[PATCH 0/4] Xilinx Zynq UltraScale+ MPSoC BSP
Jeff Kubascik Jeff.Kubascik at dornerworks.com
Mon Apr 8 13:36:34 UTC 2019
On 4/8/2019 1:20 AM, Sebastian Huber wrote:
> On 06/04/2019 02:53, Jeff Kubascik wrote:
>> From: Jeff Kubascik <jeff.kubascik at dornerworks.com>
>> This set of patches creates a new BSP layer for the Xilinx Zynq UltraScale+
>> MPSoC.
>> The first two patches move the zynq-uart driver into a common directory, so that
>> both the xilinx-zynq and xilinx-zynqmp BSPs can use it.
>> The third patch copies the xilinx-zynq BSP layer to xilinx-zynqmp, to use as a
>> starting point.
>> The fourth patch modifies the xilinx-zynqmp BSP layer as needed to work for the
>> Ultra96 board, which is based on the MPSoC. Only AArch32 mode is currently
>> supported.
> The patch set looks good. Should we change the license of the original
> Zynq BSP to BSD-2-Clause before this change? Currently, the new BSP
> under the old RTEMS license.
We would prefer the BSD 2-Clause license. Since the new xilinx-zynqmp BSP is
derived from the xilinx-zynq BSP, I take it that we have permission to change
the license clause?
-Jeff Kubascik
