[PATCH] c-user: Obsolete Go configuration options
Tue Apr 9 07:11:06 UTC 2019
Update #2832.
 c-user/configuring_a_system.rst | 102 +++++++++-------------------------------
 1 file changed, 21 insertions(+), 81 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 0384d06..c7a8808 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -4873,87 +4873,6 @@ NOTES:
     The record extensions capture thread create, start, restart, delete,
     switch, begin, exitted and terminate events.
-Go Tasks
-.. index:: CONFIGURE_ENABLE_GO
-.. _CONFIGURE_ENABLE_GO:
-CONFIGURE_ENABLE_GO
-CONSTANT:
-    ``CONFIGURE_ENABLE_GO``
-DATA TYPE:
-    Boolean feature macro.
-RANGE:
-    Defined or undefined.
-DEFAULT VALUE:
-    This is not defined by default.
-DESCRIPTION:
-    ``CONFIGURE_ENABLE_GO`` is defined to inform RTEMS that the Go run-time is
-    to be used by the application.
-NOTES:
-    The Go language support is experimental
-.. index:: CONFIGURE_MAXIMUM_GOROUTINES
-.. _CONFIGURE_MAXIMUM_GOROUTINES:
-CONFIGURE_MAXIMUM_GOROUTINES
-CONSTANT:
-    ``CONFIGURE_MAXIMUM_GOROUTINES``
-DATA TYPE:
-    Unsigned integer (``uint32_t``).
-RANGE:
-    Zero or positive.
-DEFAULT VALUE:
-    The default value is 400
-DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_GOROUTINES`` is defined to specify the maximum number
-    of Go routines.
-NOTES:
-.. index:: CONFIGURE_MAXIMUM_GO_CHANNELS
-.. _CONFIGURE_MAXIMUM_GO_CHANNELS:
-CONFIGURE_MAXIMUM_GO_CHANNELS
-CONSTANT:
-    ``CONFIGURE_MAXIMUM_GO_CHANNELS``
-DATA TYPE:
-RANGE:
-    Zero or positive.
-DEFAULT VALUE:
-    The default value is 500
-DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_GO_CHANNELS`` is defined to specify the maximum number
-    of Go channels.
-NOTES:
 Obsolete Configuration Options
@@ -4981,6 +4900,13 @@ CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
 This configuration option was introduced in RTEMS 4.9.0 and is obsolete since
 RTEMS 5.1.
+.. index:: CONFIGURE_ENABLE_GO
+CONFIGURE_ENABLE_GO
+This configuration option is obsolete since RTEMS 5.1.
 .. index:: CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
@@ -5010,6 +4936,20 @@ CONFIGURE_NUMBER_OF_TERMIOS_PORTS
+.. index:: CONFIGURE_MAXIMUM_GO_CHANNELS
+CONFIGURE_MAXIMUM_GO_CHANNELS
+.. index:: CONFIGURE_MAXIMUM_GOROUTINES
+CONFIGURE_MAXIMUM_GOROUTINES
 .. index:: CONFIGURE_MAXIMUM_POSIX_BARRIERS
2.16.4
