rtems-libbsd build error
Mon Apr 8 23:59:07 UTC 2019
On 8/4/19 12:30 am, Vijay Kumar Banerjee wrote:
> On Sun, Apr 7, 2019 at 6:24 PM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     Am 07.04.19 um 14:50 schrieb Vijay Kumar Banerjee:
>     > On Sun, Apr 7, 2019 at 6:08 PM Christian Mauderer <list at c-mauderer.de
>     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>     >     Am 07.04.19 um 14:35 schrieb Vijay Kumar Banerjee:
>     >     > On Sun, Apr 7, 2019 at 5:37 PM Christian Mauderer
>     >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>     >     >     Am 07.04.19 um 13:08 schrieb Vijay Kumar Banerjee:
>     I don't think that there are a lot of docs for how to test. Although I'm
>     sure that there are some scripts to run a number of libbsd tests, I'm
>     not sure where. Maybe in the RTEMS tester but I think that is mainly for
>     the core tests?
The documentation for testing can be found here ...
 https://docs.rtems.org/branches/master/user/testing/index.html
> so far I know, RTEMS Tester is only for core tests.
The `rtems-test` command checks the for test start and end banners. I am not
sure if libbsd supports the test banners. Maybe it could now with Sebastian's
movement of the test support code into libtest.
> I'll ask in the devel if there's some way to run libbsd test with the tester.
There is the `rtems-run` command which has similar args to `rtems-test`. It does
suffer from a limitation I have not fixed which is stdin is not passed through
to the console of the target. I also think the command has a timeout running,
but I am not sure about this one.
