[PATCH] Remove superfluous run-time check
Mon Apr 8 05:02:50 UTC 2019
On 05/04/2019 16:40, Joel Sherrill wrote:
> Are you sure it can't be NULL when POSIX is disabled? The historical
> case where it was NULL was when you disabled an API.
It cannot be NULL:
Objects_Information ** const
_Objects_Information_table[ OBJECTS_APIS_LAST + 1 ] = {
   NULL,
   &_Internal_Objects[ 0 ],
   &_RTEMS_Objects[ 0 ],
   &_POSIX_Objects[ 0 ]
> If it truly can't be NULL now, it would be good to see comments that
> explain why it can't be NULL.
I added an _Assert() to check this. I am not sure if comments that would
refer to another module are that helpful since the other module may
change and the comment not.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
