[PATCH 3/6] score: Use an ISR lock for Per_CPU_Control::Lock
Thu Apr 11 13:45:37 UTC 2019
The use of a hand crafted lock for Per_CPU_Control::Lock was necessary
at some point in the SMP support development, but it is no longer
justified.
 cpukit/include/rtems/score/percpu.h           | 161 +++++++++++++-------------
 cpukit/include/rtems/score/schedulersmpimpl.h |  12 +-
 cpukit/include/rtems/score/threadimpl.h       |   6 +-
 cpukit/include/rtems/score/userextimpl.h      |   5 +-
 cpukit/posix/src/pspinlock.c                  |  11 +-
 cpukit/posix/src/pspinunlock.c                |  13 ++-
 cpukit/score/src/schedulersmp.c               |  13 ++-
 cpukit/score/src/smp.c                        |   6 +-
 cpukit/score/src/threaddispatch.c             |  17 +--
 cpukit/score/src/userextaddset.c              |   6 +-
 cpukit/score/src/userextremoveset.c           |   6 +-
 11 files changed, 133 insertions(+), 123 deletions(-)
diff --git a/cpukit/include/rtems/score/percpu.h b/cpukit/include/rtems/score/percpu.h
index 8e33aaee4a..d7232c632f 100644
--- a/cpukit/include/rtems/score/percpu.h
+++ b/cpukit/include/rtems/score/percpu.h
@@ -28,7 +28,6 @@
   #include <rtems/score/isrlock.h>
   #include <rtems/score/smp.h>
-  #include <rtems/score/smplock.h>
   #include <rtems/score/timestamp.h>
 #endif
@@ -333,7 +332,7 @@ typedef struct Per_CPU_Control {
    * It is volatile since interrupts may alter this flag.
-   * This field is not protected by a lock and must be accessed only by this
+   * This member is not protected by a lock and must be accessed only by this
    * processor.  Code (e.g. scheduler and post-switch action requests) running
    * on another processors must use an inter-processor interrupt to set the
    * thread dispatch necessary indicator to true.
@@ -352,7 +351,8 @@ typedef struct Per_CPU_Control {
    * @brief This is the thread executing on this processor.
-   * This field is not protected by a lock.  The only writer is this processor.
+   * This member is not protected by a lock.  The only writer is this
+   * processor.
    * On SMP configurations a thread may be registered as executing on more than
    * one processor in case a thread migration is in progress.  On SMP
@@ -364,10 +364,10 @@ typedef struct Per_CPU_Control {
    * @brief This is the heir thread for this processor.
-   * This field is not protected by a lock.  The only writer after multitasking
-   * start is the scheduler owning this processor.  It is assumed that stores
-   * to pointers are atomic on all supported SMP architectures.  The CPU port
-   * specific code (inter-processor interrupt handling and
+   * This member is not protected by a lock.  The only writer after
+   * multitasking start is the scheduler owning this processor.  It is assumed
+   * that stores to pointers are atomic on all supported SMP architectures.
+   * The CPU port specific code (inter-processor interrupt handling and
    * _CPU_SMP_Send_interrupt()) must guarantee that this processor observes the
    * last value written.
@@ -418,39 +418,31 @@ typedef struct Per_CPU_Control {
   #if defined( RTEMS_SMP )
-     * @brief This lock protects some parts of the low-level thread dispatching.
+     * @brief This lock protects some members of this structure.
+    ISR_lock_Control Lock;
+     * @brief Lock context used to acquire all per-CPU locks.
-     * We must use a ticket lock here since we cannot transport a local context
-     * through the context switch.
+     * This member is protected by the Per_CPU_Control::Lock lock.
-     * @see _Thread_Dispatch().
+     * @see _Per_CPU_Acquire_all().
-    SMP_ticket_lock_Control Lock;
-    #if defined( RTEMS_PROFILING )
-       * @brief Lock statistics for the per-CPU lock.
-      SMP_lock_Stats Lock_stats;
-       * @brief Lock statistics context for the per-CPU lock.
-      SMP_lock_Stats_context Lock_stats_context;
-    #endif
+    ISR_lock_Context Lock_context;
      * @brief Chain of threads in need for help.
-     * This field is protected by the Per_CPU_Control::Lock lock.
     Chain_Control Threads_in_need_for_help;
      * @brief Bit field for SMP messages.
-     * This bit field is not protected locks.  Atomic operations are used to
-     * set and get the message bits.
+     * This member is not protected locks.  Atomic operations are used to set
+     * and get the message bits.
     Atomic_Ulong message;
@@ -488,7 +480,7 @@ typedef struct Per_CPU_Control {
      * @brief Indicates the current state of the CPU.
-     * This field is protected by the _Per_CPU_State_lock lock.
+     * This member is protected by the _Per_CPU_State_lock lock.
      * @see _Per_CPU_State_change().
@@ -539,62 +531,11 @@ typedef struct {
 extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
-#if defined( RTEMS_SMP )
-#define _Per_CPU_Acquire( cpu ) \
-  _SMP_ticket_lock_Acquire( \
-    &( cpu )->Lock, \
-    &( cpu )->Lock_stats, \
-    &( cpu )->Lock_stats_context \
-#else
-  do { \
-    (void) ( cpu ); \
-  } while ( 0 )
-#endif
-#define _Per_CPU_Release( cpu ) \
-  _SMP_ticket_lock_Release( \
-    &( cpu )->Lock, \
-#else
-  do { \
-    (void) ( cpu ); \
-  } while ( 0 )
-#endif
+#define _Per_CPU_Acquire( cpu, lock_context ) \
+  _ISR_lock_Acquire( &( cpu )->Lock, lock_context )
-#define _Per_CPU_Acquire_all( isr_cookie ) \
-  do { \
-    uint32_t ncpus = _SMP_Get_processor_maximum(); \
-    uint32_t cpu; \
-    _ISR_Local_disable( isr_cookie ); \
-    for ( cpu = 0 ; cpu < ncpus ; ++cpu ) { \
-      _Per_CPU_Acquire( _Per_CPU_Get_by_index( cpu ) ); \
-  } while ( 0 )
-#else
-#endif
-#define _Per_CPU_Release_all( isr_cookie ) \
-  do { \
-    uint32_t cpu; \
-      _Per_CPU_Release( _Per_CPU_Get_by_index( cpu ) ); \
-    _ISR_Local_enable( isr_cookie ); \
-  } while ( 0 )
-#else
-#endif
+#define _Per_CPU_Release( cpu, lock_context ) \
+  _ISR_lock_Release( &( cpu )->Lock, lock_context )
  * If we get the current processor index in a context which allows thread
@@ -671,6 +612,60 @@ static inline bool _Per_CPU_Is_boot_processor(
 #endif
+RTEMS_INLINE_ROUTINE void _Per_CPU_Acquire_all(
+  ISR_lock_Context *lock_context
+#if defined(RTEMS_SMP)
+  uint32_t         cpu_max;
+  uint32_t         cpu_index;
+  Per_CPU_Control *previous_cpu;
+  cpu_max = _SMP_Get_processor_maximum();
+  previous_cpu = _Per_CPU_Get_by_index( 0 );
+  _ISR_lock_ISR_disable( lock_context );
+  _Per_CPU_Acquire( previous_cpu, lock_context );
+  for ( cpu_index = 1 ; cpu_index < cpu_max ; ++cpu_index ) {
+     Per_CPU_Control *cpu;
+     cpu = _Per_CPU_Get_by_index( cpu_index );
+     _Per_CPU_Acquire( cpu, &previous_cpu->Lock_context );
+     previous_cpu = cpu;
+#else
+#endif
+RTEMS_INLINE_ROUTINE void _Per_CPU_Release_all(
+  uint32_t         cpu_max;
+  cpu = _Per_CPU_Get_by_index( cpu_max - 1 );
+  for ( cpu_index = cpu_max - 1 ; cpu_index > 0 ; --cpu_index ) {
+     previous_cpu = _Per_CPU_Get_by_index( cpu_index - 1 );
+     _Per_CPU_Release( cpu, &previous_cpu->Lock_context );
+     cpu = previous_cpu;
+  _Per_CPU_Release( cpu, lock_context );
+  _ISR_lock_ISR_enable( lock_context );
+#else
+#endif
diff --git a/cpukit/include/rtems/score/schedulersmpimpl.h b/cpukit/include/rtems/score/schedulersmpimpl.h
index 0f4805d7f5..f7b5fcc1e2 100644
--- a/cpukit/include/rtems/score/schedulersmpimpl.h
+++ b/cpukit/include/rtems/score/schedulersmpimpl.h
@@ -566,13 +566,13 @@ static inline Thread_Control *_Scheduler_SMP_Preempt(
   Thread_Control   *victim_thread;
-  ISR_lock_Context  lock_context;
+  ISR_lock_Context  scheduler_lock_context;
   Per_CPU_Control  *victim_cpu;
   victim_thread = _Scheduler_Node_get_user( victim );
   _Scheduler_SMP_Node_change_state( victim, SCHEDULER_SMP_NODE_READY );
-  _Thread_Scheduler_acquire_critical( victim_thread, &lock_context );
+  _Thread_Scheduler_acquire_critical( victim_thread, &scheduler_lock_context );
   victim_cpu = _Thread_Get_CPU( victim_thread );
@@ -580,16 +580,18 @@ static inline Thread_Control *_Scheduler_SMP_Preempt(
     _Scheduler_Thread_change_state( victim_thread, THREAD_SCHEDULER_READY );
     if ( victim_thread->Scheduler.helping_nodes > 0 ) {
-      _Per_CPU_Acquire( victim_cpu );
+      ISR_lock_Context per_cpu_lock_context;
+      _Per_CPU_Acquire( victim_cpu, &per_cpu_lock_context );
       _Chain_Append_unprotected(
         &victim_cpu->Threads_in_need_for_help,
         &victim_thread->Scheduler.Help_node
-      _Per_CPU_Release( victim_cpu );
+      _Per_CPU_Release( victim_cpu, &per_cpu_lock_context );
-  _Thread_Scheduler_release_critical( victim_thread, &lock_context );
+  _Thread_Scheduler_release_critical( victim_thread, &scheduler_lock_context );
   _Scheduler_SMP_Allocate_processor(
     context,
diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
index 2232d57dd0..75725aeb48 100644
--- a/cpukit/include/rtems/score/threadimpl.h
+++ b/cpukit/include/rtems/score/threadimpl.h
@@ -990,14 +990,16 @@ RTEMS_INLINE_ROUTINE void _Thread_Scheduler_cancel_need_for_help(
-  _Per_CPU_Acquire( cpu );
+  ISR_lock_Context lock_context;
+  _Per_CPU_Acquire( cpu, &lock_context );
   if ( !_Chain_Is_node_off_chain( &the_thread->Scheduler.Help_node ) ) {
     _Chain_Extract_unprotected( &the_thread->Scheduler.Help_node );
     _Chain_Set_off_chain( &the_thread->Scheduler.Help_node );
-  _Per_CPU_Release( cpu );
+  _Per_CPU_Release( cpu, &lock_context );
 #endif
diff --git a/cpukit/include/rtems/score/userextimpl.h b/cpukit/include/rtems/score/userextimpl.h
index b781773863..d311e220b3 100644
--- a/cpukit/include/rtems/score/userextimpl.h
+++ b/cpukit/include/rtems/score/userextimpl.h
@@ -255,6 +255,7 @@ static inline void _User_extensions_Thread_switch(
   const Chain_Control *chain;
   const Chain_Node    *tail;
   const Chain_Node    *node;
   chain = &_User_extensions_Switches_list;
   tail = _Chain_Immutable_tail( chain );
@@ -271,7 +272,7 @@ static inline void _User_extensions_Thread_switch(
     _ISR_Local_disable( level );
 #endif
-    _Per_CPU_Acquire( cpu_self );
+    _Per_CPU_Acquire( cpu_self, &lock_context );
     node = _Chain_Immutable_first( chain );
@@ -286,7 +287,7 @@ static inline void _User_extensions_Thread_switch(
       node = _Chain_Immutable_next( node );
-    _Per_CPU_Release( cpu_self );
+    _Per_CPU_Release( cpu_self, &lock_context );
     _ISR_Local_enable( level );
 #endif
diff --git a/cpukit/posix/src/pspinlock.c b/cpukit/posix/src/pspinlock.c
index 9bacd367b6..f505768426 100644
--- a/cpukit/posix/src/pspinlock.c
+++ b/cpukit/posix/src/pspinlock.c
@@ -58,20 +58,17 @@ int pthread_spin_lock( pthread_spinlock_t *spinlock )
   POSIX_Spinlock_Control *the_spinlock;
   ISR_Level               level;
 #if defined(RTEMS_SMP) && defined(RTEMS_PROFILING)
-  Per_CPU_Control        *cpu_self;
+  SMP_lock_Stats          unused_stats;
+  SMP_lock_Stats_context  unused_context;
 #endif
   the_spinlock = _POSIX_Spinlock_Get( spinlock );
-#if defined(RTEMS_PROFILING)
-  /* The lock statistics are incorrect in case of nested pthread spinlocks */
-  cpu_self = _Per_CPU_Get();
-#endif
     &the_spinlock->Lock,
-    &cpu_self->Lock_stats,
-    &cpu_self->Lock_stats_context
+    &unused_stats,
+    &unused_context
 #endif
   the_spinlock->interrupt_state = level;
diff --git a/cpukit/posix/src/pspinunlock.c b/cpukit/posix/src/pspinunlock.c
index 74baa7cad7..bcbb2108ef 100644
--- a/cpukit/posix/src/pspinunlock.c
+++ b/cpukit/posix/src/pspinunlock.c
@@ -28,13 +28,24 @@ int pthread_spin_unlock( pthread_spinlock_t *lock )
   ISR_Level               level;
+#if defined(RTEMS_SMP) && defined(RTEMS_PROFILING)
+#endif
   the_spinlock = _POSIX_Spinlock_Get( lock );
   level = the_spinlock->interrupt_state;
+#if defined(RTEMS_PROFILING)
+  /* This is a hack to get around the lock profiling statistics */
+  unused_stats.total_section_time = 0;
+  unused_stats.max_section_time = 0;
+  unused_context.stats = &unused_stats;
+  unused_context.acquire_instant = 0;
+#endif
-    &_Per_CPU_Get()->Lock_stats_context
+    &unused_context
 #endif
diff --git a/cpukit/score/src/schedulersmp.c b/cpukit/score/src/schedulersmp.c
index d68ac4fc8b..a498bda90a 100644
--- a/cpukit/score/src/schedulersmp.c
+++ b/cpukit/score/src/schedulersmp.c
@@ -14,25 +14,26 @@
 void _Scheduler_Request_ask_for_help( Thread_Control *the_thread )
-  _Thread_Scheduler_acquire_critical( the_thread, &lock_context );
+  _Thread_Scheduler_acquire_critical( the_thread, &scheduler_lock_context );
   if ( _Chain_Is_node_off_chain( &the_thread->Scheduler.Help_node ) ) {
-    Per_CPU_Control *cpu;
     cpu = _Thread_Get_CPU( the_thread );
+    _Per_CPU_Acquire( cpu, &per_cpu_lock_context );
       &cpu->Threads_in_need_for_help,
+    _Per_CPU_Release( cpu, &per_cpu_lock_context );
     _Thread_Dispatch_request( _Per_CPU_Get(), cpu );
-  _Thread_Scheduler_release_critical( the_thread, &lock_context );
+  _Thread_Scheduler_release_critical( the_thread, &scheduler_lock_context );
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index bfc23d5ce3..ef791fd026 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -114,11 +114,11 @@ void _SMP_Handler_initialize( void )
   cpu_config_max = rtems_configuration_get_maximum_processors();
   for ( cpu_index = 0 ; cpu_index < cpu_config_max; ++cpu_index ) {
-    Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
+    _ISR_lock_Set_name( &cpu->Lock, "Per-CPU" );
     _ISR_lock_Set_name( &cpu->Watchdog.Lock, "Watchdog" );
-    _SMP_ticket_lock_Initialize( &cpu->Lock );
-    _SMP_lock_Stats_initialize( &cpu->Lock_stats, "Per-CPU" );
     _Chain_Initialize_empty( &cpu->Threads_in_need_for_help );
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index 55dc437eaf..65951cccfe 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -158,27 +158,30 @@ static ISR_Level _Thread_Preemption_intervention(
   level = _Thread_Check_pinning( executing, cpu_self, level );
   while ( !_Chain_Is_empty( &cpu_self->Threads_in_need_for_help ) ) {
-    Chain_Node       *node;
-    Thread_Control   *the_thread;
+    Chain_Node     *node;
+    Thread_Control *the_thread;
     node = _Chain_Get_first_unprotected( &cpu_self->Threads_in_need_for_help );
     _Chain_Set_off_chain( node );
     the_thread = THREAD_OF_SCHEDULER_HELP_NODE( node );
     _Thread_State_acquire( the_thread, &lock_context );
     _Thread_Ask_for_help( the_thread );
     _Thread_State_release( the_thread, &lock_context );
 #else
   (void) cpu_self;
 #endif
diff --git a/cpukit/score/src/userextaddset.c b/cpukit/score/src/userextaddset.c
index 585712e043..2b13dfad62 100644
--- a/cpukit/score/src/userextaddset.c
+++ b/cpukit/score/src/userextaddset.c
@@ -41,17 +41,15 @@ void _User_extensions_Add_set(
   if ( the_extension->Callouts.thread_switch != NULL ) {
-    ISR_Level level;
     the_extension->Switch.thread_switch =
       the_extension->Callouts.thread_switch;
-    _Per_CPU_Acquire_all( level );
+    _Per_CPU_Acquire_all( &lock_context );
     _Chain_Initialize_node( &the_extension->Switch.Node );
       &_User_extensions_Switches_list,
-    _Per_CPU_Release_all( level );
+    _Per_CPU_Release_all( &lock_context );
diff --git a/cpukit/score/src/userextremoveset.c b/cpukit/score/src/userextremoveset.c
index adaf049677..4eb13f0c55 100644
--- a/cpukit/score/src/userextremoveset.c
+++ b/cpukit/score/src/userextremoveset.c
@@ -41,10 +41,10 @@ void _User_extensions_Remove_set (
-    ISR_Level level;
     _Chain_Extract_unprotected( &the_extension->Switch.Node );
2.16.4
