[PATCH] bsp/xilinx-zynq: Relicense to BSD-2-Clause
Sebastian Huber
Tue Apr 9 05:31:52 UTC 2019
Relicense contributions from Chris Johns, Christian Mauderer, embedded
brains GmbH, Joel Sherrill, Ralf Kirchner, and Sebastian Huber.
Update #3053.
bsps/arm/xilinx-zynq/console/console-config.c | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/console/debug-console.c | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/console/zynq-uart.c | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/i2c/cadence-i2c.c | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/include/bsp.h | 31 +++++++++++++++-------
.../arm/xilinx-zynq/include/bsp/cadence-i2c-regs.h | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/include/bsp/cadence-i2c.h | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/include/bsp/i2c.h | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/include/bsp/irq.h | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/include/bsp/zynq-uart-regs.h | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/include/bsp/zynq-uart.h | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/include/tm27.h | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/start/bspreset.c | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/start/bspsmp.c | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/start/bspstart.c | 31 +++++++++++++++-------
bsps/arm/xilinx-zynq/start/bspstartmmu.c | 31 +++++++++++++++-------
16 files changed, 352 insertions(+), 144 deletions(-)
diff --git a/bsps/arm/xilinx-zynq/console/console-config.c b/bsps/arm/xilinx-zynq/console/console-config.c
index ce7da2f114..6ab9e1e015 100644
--- a/bsps/arm/xilinx-zynq/console/console-config.c
+++ b/bsps/arm/xilinx-zynq/console/console-config.c
@@ -1,15 +1,28 @@
- * Copyright (c) 2013, 2017 embedded brains GmbH. All rights reserved.
+ * SPDX-License-Identifier: BSD-2-Clause
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <info at embedded-brains.de>
+ * Copyright (C) 2013, 2017 embedded brains GmbH
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#include <rtems/console.h>
diff --git a/bsps/arm/xilinx-zynq/console/debug-console.c b/bsps/arm/xilinx-zynq/console/debug-console.c
index 38c0050e90..8930b4fda4 100644
--- a/bsps/arm/xilinx-zynq/console/debug-console.c
+++ b/bsps/arm/xilinx-zynq/console/debug-console.c
@@ -1,15 +1,28 @@
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
+ * are met:
#include <rtems/bspIo.h>
diff --git a/bsps/arm/xilinx-zynq/console/zynq-uart.c b/bsps/arm/xilinx-zynq/console/zynq-uart.c
index fa91f3f46e..92a8c86009 100644
--- a/bsps/arm/xilinx-zynq/console/zynq-uart.c
+++ b/bsps/arm/xilinx-zynq/console/zynq-uart.c
@@ -1,15 +1,28 @@
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * are met:
#include <bsp/zynq-uart.h>
diff --git a/bsps/arm/xilinx-zynq/i2c/cadence-i2c.c b/bsps/arm/xilinx-zynq/i2c/cadence-i2c.c
index 76211da496..07379992ce 100644
--- a/bsps/arm/xilinx-zynq/i2c/cadence-i2c.c
+++ b/bsps/arm/xilinx-zynq/i2c/cadence-i2c.c
@@ -1,15 +1,28 @@
- * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * Copyright (C) 2014 embedded brains GmbH
+ * are met:
#include <bsp/cadence-i2c.h>
diff --git a/bsps/arm/xilinx-zynq/include/bsp.h b/bsps/arm/xilinx-zynq/include/bsp.h
index 43568980be..111bacc8ab 100644
--- a/bsps/arm/xilinx-zynq/include/bsp.h
+++ b/bsps/arm/xilinx-zynq/include/bsp.h
@@ -5,17 +5,30 @@
- * Copyright (c) 2013-2014 embedded brains GmbH. All rights reserved.
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * Copyright (C) 2013, 2014 embedded brains GmbH
+ * are met:
#ifndef LIBBSP_ARM_XILINX_ZYNQ_BSP_H
diff --git a/bsps/arm/xilinx-zynq/include/bsp/cadence-i2c-regs.h b/bsps/arm/xilinx-zynq/include/bsp/cadence-i2c-regs.h
index c06a47c7f1..7d7c3b284a 100644
--- a/bsps/arm/xilinx-zynq/include/bsp/cadence-i2c-regs.h
+++ b/bsps/arm/xilinx-zynq/include/bsp/cadence-i2c-regs.h
@@ -1,15 +1,28 @@
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * are met:
#ifndef LIBBSP_ARM_XILINX_ZYNQ_CADENCE_I2C_REGS_H
diff --git a/bsps/arm/xilinx-zynq/include/bsp/cadence-i2c.h b/bsps/arm/xilinx-zynq/include/bsp/cadence-i2c.h
index 9697cf3354..aff97237a4 100644
--- a/bsps/arm/xilinx-zynq/include/bsp/cadence-i2c.h
+++ b/bsps/arm/xilinx-zynq/include/bsp/cadence-i2c.h
@@ -1,15 +1,28 @@
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * are met:
#ifndef LIBBSP_ARM_XILINX_ZYNQ_CADENCE_I2C_H
diff --git a/bsps/arm/xilinx-zynq/include/bsp/i2c.h b/bsps/arm/xilinx-zynq/include/bsp/i2c.h
index 709ea0178e..fbdf6ea2c0 100644
--- a/bsps/arm/xilinx-zynq/include/bsp/i2c.h
+++ b/bsps/arm/xilinx-zynq/include/bsp/i2c.h
@@ -1,15 +1,28 @@
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * are met:
#ifndef LIBBSP_ARM_XILINX_ZYNQ_I2C_H
diff --git a/bsps/arm/xilinx-zynq/include/bsp/irq.h b/bsps/arm/xilinx-zynq/include/bsp/irq.h
index d8020ca9f6..edea29b7df 100644
--- a/bsps/arm/xilinx-zynq/include/bsp/irq.h
+++ b/bsps/arm/xilinx-zynq/include/bsp/irq.h
@@ -5,17 +5,30 @@
- * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * Copyright (C) 2013 embedded brains GmbH
+ * are met:
#ifndef LIBBSP_ARM_XILINX_ZYNQ_IRQ_H
diff --git a/bsps/arm/xilinx-zynq/include/bsp/zynq-uart-regs.h b/bsps/arm/xilinx-zynq/include/bsp/zynq-uart-regs.h
index 127f272fd9..8b6e7d513b 100644
--- a/bsps/arm/xilinx-zynq/include/bsp/zynq-uart-regs.h
+++ b/bsps/arm/xilinx-zynq/include/bsp/zynq-uart-regs.h
@@ -5,17 +5,30 @@
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * are met:
diff --git a/bsps/arm/xilinx-zynq/include/bsp/zynq-uart.h b/bsps/arm/xilinx-zynq/include/bsp/zynq-uart.h
index 76a0723f57..3aabdca65d 100644
--- a/bsps/arm/xilinx-zynq/include/bsp/zynq-uart.h
+++ b/bsps/arm/xilinx-zynq/include/bsp/zynq-uart.h
@@ -5,17 +5,30 @@
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * Copyright (C) 2013, XXX embedded brains GmbH
+ * are met:
#ifndef LIBBSP_ARM_XILINX_ZYNQ_UART_H
diff --git a/bsps/arm/xilinx-zynq/include/tm27.h b/bsps/arm/xilinx-zynq/include/tm27.h
index cf4f18a722..885b97a30c 100644
--- a/bsps/arm/xilinx-zynq/include/tm27.h
+++ b/bsps/arm/xilinx-zynq/include/tm27.h
@@ -5,17 +5,30 @@
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * are met:
#ifndef _RTEMS_TMTEST27
diff --git a/bsps/arm/xilinx-zynq/start/bspreset.c b/bsps/arm/xilinx-zynq/start/bspreset.c
index b57354c9e2..e0c81ca2ef 100644
--- a/bsps/arm/xilinx-zynq/start/bspreset.c
+++ b/bsps/arm/xilinx-zynq/start/bspreset.c
@@ -1,15 +1,28 @@
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * are met:
#include <bsp.h>
diff --git a/bsps/arm/xilinx-zynq/start/bspsmp.c b/bsps/arm/xilinx-zynq/start/bspsmp.c
index b516823243..fdb7f85ba6 100644
--- a/bsps/arm/xilinx-zynq/start/bspsmp.c
+++ b/bsps/arm/xilinx-zynq/start/bspsmp.c
@@ -1,15 +1,28 @@
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * are met:
#include <rtems/score/smpimpl.h>
diff --git a/bsps/arm/xilinx-zynq/start/bspstart.c b/bsps/arm/xilinx-zynq/start/bspstart.c
index 4e975e872b..68b0ef0b03 100644
--- a/bsps/arm/xilinx-zynq/start/bspstart.c
+++ b/bsps/arm/xilinx-zynq/start/bspstart.c
@@ -1,15 +1,28 @@
- * Copyright (c) 2013-2015 embedded brains GmbH. All rights reserved.
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * Copyright (C) 2013, 2015 embedded brains GmbH
+ * are met:
#include <bsp.h>
diff --git a/bsps/arm/xilinx-zynq/start/bspstartmmu.c b/bsps/arm/xilinx-zynq/start/bspstartmmu.c
index e0a7743e57..c18f8623f7 100644
--- a/bsps/arm/xilinx-zynq/start/bspstartmmu.c
+++ b/bsps/arm/xilinx-zynq/start/bspstartmmu.c
@@ -1,15 +1,28 @@
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * are met:
#define ARM_CP15_TEXT_SECTION BSP_START_TEXT_SECTION
2.16.4
