[PATCHv3 2/2] bsps/riscv: HTIF - Use 32-bit HTIF syscalls on RV32
Hesham Almatary
Hesham.Almatary at cl.cam.ac.uk
Tue Apr 9 09:23:51 UTC 2019
HTIF devices are not supported on RV32, so proxy a write system call
This syncs HTIF Console with riscv-pk (proxy kernel) to use 32-bit
HTIF syscalls on RV32 instead of 64-bit commands that are not atomic.
bsps/riscv/riscv/console/htif.c | 59 +++++++++++++++++++++++++++++----
1 file changed, 53 insertions(+), 6 deletions(-)
diff --git a/bsps/riscv/riscv/console/htif.c b/bsps/riscv/riscv/console/htif.c
index bcfe6a5db5..34d36d0b52 100644
--- a/bsps/riscv/riscv/console/htif.c
+++ b/bsps/riscv/riscv/console/htif.c
@@ -31,8 +31,8 @@
#if RISCV_ENABLE_HTIF_SUPPORT != 0
+#include <bsp/irq-generic.h>
#include <dev/serial/htif.h>
#include <assert.h>
/* Most of the code below is copied from riscv-pk project */
@@ -43,11 +43,15 @@
#define FROMHOST_CMD(fromhost_value) ((uint64_t)(fromhost_value) << 8 >> 56)
#define FROMHOST_DATA(fromhost_value) ((uint64_t)(fromhost_value) << 16 >> 16)
+#define SYS_write 64
volatile uint64_t tohost __attribute__((section(".htif")));
volatile uint64_t fromhost __attribute__((section(".htif")));
volatile uint64_t riscv_fill_up_htif_section[510] __attribute__((section(".htif")));
volatile int htif_console_buf;
+RTEMS_INTERRUPT_LOCK_DEFINE( static, htif_lock, "htif_lock");
static void __check_fromhost(void)
uint64_t fh = fromhost;
@@ -77,23 +81,66 @@ static void __set_tohost(uintptr_t dev, uintptr_t cmd, uintptr_t data)
tohost = TOHOST_CMD(dev, cmd, data);
+static void do_tohost_fromhost(uintptr_t dev, uintptr_t cmd, uintptr_t data)
+ rtems_interrupt_lock_context htif_lock_context;
+ rtems_interrupt_lock_acquire(&htif_lock, &htif_lock_context);
+ __set_tohost(dev, cmd, data);
+ while (1) {
+ uint64_t fh = fromhost;
+ if (fh) {
+ if (FROMHOST_DEV(fh) == dev && FROMHOST_CMD(fh) == cmd) {
+ fromhost = 0;
+ break;
+ __check_fromhost();
+ rtems_interrupt_lock_release(&htif_lock, &htif_lock_context);
+void htif_syscall(uintptr_t arg)
+ do_tohost_fromhost(0, 0, arg);
+void htif_console_putchar(rtems_termios_device_context *base, char ch)
+#if __riscv_xlen == 32
+ // HTIF devices are not supported on RV32, so proxy a write system call
+ volatile uint64_t magic_mem[8];
+ magic_mem[0] = SYS_write;
+ magic_mem[1] = 1;
+ magic_mem[2] = (uintptr_t)&ch;
+ magic_mem[3] = 1;
+ do_tohost_fromhost(0, 0, (uintptr_t)magic_mem);
+#else
+ __set_tohost(1, 1, ch);
+#endif
int htif_console_getchar(rtems_termios_device_context *base)
__check_fromhost();
int ch = htif_console_buf;
if (ch >= 0) {
htif_console_buf = -1;
__set_tohost(1, 0, 0);
return ch - 1;
-void htif_console_putchar(rtems_termios_device_context *base, char c)
- __set_tohost(1, 1, c);
static void htif_console_write_polled(
const char *buf,
2.17.1
