Doxygen @param and [in], [out] or [in,out]?
Sebastian Huber
Fri Apr 5 07:44:28 UTC 2019
On 13/03/2019 07:55, Sebastian Huber wrote:
> On 28/02/2019 15:52, Sebastian Huber wrote:
>> Hello,
>> we agreed to use @param for function parameter documentation:
>> https://docs.rtems.org/branches/master/eng/coding-doxygen.html#doxygen-best-practices
>> Do we want to use [in], [out] or [in,out] as well?
>> If yes, how are [in], [out] or [in,out] used exactly? For example
>> consider values passed by reference. Is in
>> void f(int *a)
>> if (*a == 0) {
>> *a = 1;
>> the parameter a an [in,out] parameter? What about
>> void g(int *a)
>> *a = 1;
>> How can we ensure that this extra information is consistent
>> throughout the documentation?
>> I think we should remove all the [in], [out] or [in,out] stuff. From
>> the parameter type it is quite obvious how they are used, e.g. "type
>> *param" vs. "const type *param". For passed by value it is clear that
>> they are input parameters. Output only use is normally indicated by
>> the function name, e.g. "initialize", "set", "create", etc.
> In ticket
> http://devel.rtems.org/ticket/3721
> Jens Schweikhardt proposed the following:
> "1) only pointer parameters are annotated (since scalars are [in] by
> language definition)
> 2) [in] indicates that the pointer must point to an initialized object
> (it
> may be dereferenced by the directive)
> 3) [out] indicates that the object pointed to may be written by the
> directive
> 4) [inout] If both 2) and 3) apply."
> I think these are good guidelines. What about annotation of const
> pointers? Should they get the [in] annotation which is somewhat
> redundant?
I updated the Doxygen guildelines:
What is currently not covered is the situation in which a function
assigns or returns a non-const pointer. For example:
RTEMS_INLINE_ROUTINE Chain_Node *_Chain_Head(
Chain_Control *the_chain
return &the_chain->Head.Node;
typedef struct {
Chain_Node *position;
} Chain_Iterator;
RTEMS_INLINE_ROUTINE void _Chain_Iterator_registry_update(
Chain_Iterator_registry *the_registry,
Chain_Node *the_node_to_extract
Chain_Node *iter_node;
Chain_Node *iter_tail;
iter_node = _Chain_Head( &the_registry->Iterators );
iter_tail = _Chain_Tail( &the_registry->Iterators );
while ( ( iter_node = _Chain_Next( iter_node ) ) != iter_tail ) {
Chain_Iterator *iter;
iter = (Chain_Iterator *) iter_node;
if ( iter->position == the_node_to_extract ) {
if ( iter->direction == CHAIN_ITERATOR_FORWARD ) {
iter->position = _Chain_Previous( the_node_to_extract );
} else {
iter->position = _Chain_Next( the_node_to_extract );
The referenced object is not read or modified by the function itself.
What should we do in terms of [out] and [in, out] specifiers here?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
