[PATCH 1/5] config: Obsolete Go configuration options
Sebastian Huber
Tue Apr 9 07:10:44 UTC 2019
Update #2832.
cpukit/include/rtems/confdefs.h | 59 +++++++++--------------------------------
1 file changed, 13 insertions(+), 46 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 89b47050d6..64e7458384 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2369,38 +2369,6 @@ struct _reent *__getreent(void)
#endif
/**@}*/ /* end of GNAT Configuration */
- * @defgroup ConfigurationGo GCC Go Configuration
- * @addtogroup Configuration
- * This modules includes configuration parameters for applications which
- * use GCC Go.
-#ifdef CONFIGURE_ENABLE_GO
- #ifndef CONFIGURE_MAXIMUM_POSIX_THREADS
- #define CONFIGURE_MAXIMUM_POSIX_THREADS 1
- #endif
- #ifndef CONFIGURE_MAXIMUM_GOROUTINES
- #define CONFIGURE_MAXIMUM_GOROUTINES 400
- #endif
- #ifndef CONFIGURE_MAXIMUM_GO_CHANNELS
- #define CONFIGURE_MAXIMUM_GO_CHANNELS 500
- #endif
-#else
- /** This specifies the maximum number of Go co-routines. */
- #define CONFIGURE_MAXIMUM_GOROUTINES 0
- /** This specifies the maximum number of Go channels required. */
- #define CONFIGURE_MAXIMUM_GO_CHANNELS 0
-#endif
-/**@}*/ /* end of Go Configuration */
* This is so we can account for tasks with stacks greater than minimum
* size. This is in bytes.
@@ -2414,8 +2382,7 @@ struct _reent *__getreent(void)
#define _CONFIGURE_POSIX_THREADS \
(CONFIGURE_MAXIMUM_POSIX_THREADS + \
- CONFIGURE_MAXIMUM_ADA_TASKS + \
- CONFIGURE_MAXIMUM_GOROUTINES)
+ CONFIGURE_MAXIMUM_ADA_TASKS)
* We must be able to split the free block used for the second last allocation
@@ -2632,14 +2599,6 @@ struct _reent *__getreent(void)
(_Configure_Max_Objects( CONFIGURE_MAXIMUM_ADA_TASKS ) * \
_Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) )
- * This macro is calculated to specify the memory required for
- * the stacks of all Go routines.
-#define _CONFIGURE_GOROUTINES_STACK \
- (_Configure_Max_Objects( CONFIGURE_MAXIMUM_GOROUTINES ) * \
- _Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) )
#else /* CONFIGURE_EXECUTIVE_RAM_SIZE */
#define _CONFIGURE_IDLE_TASKS_STACK 0
@@ -2647,7 +2606,6 @@ struct _reent *__getreent(void)
#define _CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS 0
#define _CONFIGURE_TASKS_STACK 0
#define _CONFIGURE_POSIX_THREADS_STACK 0
-#define _CONFIGURE_GOROUTINES_STACK 0
#define _CONFIGURE_ADA_TASKS_STACK 0
#if CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK != 0
@@ -2671,7 +2629,6 @@ struct _reent *__getreent(void)
_CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS + \
_CONFIGURE_TASKS_STACK + \
_CONFIGURE_POSIX_THREADS_STACK + \
- _CONFIGURE_GOROUTINES_STACK + \
_CONFIGURE_ADA_TASKS_STACK + \
CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK + \
_CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS + \
@@ -3115,8 +3072,7 @@ struct _reent *__getreent(void)
#if !defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION)
#if (CONFIGURE_MAXIMUM_TASKS == 0) && \
(CONFIGURE_MAXIMUM_POSIX_THREADS == 0) && \
- (CONFIGURE_MAXIMUM_ADA_TASKS == 0) && \
- (CONFIGURE_MAXIMUM_GOROUTINES == 0)
+ (CONFIGURE_MAXIMUM_ADA_TASKS == 0)
#error "CONFIGURATION ERROR: No tasks or threads configured!!"
#endif
#endif
@@ -3272,6 +3228,17 @@ struct _reent *__getreent(void)
#error "IMFS Memfile block size must be a power of 2 between 16 and 512"
#endif
+#ifdef CONFIGURE_ENABLE_GO
+ #warning "The CONFIGURE_ENABLE_GO configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_GOROUTINES
+ #warning "The CONFIGURE_MAXIMUM_GOROUTINES configuration option is obsolete since RTEMS 5.1"
+#endif
+#ifdef CONFIGURE_MAXIMUM_GO_CHANNELS
+ #warning "The CONFIGURE_MAXIMUM_GO_CHANNELS configuration option is obsolete since RTEMS 5.1"
+#endif
#endif
/* end of include file */
2.16.4
