[PATCH 1/2] c-user: Document rtems_scheduler_get_processor()
Fri Apr 5 07:15:21 UTC 2019
Close #3731.
 c-user/scheduling_concepts.rst                | 31 ++++++++++++++++++++++++
 c-user/symmetric_multiprocessing_services.rst | 35 ---------------------------
 2 files changed, 31 insertions(+), 35 deletions(-)
diff --git a/c-user/scheduling_concepts.rst b/c-user/scheduling_concepts.rst
index db90ed1..ad955f8 100644
--- a/c-user/scheduling_concepts.rst
+++ b/c-user/scheduling_concepts.rst
@@ -37,6 +37,8 @@ The directives provided by the scheduler manager are:
 - rtems_scheduler_get_maximum_priority_ - Get maximum task priority of a scheduler
+- rtems_scheduler_get_processor_ - Get current processor index
 - rtems_scheduler_get_processor_set_ - Get processor set of a scheduler
 - rtems_scheduler_add_processor_ - Add processor to a scheduler
@@ -697,6 +699,35 @@ NOTES:
    \clearpage
+.. _rtems_scheduler_get_processor:
+SCHEDULER_GET_PROCESSOR - Get current processor index
+CALLING SEQUENCE:
+    .. code-block:: c
+        uint32_t rtems_scheduler_get_processor( void );
+DIRECTIVE STATUS CODES:
+    This directive returns the index of the current processor.
+DESCRIPTION:
+    In uniprocessor configurations, a value of zero will be returned.
+    In SMP configurations, an architecture specific method is used to obtain the
+    index of the current processor in the system.  The set of processor indices
+    is the range of integers starting with zero up to the processor count minus
+    one.
+    Outside of sections with disabled thread dispatching the current processor
+    index may change after every instruction since the thread may migrate from
+    one processor to another.  Sections with disabled interrupts are sections
+    with thread dispatching disabled.
+NOTES:
+    None.
 .. _rtems_scheduler_get_processor_set:
 SCHEDULER_GET_PROCESSOR_SET - Get processor set of a scheduler
diff --git a/c-user/symmetric_multiprocessing_services.rst b/c-user/symmetric_multiprocessing_services.rst
index e04adb3..aef4397 100644
--- a/c-user/symmetric_multiprocessing_services.rst
+++ b/c-user/symmetric_multiprocessing_services.rst
@@ -39,8 +39,6 @@ The directives provided by the SMP support are:
 - rtems_get_processor_count_ - Get processor count
-- rtems_get_current_processor_ - Get current processor index
 Background
@@ -540,39 +538,6 @@ DESCRIPTION:
 NOTES:
     None.
-.. raw:: latex
-   \clearpage
-.. _rtems_get_current_processor:
-GET_CURRENT_PROCESSOR - Get current processor index
-CALLING SEQUENCE:
-    .. code-block:: c
-        uint32_t rtems_get_current_processor(void);
-DIRECTIVE STATUS CODES:
-    The index of the current processor.
-DESCRIPTION:
-    In uniprocessor configurations, a value of zero will be returned.
-    In SMP configurations, an architecture specific method is used to obtain the
-    index of the current processor in the system.  The set of processor indices
-    is the range of integers starting with zero up to the processor count minus
-    one.
-    Outside of sections with disabled thread dispatching the current processor
-    index may change after every instruction since the thread may migrate from
-    one processor to another.  Sections with disabled interrupts are sections
-    with thread dispatching disabled.
-NOTES:
-    None.
 Implementation Details
2.16.4
