[PATCH v2 3/4] bsp/xilinx-zynqmp: Stub out Xilinx MPSoC BSP
Jeff Kubascik Jeff.Kubascik at dornerworks.com
Wed Apr 10 23:38:54 UTC 2019
From: Jeff Kubascik <jeff.kubascik at dornerworks.com>
Source files were copied from xilinx-zynq.
 bsps/arm/xilinx-zynqmp/README                 |  13 ++
 bsps/arm/xilinx-zynqmp/config/xilinx_zynq.inc |  10 ++
 .../xilinx-zynqmp/console/console-config.c    |  75 +++++++++
 bsps/arm/xilinx-zynqmp/headers.am             |  15 ++
 bsps/arm/xilinx-zynqmp/include/bsp.h          |  99 ++++++++++++
 bsps/arm/xilinx-zynqmp/include/bsp/irq.h      | 128 ++++++++++++++++
 bsps/arm/xilinx-zynqmp/include/tm27.h         |  49 ++++++
 bsps/arm/xilinx-zynqmp/start/bsp_specs        |   9 ++
 bsps/arm/xilinx-zynqmp/start/bspreset.c       |  43 ++++++
 bsps/arm/xilinx-zynqmp/start/bspsmp.c         |  52 +++++++
 bsps/arm/xilinx-zynqmp/start/bspstart.c       |  45 ++++++
 bsps/arm/xilinx-zynqmp/start/bspstarthooks.c  |  89 +++++++++++
 bsps/arm/xilinx-zynqmp/start/bspstartmmu.c    |  75 +++++++++
 bsps/arm/xilinx-zynqmp/start/linkcmds.in      |  36 +++++
 .../lib/libbsp/arm/xilinx-zynqmp/Makefile.am  |  86 +++++++++++
 .../lib/libbsp/arm/xilinx-zynqmp/configure.ac | 142 ++++++++++++++++++
 16 files changed, 966 insertions(+)
 create mode 100644 bsps/arm/xilinx-zynqmp/README
 create mode 100644 bsps/arm/xilinx-zynqmp/config/xilinx_zynq.inc
 create mode 100644 bsps/arm/xilinx-zynqmp/console/console-config.c
 create mode 100644 bsps/arm/xilinx-zynqmp/headers.am
 create mode 100644 bsps/arm/xilinx-zynqmp/include/bsp.h
 create mode 100644 bsps/arm/xilinx-zynqmp/include/bsp/irq.h
 create mode 100644 bsps/arm/xilinx-zynqmp/include/tm27.h
 create mode 100644 bsps/arm/xilinx-zynqmp/start/bsp_specs
 create mode 100644 bsps/arm/xilinx-zynqmp/start/bspreset.c
 create mode 100644 bsps/arm/xilinx-zynqmp/start/bspsmp.c
 create mode 100644 bsps/arm/xilinx-zynqmp/start/bspstart.c
 create mode 100644 bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
 create mode 100644 bsps/arm/xilinx-zynqmp/start/bspstartmmu.c
 create mode 100644 bsps/arm/xilinx-zynqmp/start/linkcmds.in
 create mode 100644 c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
 create mode 100644 c/src/lib/libbsp/arm/xilinx-zynqmp/configure.ac
diff --git a/bsps/arm/xilinx-zynqmp/README b/bsps/arm/xilinx-zynqmp/README
new file mode 100644
index 0000000000..eef9159926
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/README
@@ -0,0 +1,13 @@
+Tested only on Qemu.
+git clone git://git.qemu.org/qemu.git qemu
+cd qemu
+git checkout 1b0d3845b454eaaac0b2064c78926ca4d739a080
+mkdir build
+cd build
+../configure --prefix=/opt/qemu --interp-prefix=/opt/qemu
+make
+make install
+export PATH="$PATH:/opt/qemu/bin"
+qemu-system-arm -no-reboot -serial null -serial mon:stdio -net none -nographic -M xilinx-zynq-a9 -m 256M -kernel ticker.exe
diff --git a/bsps/arm/xilinx-zynqmp/config/xilinx_zynq.inc b/bsps/arm/xilinx-zynqmp/config/xilinx_zynq.inc
index 0000000000..59c18f7c95
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/config/xilinx_zynq.inc
@@ -0,0 +1,10 @@
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = arm
+CPU_CFLAGS = -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9
+CFLAGS_OPTIMIZE_V ?= -O2 -g
+CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
+LDFLAGS = -Wl,--gc-sections
diff --git a/bsps/arm/xilinx-zynqmp/console/console-config.c b/bsps/arm/xilinx-zynqmp/console/console-config.c
index 0000000000..6ab9e1e015
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/console/console-config.c
@@ -0,0 +1,75 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2013, 2017 embedded brains GmbH
+ * are met:
+#include <rtems/console.h>
+#include <rtems/bspIo.h>
+#include <bsp/irq.h>
+#include <bsp/zynq-uart.h>
+#include <bspopts.h>
+zynq_uart_context zynq_uart_instances[2] = {
+    .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 0" ),
+    .regs = (volatile struct zynq_uart *) 0xe0000000,
+    .irq = ZYNQ_IRQ_UART_0
+    .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 1" ),
+    .regs = (volatile struct zynq_uart *) 0xe0001000,
+    .irq = ZYNQ_IRQ_UART_1
+rtems_status_code console_initialize(
+  rtems_device_major_number major,
+  rtems_device_minor_number minor,
+  void *arg
+  size_t i;
+  rtems_termios_initialize();
+  for (i = 0; i < RTEMS_ARRAY_SIZE(zynq_uart_instances); ++i) {
+    char uart[] = "/dev/ttySX";
+    uart[sizeof(uart) - 2] = (char) ('0' + i);
+    rtems_termios_device_install(
+      &uart[0],
+      &zynq_uart_handler,
+      NULL,
+      &zynq_uart_instances[i].base
+    if (i == BSP_CONSOLE_MINOR) {
+      link(&uart[0], CONSOLE_DEVICE_NAME);
+  return RTEMS_SUCCESSFUL;
diff --git a/bsps/arm/xilinx-zynqmp/headers.am b/bsps/arm/xilinx-zynqmp/headers.am
index 0000000000..ed7061964c
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/headers.am
@@ -0,0 +1,15 @@
+## This file was generated by "./boostrap -H".
+include_HEADERS =
+include_HEADERS += ../../../../../../bsps/arm/xilinx-zynq/include/bsp.h
+include_HEADERS += include/bspopts.h
+include_HEADERS += ../../../../../../bsps/arm/xilinx-zynq/include/tm27.h
+include_bspdir = $(includedir)/bsp
+include_bsp_HEADERS =
+include_bsp_HEADERS += ../../../../../../bsps/arm/xilinx-zynq/include/bsp/cadence-i2c-regs.h
+include_bsp_HEADERS += ../../../../../../bsps/arm/xilinx-zynq/include/bsp/cadence-i2c.h
+include_bsp_HEADERS += ../../../../../../bsps/arm/xilinx-zynq/include/bsp/i2c.h
+include_bsp_HEADERS += ../../../../../../bsps/arm/xilinx-zynq/include/bsp/irq.h
+include_bsp_HEADERS += ../../../../../../bsps/arm/include/bsp/zynq-uart-regs.h
+include_bsp_HEADERS += ../../../../../../bsps/arm/include/bsp/zynq-uart.h
diff --git a/bsps/arm/xilinx-zynqmp/include/bsp.h b/bsps/arm/xilinx-zynqmp/include/bsp.h
index 0000000000..6c2759ce50
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/include/bsp.h
@@ -0,0 +1,99 @@
+ * @file
+ * @ingroup RTEMSBSPsARMZynq
+ * @brief Global BSP definitions.
+ * Copyright (C) 2013, 2014 embedded brains GmbH
+ * are met:
+#ifndef LIBBSP_ARM_XILINX_ZYNQ_BSP_H
+#define LIBBSP_ARM_XILINX_ZYNQ_BSP_H
+ * @defgroup RTEMSBSPsARMZynq Xilinx Zynq
+ * @brief Xilinx Zynq Board Support Package.
+#define BSP_FEATURE_IRQ_EXTENSION
+#ifndef ASM
+#include <rtems.h>
+#include <bsp/default-initial-extension.h>
+#include <bsp/start.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define BSP_ARM_A9MPCORE_SCU_BASE 0xf8f00000
+#define BSP_ARM_GIC_CPUIF_BASE 0xf8f00100
+#define BSP_ARM_A9MPCORE_GT_BASE 0xf8f00200
+#define BSP_ARM_A9MPCORE_PT_BASE 0xf8f00600
+#define BSP_ARM_GIC_DIST_BASE 0xf8f01000
+#define BSP_ARM_L2C_310_BASE 0xf8f02000
+#define BSP_ARM_L2C_310_ID 0x410000c8
+extern zynq_uart_context zynq_uart_instances[2];
+ * @brief Zynq specific set up of the MMU.
+ * Provide in the application to override
+ * the defaults in the BSP. Note the defaults do not map in the GP0 and GP1
+ * AXI ports. You should add the specific regions that map into your
+ * PL rather than just open the whole of the GP[01] address space up.
+BSP_START_TEXT_SECTION void zynq_setup_mmu_and_cache(void);
+uint32_t zynq_clock_cpu_1x(void);
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_ARM_XILINX_ZYNQ_BSP_H */
diff --git a/bsps/arm/xilinx-zynqmp/include/bsp/irq.h b/bsps/arm/xilinx-zynqmp/include/bsp/irq.h
index 0000000000..edea29b7df
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/include/bsp/irq.h
@@ -0,0 +1,128 @@
+ * @file
+ * @ingroup zynq_interrupt
+ * @brief Interrupt definitions.
+ * Copyright (C) 2013 embedded brains GmbH
+ * are met:
+#ifndef LIBBSP_ARM_XILINX_ZYNQ_IRQ_H
+#define LIBBSP_ARM_XILINX_ZYNQ_IRQ_H
+#ifndef ASM
+#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
+#include <bsp/arm-a9mpcore-irq.h>
+#include <bsp/arm-gic-irq.h>
+#ifdef __cplusplus
+extern "C" {
+ * @defgroup zynq_interrupt Interrupt Support
+ * @brief Interrupt Support
+#define ZYNQ_IRQ_CPU_0 32
+#define ZYNQ_IRQ_CPU_1 33
+#define ZYNQ_IRQ_L2_CACHE 34
+#define ZYNQ_IRQ_OCM 35
+#define ZYNQ_IRQ_PMU_0 37
+#define ZYNQ_IRQ_PMU_1 38
+#define ZYNQ_IRQ_XADC 39
+#define ZYNQ_IRQ_DVI 40
+#define ZYNQ_IRQ_SWDT 41
+#define ZYNQ_IRQ_TTC_0_0 42
+#define ZYNQ_IRQ_TTC_1_0 43
+#define ZYNQ_IRQ_TTC_2_0 44
+#define ZYNQ_IRQ_DMAC_ABORT 45
+#define ZYNQ_IRQ_DMAC_0 46
+#define ZYNQ_IRQ_DMAC_1 47
+#define ZYNQ_IRQ_DMAC_2 48
+#define ZYNQ_IRQ_DMAC_3 49
+#define ZYNQ_IRQ_SMC 50
+#define ZYNQ_IRQ_QUAD_SPI 51
+#define ZYNQ_IRQ_GPIO 52
+#define ZYNQ_IRQ_USB_0 53
+#define ZYNQ_IRQ_ETHERNET_0 54
+#define ZYNQ_IRQ_ETHERNET_0_WAKEUP 55
+#define ZYNQ_IRQ_SDIO_0 56
+#define ZYNQ_IRQ_I2C_0 57
+#define ZYNQ_IRQ_SPI_0 58
+#define ZYNQ_IRQ_UART_0 59
+#define ZYNQ_IRQ_CAN_0 60
+#define ZYNQ_IRQ_FPGA_0 61
+#define ZYNQ_IRQ_FPGA_1 62
+#define ZYNQ_IRQ_FPGA_2 63
+#define ZYNQ_IRQ_FPGA_3 64
+#define ZYNQ_IRQ_FPGA_4 65
+#define ZYNQ_IRQ_FPGA_5 66
+#define ZYNQ_IRQ_FPGA_6 67
+#define ZYNQ_IRQ_FPGA_7 68
+#define ZYNQ_IRQ_TTC_0_1 69
+#define ZYNQ_IRQ_TTC_1_1 70
+#define ZYNQ_IRQ_TTC_2_1 71
+#define ZYNQ_IRQ_DMAC_4 72
+#define ZYNQ_IRQ_DMAC_5 73
+#define ZYNQ_IRQ_DMAC_6 74
+#define ZYNQ_IRQ_DMAC_7 75
+#define ZYNQ_IRQ_USB_1 76
+#define ZYNQ_IRQ_ETHERNET_1 77
+#define ZYNQ_IRQ_ETHERNET_1_WAKEUP 78
+#define ZYNQ_IRQ_SDIO_1 79
+#define ZYNQ_IRQ_I2C_1 80
+#define ZYNQ_IRQ_SPI_1 81
+#define ZYNQ_IRQ_UART_1 82
+#define ZYNQ_IRQ_CAN_1 83
+#define ZYNQ_IRQ_FPGA_8 84
+#define ZYNQ_IRQ_FPGA_9 85
+#define ZYNQ_IRQ_FPGA_10 86
+#define ZYNQ_IRQ_FPGA_11 87
+#define ZYNQ_IRQ_FPGA_12 88
+#define ZYNQ_IRQ_FPGA_13 89
+#define ZYNQ_IRQ_FPGA_14 90
+#define ZYNQ_IRQ_FPGA_15 91
+#define ZYNQ_IRQ_PARITY 92
+#define BSP_INTERRUPT_VECTOR_MIN 0
+#define BSP_INTERRUPT_VECTOR_MAX 92
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_ARM_XILINX_ZYNQ_IRQ_H */
diff --git a/bsps/arm/xilinx-zynqmp/include/tm27.h b/bsps/arm/xilinx-zynqmp/include/tm27.h
index 0000000000..885b97a30c
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/include/tm27.h
@@ -0,0 +1,49 @@
+ * @file
+ * @ingroup zynq_tm27
+ * @brief Interrupt mechanisms for tm27 test.
+ * are met:
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+ * @defgroup zynq_tm27 TM27 Test Support
+ * @brief Interrupt Mechanisms for tm27 test
+#include <bsp/arm-gic-tm27.h>
+#endif /* __tm27_h */
diff --git a/bsps/arm/xilinx-zynqmp/start/bsp_specs b/bsps/arm/xilinx-zynqmp/start/bsp_specs
index 0000000000..47dd31d46b
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/start/bsp_specs
@@ -0,0 +1,9 @@
+%rename endfile old_endfile
+%rename startfile old_startfile
+*startfile:
+%{!qrtems: %(old_startfile)} \
+%{!nostdlib: %{qrtems: crti.o%s crtbegin.o%s}}
+*endfile:
+%{!qrtems: %(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s}
diff --git a/bsps/arm/xilinx-zynqmp/start/bspreset.c b/bsps/arm/xilinx-zynqmp/start/bspreset.c
index 0000000000..e0c81ca2ef
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/start/bspreset.c
@@ -0,0 +1,43 @@
+ * are met:
+#include <bsp.h>
+#include <bsp/bootcard.h>
+void bsp_reset(void)
+  volatile uint32_t *slcr_unlock = (volatile uint32_t *) 0xf8000008;
+  volatile uint32_t *pss_rst_ctrl = (volatile uint32_t *) 0xf8000200;
+  zynq_uart_reset_tx_flush(&zynq_uart_instances[BSP_CONSOLE_MINOR]);
+  while (true) {
+    *slcr_unlock = 0xdf0d;
+    *pss_rst_ctrl = 0x1;
diff --git a/bsps/arm/xilinx-zynqmp/start/bspsmp.c b/bsps/arm/xilinx-zynqmp/start/bspsmp.c
index 0000000000..fdb7f85ba6
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/start/bspsmp.c
@@ -0,0 +1,52 @@
+ * Copyright (C) 2014 embedded brains GmbH
+ * are met:
+#include <rtems/score/smpimpl.h>
+bool _CPU_SMP_Start_processor(uint32_t cpu_index)
+   * Enable the second CPU.
+  if (cpu_index != 0) {
+    volatile uint32_t* const kick_address = (uint32_t*) 0xfffffff0UL;
+    _ARM_Data_synchronization_barrier();
+    _ARM_Instruction_synchronization_barrier();
+    *kick_address = (uint32_t) _start;
+    _ARM_Send_event();
+   * Wait for secondary processor to complete its basic initialization so that
+   * we can enable the unified L2 cache.
+  return _Per_CPU_State_wait_for_non_initial_state(cpu_index, 0);
diff --git a/bsps/arm/xilinx-zynqmp/start/bspstart.c b/bsps/arm/xilinx-zynqmp/start/bspstart.c
index 0000000000..68b0ef0b03
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/start/bspstart.c
@@ -0,0 +1,45 @@
+ * Copyright (C) 2013, 2015 embedded brains GmbH
+ * are met:
+#include <bsp.h>
+#include <bsp/irq-generic.h>
+#include <bsp/linker-symbols.h>
+__attribute__ ((weak)) uint32_t zynq_clock_cpu_1x(void)
+  return ZYNQ_CLOCK_CPU_1X;
+void bsp_start(void)
+  bsp_interrupt_initialize();
+  rtems_cache_coherent_add_area(
+    bsp_section_nocacheheap_begin,
+    (uintptr_t) bsp_section_nocacheheap_size
diff --git a/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c b/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
index 0000000000..a0f0fbacf6
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
@@ -0,0 +1,89 @@
+ * are met:
+#define ARM_CP15_TEXT_SECTION BSP_START_TEXT_SECTION
+#include <bsp.h>
+#include <bsp/arm-cp15-start.h>
+#include <bsp/arm-a9mpcore-start.h>
+BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
+  uint32_t sctlr_val;
+  sctlr_val = arm_cp15_get_control();
+   * Current U-boot loader seems to start kernel image
+   * with I and D caches on and MMU enabled.
+   * If RTEMS application image finds that cache is on
+   * during startup then disable caches.
+  if ( sctlr_val & (ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M ) ) {
+    if ( sctlr_val & (ARM_CP15_CTRL_C | ARM_CP15_CTRL_M ) ) {
+       * If the data cache is on then ensure that it is clean
+       * before switching off to be extra carefull.
+      arm_cp15_data_cache_clean_all_levels();
+    arm_cp15_flush_prefetch_buffer();
+    sctlr_val &= ~ ( ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M | ARM_CP15_CTRL_A );
+    arm_cp15_set_control( sctlr_val );
+  arm_cp15_instruction_cache_invalidate();
+   * The care should be taken there that no shared levels
+   * are invalidated by secondary CPUs in SMP case.
+   * It is not problem on Zynq because level of coherency
+   * is L1 only and higher level is not maintained and seen
+   * by CP15. So no special care to limit levels on the secondary
+   * are required there.
+  arm_cp15_data_cache_invalidate_all_levels();
+  arm_cp15_branch_predictor_invalidate_all();
+  arm_cp15_tlb_invalidate();
+  arm_a9mpcore_start_hook_0();
+BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
+  arm_a9mpcore_start_hook_1();
+  bsp_start_copy_sections();
+  zynq_setup_mmu_and_cache();
+#if !defined(RTEMS_SMP) \
+  && (defined(BSP_DATA_CACHE_ENABLED) \
+    || defined(BSP_INSTRUCTION_CACHE_ENABLED))
+  /* Enable unified L2 cache */
+  rtems_cache_enable_data();
+#endif
+  bsp_start_clear_bss();
diff --git a/bsps/arm/xilinx-zynqmp/start/bspstartmmu.c b/bsps/arm/xilinx-zynqmp/start/bspstartmmu.c
index 0000000000..c18f8623f7
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/start/bspstartmmu.c
@@ -0,0 +1,75 @@
+ * are met:
+#include <bsp.h>
+BSP_START_DATA_SECTION static const arm_cp15_start_section_config
+zynq_mmu_config_table[] = {
+  ARMV7_CP15_START_DEFAULT_SECTIONS,
+#if defined(RTEMS_SMP)
+    .begin = 0xffff0000U,
+    .end = 0xffffffffU,
+    .flags = ARMV7_MMU_DEVICE
+#endif
+    .begin = 0xe0000000U,
+    .end = 0xe0200000U,
+    .begin = 0xf8000000U,
+    .end = 0xf9000000U,
+ * Make weak and let the user override.
+BSP_START_TEXT_SECTION void zynq_setup_mmu_and_cache(void) __attribute__ ((weak));
+  uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
+    ARM_CP15_CTRL_A,
+    ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
+  arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
+    ctrl,
+    (uint32_t *) bsp_translation_table_base,
+    ARM_MMU_DEFAULT_CLIENT_DOMAIN,
+    &zynq_mmu_config_table[0],
+    RTEMS_ARRAY_SIZE(zynq_mmu_config_table)
diff --git a/bsps/arm/xilinx-zynqmp/start/linkcmds.in b/bsps/arm/xilinx-zynqmp/start/linkcmds.in
index 0000000000..b56309bf37
--- /dev/null
+++ b/bsps/arm/xilinx-zynqmp/start/linkcmds.in
@@ -0,0 +1,36 @@
+MEMORY {
+   RAM_INT_0 : ORIGIN = @ZYNQ_RAM_INT_0_ORIGIN@, LENGTH = @ZYNQ_RAM_INT_0_LENGTH@
+   RAM_INT_1 : ORIGIN = @ZYNQ_RAM_INT_1_ORIGIN@, LENGTH = @ZYNQ_RAM_INT_1_LENGTH@
+   RAM_MMU   : ORIGIN = @ZYNQ_RAM_MMU@, LENGTH = @ZYNQ_RAM_MMU_LENGTH@
+   RAM       : ORIGIN = @ZYNQ_RAM_ORIGIN_AVAILABLE@, LENGTH = @ZYNQ_RAM_LENGTH_AVAILABLE@ - @ZYNQ_RAM_NOCACHE_LENGTH@
+   NOCACHE   : ORIGIN = @ZYNQ_RAM_ORIGIN_AVAILABLE@ + @ZYNQ_RAM_LENGTH_AVAILABLE@ - @ZYNQ_RAM_NOCACHE_LENGTH@, LENGTH = @ZYNQ_RAM_NOCACHE_LENGTH@
+REGION_ALIAS ("REGION_START",          RAM);
+REGION_ALIAS ("REGION_VECTOR",         RAM);
+REGION_ALIAS ("REGION_TEXT",           RAM);
+REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
+REGION_ALIAS ("REGION_RODATA",         RAM);
+REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
+REGION_ALIAS ("REGION_DATA",           RAM);
+REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
+REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
+REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
+REGION_ALIAS ("REGION_FAST_DATA",      RAM);
+REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+REGION_ALIAS ("REGION_BSS",            RAM);
+REGION_ALIAS ("REGION_WORK",           RAM);
+REGION_ALIAS ("REGION_STACK",          RAM);
+REGION_ALIAS ("REGION_NOCACHE",        NOCACHE);
+REGION_ALIAS ("REGION_NOCACHE_LOAD",   NOCACHE);
+bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
+bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
+bsp_vector_table_in_start_section = 1;
+bsp_translation_table_base = ORIGIN (RAM_MMU);
+bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
+INCLUDE linkcmds.armv4
diff --git a/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
index 0000000000..7b4e4aea94
--- /dev/null
+++ b/c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am
@@ -0,0 +1,86 @@
+# @file
+# @brief Makefile of LibBSP for the Xilinx Zynq platform.
+ACLOCAL_AMFLAGS = -I ../../../../aclocal
+include $(top_srcdir)/../../../../automake/compile.am
+include $(top_srcdir)/../../bsp.am
+dist_project_lib_DATA = ../../../../../../bsps/arm/xilinx-zynq/start/bsp_specs
+#                  Header                                                     #
+#                  Data                                                       #
+start.$(OBJEXT): ../../../../../../bsps/arm/shared/start/start.S
+	$(CPPASCOMPILE) -o $@ -c $<
+project_lib_DATA = start.$(OBJEXT)
+project_lib_DATA += linkcmds
+#                  LibBSP                                                     #
+project_lib_LIBRARIES = librtemsbsp.a
+librtemsbsp_a_SOURCES =
+# Shared
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/getentropy/getentropy-cpucounter.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-default.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/stackalloc.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/start/bsp-start-memcpy.S
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
+# Startup
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/start/bspreset.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/start/bspstart.c
+if HAS_SMP
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/start/arm-a9mpcore-smp.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/start/bspsmp.c
+endif
+# IRQ
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/irq/irq-gic.c
+# Console
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/console/console-config.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/console/debug-console.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/serial/zynq-uart.c
+# Clock
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/clock/clock-a9mpcore.c
+# I2C
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/i2c/cadence-i2c.c
+# Cache
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-l2c-310.c
+# Start hooks
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/start/bspstarthooks.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/start/bspstartmmu.c
+#                  Special Rules                                              #
+include $(srcdir)/../../../../../../bsps/shared/irq-sources.am
+include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
+include $(srcdir)/../../../../../../bsps/arm/xilinx-zynq/headers.am
diff --git a/c/src/lib/libbsp/arm/xilinx-zynqmp/configure.ac b/c/src/lib/libbsp/arm/xilinx-zynqmp/configure.ac
index 0000000000..f58b737b1b
--- /dev/null
+++ b/c/src/lib/libbsp/arm/xilinx-zynqmp/configure.ac
@@ -0,0 +1,142 @@
+# @file
+# @brief Configure script of LibBSP for the Xilinx Zynq platform.
+AC_PREREQ([2.69])
+AC_INIT([rtems-c-src-lib-libbsp-arm-xilinx-zynq-a9],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
+RTEMS_TOP(../../../../../..)
+RTEMS_SOURCE_TOP
+RTEMS_BUILD_TOP
+RTEMS_CANONICAL_TARGET_CPU
+AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
+RTEMS_BSP_CONFIGURE
+RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
+RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for BSP start])
+RTEMS_BSPOPTS_SET([BSP_DATA_CACHE_ENABLED],[*qemu],[])
+RTEMS_BSPOPTS_SET([BSP_DATA_CACHE_ENABLED],[*],[1])
+RTEMS_BSPOPTS_HELP([BSP_DATA_CACHE_ENABLED],[enable data cache])
+RTEMS_BSPOPTS_SET([BSP_INSTRUCTION_CACHE_ENABLED],[*qemu],[])
+RTEMS_BSPOPTS_SET([BSP_INSTRUCTION_CACHE_ENABLED],[*],[1])
+RTEMS_BSPOPTS_HELP([BSP_INSTRUCTION_CACHE_ENABLED],[enable instruction cache])
+RTEMS_BSPOPTS_SET([BSP_ARM_A9MPCORE_PERIPHCLK],[xilinx_zynq_zc702*],[333333333U])
+RTEMS_BSPOPTS_SET([BSP_ARM_A9MPCORE_PERIPHCLK],[xilinx_zynq_zedboard*],[666666667U])
+RTEMS_BSPOPTS_SET([BSP_ARM_A9MPCORE_PERIPHCLK],[*],[100000000U])
+RTEMS_BSPOPTS_HELP([BSP_ARM_A9MPCORE_PERIPHCLK],[ARM Cortex-A9 MPCore PERIPHCLK clock frequency in Hz])
+RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_UART],[xilinx_zynq_zc702*],[50000000UL])
+RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_UART],[xilinx_zynq_zedboard*],[50000000UL])
+RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_UART],[*],[50000000UL])
+RTEMS_BSPOPTS_HELP([ZYNQ_CLOCK_UART],[Zynq UART clock frequency in Hz])
+RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_CPU_1X],[xilinx_zynq_zc702*],[111111111U])
+RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_CPU_1X],[xilinx_zynq_zedboard*],[111111111U])
+RTEMS_BSPOPTS_SET([ZYNQ_CLOCK_CPU_1X],[*],[111111111U])
+RTEMS_BSPOPTS_HELP([ZYNQ_CLOCK_CPU_1X],[Zynq cpu_1x clock frequency in Hz])
+USE_FAST_IDLE=0
+AS_IF([test "x${RTEMS_BSP}" == xxilinx_zynq_a9_qemu], [USE_FAST_IDLE=1])
+RTEMS_BSPOPTS_SET([CLOCK_DRIVER_USE_FAST_IDLE],[*qemu],[${USE_FAST_IDLE}])
+RTEMS_BSPOPTS_HELP([CLOCK_DRIVER_USE_FAST_IDLE],
+[This sets a mode where the time runs as fast as possible when a clock ISR
+occurs while the IDLE thread is executing.  This can significantly reduce
+simulation times.])
+RTEMS_BSPOPTS_SET([BSP_CONSOLE_MINOR],[*],[1])
+RTEMS_BSPOPTS_HELP([BSP_CONSOLE_MINOR],[minor number of console device])
+RTEMS_BSPOPTS_SET([ZYNQ_CONSOLE_USE_INTERRUPTS],[*],[1])
+RTEMS_BSPOPTS_HELP([ZYNQ_CONSOLE_USE_INTERRUPTS],[use interrupt driven mode for console devices (used by default)])
+# Zynq Memory map can be controlled from the configure command line. Use ...
+#   ..../configure --target=arm-rtems4.11 ... BSP_ZYNQ_RAM_LENGTH=256M
+RTEMS_BSPOPTS_SET([BSP_ZYNQ_RAM_LENGTH],[xilinx_zynq_a9_qemu],[256M])
+RTEMS_BSPOPTS_SET([BSP_ZYNQ_RAM_LENGTH],[xilinx_zynq_zc702],[1024M])
+RTEMS_BSPOPTS_SET([BSP_ZYNQ_RAM_LENGTH],[xilinx_zynq_zc706],[1024M])
+RTEMS_BSPOPTS_SET([BSP_ZYNQ_RAM_LENGTH],[xilinx_zynq_zedboard],[512M])
+RTEMS_BSPOPTS_SET([BSP_ZYNQ_RAM_LENGTH],[*],[256M])
+RTEMS_BSPOPTS_HELP([BSP_ZYNQ_RAM_LENGTH],[override a BSP's default RAM length])
+RTEMS_BSPOPTS_SET([BSP_ZYNQ_NOCACHE_LENGTH],[*],[1M])
+RTEMS_BSPOPTS_HELP([BSP_ZYNQ_NOCACHE_LENGTH],[length of nocache RAM region])
+      [ZYNQ_RAM_ORIGIN="0x00000000"
+       ZYNQ_RAM_MMU="0x0fffc000"
+       ZYNQ_RAM_MMU_LENGTH="16k"
+       ZYNQ_RAM_ORIGIN_AVAILABLE="${ZYNQ_RAM_ORIGIN}"
+       ZYNQ_RAM_LENGTH_AVAILABLE="${BSP_ZYNQ_RAM_LENGTH} - 16k"
+       ZYNQ_RAM_INT_0_ORIGIN="0x00000000"
+       ZYNQ_RAM_INT_0_LENGTH="64k + 64k + 64k"
+       ZYNQ_RAM_INT_1_ORIGIN="0xFFFF0000"
+       ZYNQ_RAM_INT_1_LENGTH="64k - 512"])
+AS_IF([test "x${RTEMS_BSP}" == xxilinx_zynq_zc702],
+      [ZYNQ_RAM_ORIGIN="0x00100000"
+       ZYNQ_RAM_MMU="${ZYNQ_RAM_ORIGIN}"
+       ZYNQ_RAM_ORIGIN_AVAILABLE="${ZYNQ_RAM_ORIGIN} + 0x00004000"
+       ZYNQ_RAM_LENGTH_AVAILABLE="${BSP_ZYNQ_RAM_LENGTH} - 1M - 16k"
+AS_IF([test "x${RTEMS_BSP}" == xxilinx_zynq_zc706],
+      [ZYNQ_RAM_ORIGIN="0x00400000"
+       ZYNQ_RAM_LENGTH_AVAILABLE="${BSP_ZYNQ_RAM_LENGTH} - 4M - 16k"
+AS_IF([test "x${RTEMS_BSP}" == xxilinx_zynq_zedboard],
+AC_DEFUN([ZYNQ_LINKCMD],[
+AC_ARG_VAR([$1],[$2; default $3])dnl
+[$1]=[$]{[$1]:-[$3]}
+ZYNQ_LINKCMD([ZYNQ_RAM_ORIGIN],[normal RAM region origin],[${ZYNQ_RAM_ORIGIN}])
+ZYNQ_LINKCMD([ZYNQ_RAM_LENGTH],[normal RAM region length],[${BSP_ZYNQ_RAM_LENGTH}])
+ZYNQ_LINKCMD([ZYNQ_RAM_MMU],[MMU region origin],[${ZYNQ_RAM_MMU}])
+ZYNQ_LINKCMD([ZYNQ_RAM_MMU_LENGTH],[MMU region length],[${ZYNQ_RAM_MMU_LENGTH}])
+ZYNQ_LINKCMD([ZYNQ_RAM_ORIGIN_AVAILABLE],[origin of available RAM],[${ZYNQ_RAM_ORIGIN_AVAILABLE}])
+ZYNQ_LINKCMD([ZYNQ_RAM_LENGTH_AVAILABLE],[length of available RAM],[${ZYNQ_RAM_LENGTH_AVAILABLE}])
+ZYNQ_LINKCMD([ZYNQ_RAM_NOCACHE_LENGTH],[length of nocache RAM region],[${BSP_ZYNQ_NOCACHE_LENGTH}])
+ZYNQ_LINKCMD([ZYNQ_RAM_INT_0_ORIGIN],[internal 0 RAM region origin],[${ZYNQ_RAM_INT_0_ORIGIN}])
+ZYNQ_LINKCMD([ZYNQ_RAM_INT_0_LENGTH],[internal 0 RAM region length],[${ZYNQ_RAM_INT_0_LENGTH}])
+ZYNQ_LINKCMD([ZYNQ_RAM_INT_1_ORIGIN],[internal 1 RAM region origin],[${ZYNQ_RAM_INT_1_ORIGIN}])
+ZYNQ_LINKCMD([ZYNQ_RAM_INT_1_LENGTH],[internal 1 RAM region length],[${ZYNQ_RAM_INT_1_LENGTH}])
+RTEMS_BSP_CLEANUP_OPTIONS
+AC_CONFIG_FILES([
+Makefile
+linkcmds:../../../../../../bsps/arm/xilinx-zynq/start/linkcmds.in])
+AC_OUTPUT
2.17.1
