_get_processor();
       rtems_interrupt_local_enable(level);
       _Assert(worker_index < ctx->worker_count);
diff --git a/cpukit/rtems/src/getcurrentprocessor.c b/cpukit/rtems/src/getcurrentprocessor.c
index 5fc48b9426..10811ade66 100644
--- a/cpukit/rtems/src/getcurrentprocessor.c
+++ b/cpukit/rtems/src/getcurrentprocessor.c
@@ -16,10 +16,10 @@
   #include "config.h"
 #endif
-#include <rtems/rtems/smp.h>
+#include <rtems/rtems/tasks.h>
 #include <rtems/score/smp.h>
+uint32_t rtems_scheduler_get_processor(void)
   return _SMP_Get_current_processor();
diff --git a/testsuites/smptests/smp01/init.c b/testsuites/smptests/smp01/init.c
index c77a192071..cf7d5ab9c1 100644
--- a/testsuites/smptests/smp01/init.c
+++ b/testsuites/smptests/smp01/init.c
@@ -35,7 +35,7 @@ rtems_task Init(
   rtems_status_code  status;
   bool               allDone;
-  cpu_self = rtems_get_current_processor();
+  cpu_self = rtems_scheduler_get_processor();
   /* XXX - Delay a bit to allow debug messages from
    * startup to print.  This may need to go away when
diff --git a/testsuites/smptests/smp01/tasks.c b/testsuites/smptests/smp01/tasks.c
index b8c766f1c8..ae75b718dc 100644
--- a/testsuites/smptests/smp01/tasks.c
+++ b/testsuites/smptests/smp01/tasks.c
@@ -28,7 +28,7 @@ rtems_task Test_task(
   rtems_test_assert( p != NULL );
    /* Get the CPU Number */
-  cpu_num = rtems_get_current_processor();
+  cpu_num = rtems_scheduler_get_processor();
   /* Print that the task is up and running. */
   Loop();
diff --git a/testsuites/smptests/smp02/init.c b/testsuites/smptests/smp02/init.c
index e70eca3182..fd7c583db8 100644
--- a/testsuites/smptests/smp02/init.c
+++ b/testsuites/smptests/smp02/init.c
@@ -73,7 +73,7 @@ rtems_task Init(
       &id
     locked_printf(" CPU %" PRIu32 " start task TA%c\n", cpu_num, ch);
     status = rtems_task_start( id, Test_task, i+1 );
     directive_failed( status, str );
diff --git a/testsuites/smptests/smp02/tasks.c b/testsuites/smptests/smp02/tasks.c
index 22caf77ac1..ff82d58826 100644
--- a/testsuites/smptests/smp02/tasks.c
+++ b/testsuites/smptests/smp02/tasks.c
@@ -34,7 +34,7 @@ rtems_task Test_task(
   uint32_t          cpu_num;
   rtems_status_code sc;
   do {
diff --git a/testsuites/smptests/smp03/init.c b/testsuites/smptests/smp03/init.c
index cd6bba14e3..1e9bb69f7a 100644
--- a/testsuites/smptests/smp03/init.c
+++ b/testsuites/smptests/smp03/init.c
@@ -37,7 +37,7 @@ void PrintTaskInfo(
   uint32_t cpu_num;
   locked_printf("  CPU %" PRIu32 " running task %s\n", cpu_num, task_name );
diff --git a/testsuites/smptests/smp05/init.c b/testsuites/smptests/smp05/init.c
index 7988861983..bc2c6cd5ac 100644
--- a/testsuites/smptests/smp05/init.c
+++ b/testsuites/smptests/smp05/init.c
@@ -35,7 +35,7 @@ rtems_task Test_task(
   rtems_task_argument argument
-  locked_printf( "Shut down from CPU %" PRIu32 "\n", rtems_get_current_processor() );
+  locked_printf( "Shut down from CPU %" PRIu32 "\n", rtems_scheduler_get_processor() );
   success();
@@ -69,7 +69,7 @@ rtems_task Init(
     directive_failed( status, "task create" );
diff --git a/testsuites/smptests/smp07/init.c b/testsuites/smptests/smp07/init.c
index 66e2da38de..e4ea76183b 100644
--- a/testsuites/smptests/smp07/init.c
+++ b/testsuites/smptests/smp07/init.c
@@ -48,7 +48,7 @@ rtems_task Test_task(
   locked_printf(" CPU %" PRIu32 " runnng Task %s and blocking\n", cpu_num, name);
@@ -130,7 +130,7 @@ rtems_task Init(
   locked_printf(" CPU %d start task TA1\n", cpu_num );
   status = rtems_task_start( id, Test_task, 1 );
   directive_failed( status, "task start" );
diff --git a/testsuites/smptests/smp08/init.c b/testsuites/smptests/smp08/init.c
index ba0c7ffadd..de98865735 100644
--- a/testsuites/smptests/smp08/init.c
+++ b/testsuites/smptests/smp08/init.c
@@ -23,7 +23,7 @@ void PrintTaskInfo(
   uint32_t cpu_num;
   /* Print the cpu number and task name */
   locked_printf(
diff --git a/testsuites/smptests/smp09/init.c b/testsuites/smptests/smp09/init.c
index 5ebc855c9f..f36f8691b7 100644
--- a/testsuites/smptests/smp09/init.c
+++ b/testsuites/smptests/smp09/init.c
@@ -66,7 +66,7 @@ rtems_task Init(
diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/smpatomic01/init.c
index 593bd02d73..4ae1d58364 100644
--- a/testsuites/smptests/smpatomic01/init.c
+++ b/testsuites/smptests/smpatomic01/init.c
@@ -487,7 +487,7 @@ static void test_atomic_store_load_rmw_body(
    * Use the physical processor index, to observe timing differences introduced
    * by the system topology.
   /* Store release and load acquire test case */
@@ -638,7 +638,7 @@ static void test_single_writer_seqlock_body(
     counter = 0;
@@ -700,7 +700,7 @@ static void test_multi_writer_seqlock_body(
   if (cpu_self_index % 2 == 0) {
     counter = 0;
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index 131b986050..a679764d5d 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -47,7 +47,7 @@ static void test_action( void *arg )
   rtems_test_assert(arg == &ctx);
-  ctx.count[rtems_get_current_processor()]++;
+  ctx.count[rtems_scheduler_get_processor()]++;
 typedef void ( *test_case )(
@@ -68,7 +68,7 @@ static void test_cache_invalidate_multiple_instruction_lines(
   const cpu_set_t *cpu_set
-  uint32_t self = rtems_get_current_processor();
+  uint32_t self = rtems_scheduler_get_processor();
   ctx.do_longjmp[self] = true;
@@ -87,7 +87,7 @@ static void barrier( SMP_barrier_State *bs )
 static void broadcast_test_init( void )
-  ctx.count[rtems_get_current_processor()] = 0;
+  ctx.count[rtems_scheduler_get_processor()] = 0;
 static void broadcast_test_body(
@@ -101,7 +101,7 @@ static void broadcast_test_body(
 static void broadcast_test_fini( void )
   rtems_test_assert(
-    ctx.count[rtems_get_current_processor()] == rtems_get_processor_count()
+    ctx.count[rtems_scheduler_get_processor()] == rtems_get_processor_count()
@@ -169,7 +169,7 @@ static void call_tests_with_thread_dispatch_disabled( size_t set_size,
 static void cmlog(  const char* str )
-  if ( rtems_get_current_processor() == 0 )
+  if ( rtems_scheduler_get_processor() == 0 )
     printf( "%s", str );
@@ -256,7 +256,7 @@ static void fatal_extension(
   rtems_fatal_code error
   if (source == RTEMS_FATAL_SOURCE_EXCEPTION && ctx.do_longjmp[self]) {
     _ISR_Set_level(0);
diff --git a/testsuites/smptests/smpcapture01/init.c b/testsuites/smptests/smpcapture01/init.c
index d9c4f2e1a9..52f762eda2 100644
--- a/testsuites/smptests/smpcapture01/init.c
+++ b/testsuites/smptests/smpcapture01/init.c
@@ -76,7 +76,7 @@ static void task(rtems_task_argument arg)
     sc = rtems_semaphore_obtain (task_sem, RTEMS_NO_WAIT, 0);
     if (sc == RTEMS_SUCCESSFUL) {
       task_data[arg].ran = true;
-      task_data[arg].actual_cpu = rtems_get_current_processor();
+      task_data[arg].actual_cpu = rtems_scheduler_get_processor();
       rtems_semaphore_release(task_sem);
       test_delay(1);
@@ -89,7 +89,7 @@ static void set_init_task(void)
   /* Set Init task data */
   task_data[0].ran = true;
-  task_data[0].actual_cpu = rtems_get_current_processor();
+  task_data[0].actual_cpu = rtems_scheduler_get_processor();
diff --git a/testsuites/smptests/smpclock01/init.c b/testsuites/smptests/smpclock01/init.c
index ecfab36b9b..4887ec20e7 100644
--- a/testsuites/smptests/smpclock01/init.c
+++ b/testsuites/smptests/smpclock01/init.c
@@ -64,7 +64,7 @@ static void timer_task(rtems_task_argument arg)
   rtems_id timer_id;
-  rtems_test_assert(rtems_get_current_processor() == 1);
+  rtems_test_assert(rtems_scheduler_get_processor() == 1);
   sc = rtems_timer_create(SCHEDULER_B, &timer_id);
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
@@ -96,7 +96,7 @@ static void delay_clock_tick(test_context *ctx)
   const Per_CPU_Control *cpu_other = _Per_CPU_Get_by_index(1);
   uint64_t ticks;
-  rtems_test_assert(rtems_get_current_processor() == 0);
+  rtems_test_assert(rtems_scheduler_get_processor() == 0);
   rtems_test_spin_until_next_tick();
   ticks = cpu_self->Watchdog.ticks;
diff --git a/testsuites/smptests/smpfatal01/init.c b/testsuites/smptests/smpfatal01/init.c
index f20d395697..463f35acbb 100644
--- a/testsuites/smptests/smpfatal01/init.c
+++ b/testsuites/smptests/smpfatal01/init.c
@@ -48,7 +48,7 @@ static void fatal_extension(
   SMP_barrier_State barrier_state = SMP_BARRIER_STATE_INITIALIZER;
   if (source == RTEMS_FATAL_SOURCE_SMP) {
     assert(!always_set_to_false);
     assert(code == SMP_FATAL_SHUTDOWN);
@@ -76,7 +76,7 @@ static rtems_status_code test_driver_init(
   void *arg
   uint32_t cpu;
diff --git a/testsuites/smptests/smpfatal02/init.c b/testsuites/smptests/smpfatal02/init.c
index a16261d1da..217c7a1758 100644
--- a/testsuites/smptests/smpfatal02/init.c
+++ b/testsuites/smptests/smpfatal02/init.c
@@ -46,7 +46,7 @@ static void fatal_extension(
@@ -80,7 +80,7 @@ static rtems_status_code test_driver_init(
   void *arg
   uint32_t cpu;
diff --git a/testsuites/smptests/smpipi01/init.c b/testsuites/smptests/smpipi01/init.c
index 9a995c09bd..3389e85a11 100644
--- a/testsuites/smptests/smpipi01/init.c
+++ b/testsuites/smptests/smpipi01/init.c
@@ -79,7 +79,7 @@ static void test_send_message_while_processing_a_message(
-  uint32_t cpu_index_self = rtems_get_current_processor();
+  uint32_t cpu_index_self = rtems_scheduler_get_processor();
   uint32_t cpu_index;
   SMP_barrier_State *bs = &ctx->main_barrier_state;
@@ -132,7 +132,7 @@ static void test_send_message_flood(
   uint32_t cpu_index;
   _SMP_Set_test_message_handler(counter_handler);
diff --git a/testsuites/smptests/smpmigration01/init.c b/testsuites/smptests/smpmigration01/init.c
index 3f1f7ae262..476a12a0cd 100644
--- a/testsuites/smptests/smpmigration01/init.c
+++ b/testsuites/smptests/smpmigration01/init.c
@@ -72,7 +72,7 @@ static void runner(rtems_task_argument self)
   test_counters *next_counters = &ctx->counters[next];
   while (true) {
-    uint32_t current_cpu = rtems_get_current_processor();
+    uint32_t current_cpu = rtems_scheduler_get_processor();
     ++counters->cycles_per_cpu[current_cpu].counter;
diff --git a/testsuites/smptests/smpmigration02/init.c b/testsuites/smptests/smpmigration02/init.c
index 74088dd95b..e613f5dae9 100644
--- a/testsuites/smptests/smpmigration02/init.c
+++ b/testsuites/smptests/smpmigration02/init.c
@@ -57,7 +57,7 @@ static void migration_task(rtems_task_argument arg)
   uint32_t task_index = arg;
   rtems_task_priority prio = migration_task_prio(task_index);
-  uint32_t cpu_index = rtems_get_current_processor();
+  uint32_t cpu_index = rtems_scheduler_get_processor();
   while (true) {
@@ -73,7 +73,7 @@ static void migration_task(rtems_task_argument arg)
     ++ctx->counters[task_index].value;
-    rtems_test_assert(cpu_index == rtems_get_current_processor());
+    rtems_test_assert(cpu_index == rtems_scheduler_get_processor());
diff --git a/testsuites/smptests/smpmrsp01/init.c b/testsuites/smptests/smpmrsp01/init.c
index 4d4e6350e2..a3e955b30c 100644
--- a/testsuites/smptests/smpmrsp01/init.c
+++ b/testsuites/smptests/smpmrsp01/init.c
@@ -154,7 +154,7 @@ static void switch_extension(Thread_Control *executing, Thread_Control *heir)
     switch_event *e = &ctx->switch_events[i];
     Scheduler_SMP_Node *node = _Scheduler_SMP_Thread_get_node(heir);
-    e->cpu_index = rtems_get_current_processor();
+    e->cpu_index = rtems_scheduler_get_processor();
     e->executing = executing;
     e->heir = heir;
     e->heir_node = _Scheduler_Node_get_owner(&node->Base);
@@ -505,9 +505,9 @@ static void test_mrsp_obtain_and_release(test_context *ctx)
-  while (rtems_get_current_processor() != 0) {
+  while (rtems_scheduler_get_processor() != 0) {
     /* Wait */
@@ -654,7 +654,7 @@ static void test_mrsp_obtain_after_migration(test_context *ctx)
   sc = rtems_task_start(ctx->high_task_id[0], obtain_after_migration_high, 0);
   /* Obtain done (I) */
   _SMP_barrier_State_initialize(&barrier_state);
@@ -663,7 +663,7 @@ static void test_mrsp_obtain_after_migration(test_context *ctx)
   sc = rtems_task_suspend(ctx->high_task_id[0]);
    * Obtain second MrsP semaphore and ensure that we change the priority of our
@@ -675,7 +675,7 @@ static void test_mrsp_obtain_after_migration(test_context *ctx)
   assert_prio(RTEMS_SELF, 1);
   sc = rtems_semaphore_release(ctx->mrsp_ids[2]);
@@ -686,7 +686,7 @@ static void test_mrsp_obtain_after_migration(test_context *ctx)
   /* Ready to release (J) */
   barrier(ctx, &barrier_state);
   /* Prepare barrier for worker */
   barrier_init(ctx);
@@ -695,7 +695,7 @@ static void test_mrsp_obtain_after_migration(test_context *ctx)
   sc = rtems_semaphore_release(ctx->mrsp_ids[0]);
   print_switch_events(ctx);
@@ -1106,7 +1106,7 @@ static void various_block_unblock(test_context *ctx)
   sc = rtems_task_resume(ctx->worker_ids[0]);
   /* Use node of the active rival */
@@ -1116,7 +1116,7 @@ static void various_block_unblock(test_context *ctx)
   sc = rtems_task_resume(ctx->high_task_id[0]);
   sc = rtems_task_suspend(ctx->worker_ids[0]);
@@ -1152,7 +1152,7 @@ static void various_block_unblock(test_context *ctx)
   assert_prio(RTEMS_SELF, 4);
@@ -1409,12 +1409,12 @@ static void test_mrsp_obtain_and_release_with_help(test_context *ctx)
   sc = rtems_task_wake_after(2);
   rtems_test_assert(!run);
   change_prio(run_task_id, 1);
   while (!run) {
     /* Wait */
@@ -1423,11 +1423,11 @@ static void test_mrsp_obtain_and_release_with_help(test_context *ctx)
   change_prio(run_task_id, 4);
    * With this operation the scheduler instance 0 has now only the main and the
@@ -1436,7 +1436,7 @@ static void test_mrsp_obtain_and_release_with_help(test_context *ctx)
   sc = rtems_task_suspend(run_task_id);
   change_prio(RTEMS_SELF, 1);
   change_prio(RTEMS_SELF, 3);
@@ -1444,7 +1444,7 @@ static void test_mrsp_obtain_and_release_with_help(test_context *ctx)
   assert_prio(RTEMS_SELF, 3);
@@ -1494,7 +1494,7 @@ static void load_worker(rtems_task_argument index)
       sc = rtems_task_wake_after(1);
-      ++ctx->counters[index].cpu[rtems_get_current_processor()];
+      ++ctx->counters[index].cpu[rtems_scheduler_get_processor()];
     } else {
       uint32_t n = (v >> 17) % (i + 1);
       uint32_t s;
@@ -1517,7 +1517,7 @@ static void load_worker(rtems_task_argument index)
           break;
         v = simple_random(v);
@@ -1529,7 +1529,7 @@ static void load_worker(rtems_task_argument index)
         sc = rtems_semaphore_release(ctx->mrsp_ids[k]);
@@ -1556,7 +1556,7 @@ static void migration_task(rtems_task_argument arg)
     sc = rtems_task_set_scheduler(RTEMS_SELF, ctx->scheduler_ids[cpu_index], 2);
-    ++ctx->migration_counters[rtems_get_current_processor()];
+    ++ctx->migration_counters[rtems_scheduler_get_processor()];
diff --git a/testsuites/smptests/smpmutex01/init.c b/testsuites/smptests/smpmutex01/init.c
index 09ee496247..fa449aacf2 100644
--- a/testsuites/smptests/smpmutex01/init.c
+++ b/testsuites/smptests/smpmutex01/init.c
@@ -84,7 +84,7 @@ static test_context test_instance;
 static void assert_cpu(uint32_t expected_cpu)
-  rtems_test_assert(rtems_get_current_processor() == expected_cpu);
+  rtems_test_assert(rtems_scheduler_get_processor() == expected_cpu);
 static void test_task_get_priority_not_defined(test_context *ctx)
@@ -226,7 +226,7 @@ static void request(test_context *ctx, task_id id, request_id req)
   send_event(ctx, id, req);
   clear_done(ctx);
-  if (rtems_get_current_processor() == 0) {
+  if (rtems_scheduler_get_processor() == 0) {
     id = H_B;
   } else {
     id = H_A;
diff --git a/testsuites/smptests/smppsxmutex01/init.c b/testsuites/smptests/smppsxmutex01/init.c
index 5ba24baadc..a634c76962 100644
--- a/testsuites/smptests/smppsxmutex01/init.c
+++ b/testsuites/smptests/smppsxmutex01/init.c
@@ -50,7 +50,7 @@ static void *thread_b(void *arg)
   ctx = arg;
   sc = rtems_scheduler_ident(SCHED_B, &scheduler_b_id);
@@ -61,7 +61,7 @@ static void *thread_b(void *arg)
   sc = rtems_task_set_scheduler(pthread_self(), scheduler_b_id, prio);
   eno = pthread_mutex_init(&ctx->mtx_b, &ctx->mtx_attr);
   rtems_test_assert(eno == 0);
@@ -97,7 +97,7 @@ static void test(test_context *ctx)
   eno = pthread_mutexattr_init(&ctx->mtx_attr);
diff --git a/testsuites/smptests/smppsxsignal01/init.c b/testsuites/smptests/smppsxsignal01/init.c
index 695eeb7b80..53ecb54932 100644
--- a/testsuites/smptests/smppsxsignal01/init.c
+++ b/testsuites/smptests/smppsxsignal01/init.c
@@ -82,14 +82,14 @@ static void signal_send(test_context *ctx, test_state new_state)
 static void check_consumer_processor(const test_context *ctx)
   rtems_test_assert(
-    ctx->consumer_processor == rtems_get_current_processor()
+    ctx->consumer_processor == rtems_scheduler_get_processor()
 static void check_producer_processor(const test_context *ctx)
   rtems_test_assert(
-    ctx->producer_processor == rtems_get_current_processor()
+    ctx->producer_processor == rtems_scheduler_get_processor()
@@ -97,7 +97,7 @@ static void *producer(void *arg)
   test_context *ctx = arg;
-  ctx->producer_processor = rtems_get_current_processor();
+  ctx->producer_processor = rtems_scheduler_get_processor();
   rtems_test_assert(ctx->consumer_processor != ctx->producer_processor);
@@ -120,7 +120,7 @@ static void test(void)
   void *producer_status;
   ctx->consumer = pthread_self();
-  ctx->consumer_processor = rtems_get_current_processor();
+  ctx->consumer_processor = rtems_scheduler_get_processor();
   memset(&new_action, 0, sizeof(new_action));
   new_action.sa_handler = signal_handler;
diff --git a/testsuites/smptests/smpschedaffinity01/init.c b/testsuites/smptests/smpschedaffinity01/init.c
index 770830f53e..c5a9ed5098 100644
--- a/testsuites/smptests/smpschedaffinity01/init.c
+++ b/testsuites/smptests/smpschedaffinity01/init.c
@@ -66,7 +66,7 @@ static void task(rtems_task_argument arg)
   uint32_t cpu;
   cpu_set_t cpuset;
-  cpu = rtems_get_current_processor();
+  cpu = rtems_scheduler_get_processor();
   rtems_task_get_affinity( rtems_task_self(), sizeof(cpuset), &cpuset );
diff --git a/testsuites/smptests/smpschedaffinity02/init.c b/testsuites/smptests/smpschedaffinity02/init.c
index d4a0416be0..d8d2c23172 100644
--- a/testsuites/smptests/smpschedaffinity02/init.c
+++ b/testsuites/smptests/smpschedaffinity02/init.c
@@ -99,7 +99,7 @@ static void init_verify( int expect )
   test_delay(20);
   printf( "Init: expected=%d actual=%d\n", expect, cpu);
   rtems_test_assert( expect == cpu );
@@ -112,7 +112,7 @@ static void task(rtems_task_argument arg)
   while (true) {
-      task_data.actual_cpu = rtems_get_current_processor();
+      task_data.actual_cpu = rtems_scheduler_get_processor();
       task_data.ran = true;
       test_delay(25);
diff --git a/testsuites/smptests/smpschedaffinity03/init.c b/testsuites/smptests/smpschedaffinity03/init.c
index 629fa5d3f1..5f63d5ff80 100644
--- a/testsuites/smptests/smpschedaffinity03/init.c
+++ b/testsuites/smptests/smpschedaffinity03/init.c
@@ -64,7 +64,7 @@ static void test(void)
     test_delay(100);
     /* Check the cpu the Init task is running on */
     printf("On cpu %d\n", cpu);
     rtems_test_assert(cpu == i);
diff --git a/testsuites/smptests/smpschedaffinity04/init.c b/testsuites/smptests/smpschedaffinity04/init.c
index e526746f8a..329b5a78c4 100644
--- a/testsuites/smptests/smpschedaffinity04/init.c
+++ b/testsuites/smptests/smpschedaffinity04/init.c
@@ -60,7 +60,7 @@ static void task(rtems_task_argument arg)
@@ -115,7 +115,7 @@ static void test(void)
    * Verify the Init task is running on the max core.
   printf("Verify Init task is on cpu %" PRIu32 "\n",cpu_count-1);
   rtems_test_assert(cpu == (cpu_count-1));
   /* Walk TA1 across all of the cores */
diff --git a/testsuites/smptests/smpschedaffinity05/init.c b/testsuites/smptests/smpschedaffinity05/init.c
index 632cbef1dc..822bdddae6 100644
--- a/testsuites/smptests/smpschedaffinity05/init.c
+++ b/testsuites/smptests/smpschedaffinity05/init.c
@@ -77,7 +77,7 @@ static void task(rtems_task_argument arg)
@@ -92,7 +92,7 @@ static void verify_tasks(void)
   /* Verify all tasks */
   for (i = 0; i < NUM_CPUS; i++) {
diff --git a/testsuites/smptests/smpscheduler02/init.c b/testsuites/smptests/smpscheduler02/init.c
index 69d6d24f1a..1a88c6e4d4 100644
--- a/testsuites/smptests/smpscheduler02/init.c
+++ b/testsuites/smptests/smpscheduler02/init.c
@@ -46,7 +46,7 @@ static void task(rtems_task_argument arg)
   (void) arg;
   rtems_test_assert(sched_get_priority_min(SCHED_RR) == 1);
   rtems_test_assert(sched_get_priority_max(SCHED_RR) == INT_MAX - 1);
@@ -77,7 +77,7 @@ static void sticky_task(rtems_task_argument arg)
   (void) arg;
   sc = rtems_semaphore_create(
     rtems_build_name(' ', 'M', 'T', 'X'),
@@ -149,12 +149,12 @@ static void test_scheduler_add_remove_processors(void)
     sc = rtems_scheduler_add_processor(scheduler_a_id, 1);
     sc = rtems_scheduler_remove_processor(scheduler_a_id, 0);
     CPU_ZERO(&first_cpu);
     CPU_SET(0, &first_cpu);
@@ -168,7 +168,7 @@ static void test_scheduler_add_remove_processors(void)
     sc = rtems_scheduler_add_processor(scheduler_a_id, 0);
     sc = rtems_task_create(
       rtems_build_name('T', 'A', 'S', 'K'),
@@ -190,7 +190,7 @@ static void test_scheduler_add_remove_processors(void)
     sc = rtems_scheduler_remove_processor(scheduler_a_id, 1);
     sc = rtems_event_transient_send(task_id);
@@ -222,7 +222,7 @@ static void test(void)
   cpu_set_t online_cpus;
   uint32_t cpu_count;
   main_task_id = rtems_task_self();
diff --git a/testsuites/smptests/smpscheduler04/init.c b/testsuites/smptests/smpscheduler04/init.c
index b4bb4ebcda..d79bcd8775 100644
--- a/testsuites/smptests/smpscheduler04/init.c
+++ b/testsuites/smptests/smpscheduler04/init.c
@@ -47,7 +47,7 @@ static void migration_task(rtems_task_argument arg)
   test_context *ctx = (test_context *) arg;
   while (true) {
@@ -65,7 +65,7 @@ static void migration_task(rtems_task_argument arg)
     ++ctx->migration_counter;
@@ -74,7 +74,7 @@ static void scheduler_task(rtems_task_argument arg)
   while (true) {
diff --git a/testsuites/smptests/smpsignal01/init.c b/testsuites/smptests/smpsignal01/init.c
index 966b68ff93..37c07a69af 100644
--- a/testsuites/smptests/smpsignal01/init.c
+++ b/testsuites/smptests/smpsignal01/init.c
@@ -90,14 +90,14 @@ static void signal_send(test_context *ctx, test_state new_state)
   rtems_test_assert(
   rtems_test_assert(
@@ -105,7 +105,7 @@ static void producer(rtems_task_argument arg)
@@ -220,7 +220,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
   ctx->consumer = rtems_task_self();
   test_isr_level(ctx);
diff --git a/testsuites/smptests/smpthreadpin01/init.c b/testsuites/smptests/smpthreadpin01/init.c
index 66a8e33054..3b6060adaf 100644
--- a/testsuites/smptests/smpthreadpin01/init.c
+++ b/testsuites/smptests/smpthreadpin01/init.c
@@ -286,18 +286,18 @@ static void test_simple_pin_unpin(test_context *ctx, int run)
   set_affinity(ctx->busy, 0);
   set_prio(ctx->busy, PRIO_IDLE);
   set_prio(RTEMS_SELF, PRIO_MIDDLE);
   cpu_self = _Thread_Dispatch_disable();
   executing = _Per_CPU_Get_executing(cpu_self);
   _Thread_Pin(executing);
   _Thread_Unpin(executing, cpu_self);
   _Thread_Dispatch_enable(cpu_self);
 static void test_pin_wait_unpin(test_context *ctx, bool blocked, int run)
@@ -309,20 +309,20 @@ static void test_pin_wait_unpin(test_context *ctx, bool blocked, int run)
   set_prio(ctx->event, PRIO_LOW);
   set_affinity(ctx->event, 1);
   pin(blocked);
   send_events(ctx->event, EVENT_WAKEUP_MASTER);
   wait_for_events();
   set_prio(ctx->busy, PRIO_HIGH);
   unpin(blocked);
 static void test_pin_preempt_unpin(test_context *ctx, bool blocked, int run)
@@ -338,10 +338,10 @@ static void test_pin_preempt_unpin(test_context *ctx, bool blocked, int run)
   set_affinity(ctx->event, 0);
   pin(blocked);
   ctx->flag = false;
   send_events(
@@ -351,12 +351,12 @@ static void test_pin_preempt_unpin(test_context *ctx, bool blocked, int run)
   while (!ctx->flag) {
   unpin(blocked);
 static void test_pin_home_no_help_unpin(
@@ -376,16 +376,16 @@ static void test_pin_home_no_help_unpin(
   set_affinity(ctx->busy, 1);
   pin(blocked);
   sc = rtems_task_set_scheduler(RTEMS_SELF, ctx->sched_b, 1);
   rtems_test_assert(sc == RTEMS_RESOURCE_IN_USE);
   rtems_mutex_lock(&ctx->mtx);
   set_prio(ctx->event, PRIO_MIDDLE);
@@ -398,7 +398,7 @@ static void test_pin_home_no_help_unpin(
   /* Now the event task can help us */
   rtems_test_assert(ctx->mtx._Queue._heads != NULL);
   set_affinity(ctx->event_2, 0);
@@ -409,17 +409,17 @@ static void test_pin_home_no_help_unpin(
       | EVENT_SET_SELF_PRIO_TO_LOW | EVENT_SET_BUSY_PRIO_TO_IDLE
   set_prio(ctx->event_2, PRIO_VERY_HIGH);
   rtems_mutex_unlock(&ctx->mtx);
   send_events(ctx->event, EVENT_WAKEUP_MASTER | EVENT_MTX_UNLOCK);
   wait_for_events();
   unpin(blocked);
 static void test_pin_foreign_no_help_unpin(
@@ -437,10 +437,10 @@ static void test_pin_foreign_no_help_unpin(
@@ -452,16 +452,16 @@ static void test_pin_foreign_no_help_unpin(
   /* Request help */
   /* Pin while using foreign scheduler */
   pin(blocked);
   set_affinity(ctx->event_2, 1);
   send_events(
@@ -470,18 +470,18 @@ static void test_pin_foreign_no_help_unpin(
   unpin(blocked);
   wait_for_events();
@@ -514,7 +514,7 @@ static void test(test_context *ctx)
     rtems_build_name('E', 'V', 'T', '1'),
diff --git a/testsuites/tmtests/tmcontext01/init.c b/testsuites/tmtests/tmcontext01/init.c
index 4b3c9d8c8a..849bfba04d 100644
--- a/testsuites/tmtests/tmcontext01/init.c
+++ b/testsuites/tmtests/tmcontext01/init.c
@@ -116,7 +116,7 @@ static void load_task(rtems_task_argument arg)
   volatile int *load_data = (volatile int *) arg;
   size_t n = data_size;
   size_t clsz = cache_line_size;
-  int j = (int) rtems_get_current_processor();
+  int j = (int) rtems_scheduler_get_processor();
   while (true) {
     j = dirty_data_cache(load_data, n, clsz, j);
2.16.4
