[PATCHv2 1/2] bsps/riscv: UART - Read reg-shift from DTB to properly set/get registers
Hesham Almatary
Hesham.Almatary at cl.cam.ac.uk
Mon Apr 8 12:44:31 UTC 2019
bsps/riscv/riscv/console/console-config.c | 15 +++++++++++++--
1 file changed, 13 insertions(+), 2 deletions(-)
diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
index 464b4b0e26..04d0b28361 100644
--- a/bsps/riscv/riscv/console/console-config.c
+++ b/bsps/riscv/riscv/console/console-config.c
@@ -145,12 +145,19 @@ static void riscv_console_probe(void)
ns16550_context *ctx;
fdt32_t *val;
int len;
+ int reg_shift = 0;
ctx = &ns16550_instances[ns16550_devices];
ctx->initial_baud = BSP_CONSOLE_BAUD;
- if (RISCV_CONSOLE_IS_COMPATIBLE(compat, compat_len, "ns16750")) {
- ctx->has_precision_clock_synthesizer = true;
+ // Get register shift property of the UART device
+ val = (fdt32_t *) fdt_getprop(fdt, node, "reg-shift", &len);
+ if (val) {
+ reg_shift = fdt32_to_cpu(val[0]);
+ if (reg_shift == 2) {
ctx->get_reg = riscv_console_get_reg_32;
ctx->set_reg = riscv_console_set_reg_32;
} else {
@@ -158,6 +165,10 @@ static void riscv_console_probe(void)
ctx->set_reg = riscv_console_set_reg_8;
+ if (RISCV_CONSOLE_IS_COMPATIBLE(compat, compat_len, "ns16750")) {
+ ctx->has_precision_clock_synthesizer = true;
ctx->port = (uintptr_t) riscv_fdt_get_address(fdt, node);
if (ctx->port == 0) {
2.17.1
