[PATCH 5/6] score: Rework SMP multicast action
Thu Apr 11 13:45:39 UTC 2019
 cpukit/include/rtems/score/percpu.h       |  32 +++++
 cpukit/include/rtems/score/smpimpl.h      |  13 +-
 cpukit/score/src/smpmulticastaction.c     | 203 +++++++++++++++++++-----------
 testsuites/smptests/smpcache01/init.c     |   5 +-
 testsuites/smptests/smpmulticast01/init.c |   3 +
 5 files changed, 170 insertions(+), 86 deletions(-)
diff --git a/cpukit/include/rtems/score/percpu.h b/cpukit/include/rtems/score/percpu.h
index d7232c632f..a0eb46c045 100644
--- a/cpukit/include/rtems/score/percpu.h
+++ b/cpukit/include/rtems/score/percpu.h
@@ -74,6 +74,8 @@ struct _Thread_Control;
 struct Scheduler_Context;
+struct Per_CPU_Job;
  *  @defgroup PerCPU RTEMS Per CPU Information
@@ -494,6 +496,29 @@ typedef struct Per_CPU_Control {
     Atomic_Uintptr before_multitasking_action;
+     * @brief FIFO list of jobs to be performed by this processor.
+     * The members are protected by the Per_CPU_Control::Lock lock.
+     * @see _SMP_Multicast_action().
+    struct {
+       * @brief Head of the FIFO list of jobs to be performed by this
+       * processor.
+      struct Per_CPU_Job *head;
+       * @brief Tail of the FIFO list of jobs to be performed by this
+       * processor.
+       * This member is only valid if the head is not @c NULL.
+      struct Per_CPU_Job **tail;
+    } Jobs;
      * @brief Indicates if the processor has been successfully started via
      * _CPU_SMP_Start_processor().
@@ -710,6 +735,13 @@ bool _Per_CPU_State_wait_for_non_initial_state(
   uint32_t timeout_in_ns
+ * @brief Performs the jobs of the specified processor.
+ * @param[in, out] cpu The jobs of this processor will be performed.
+void _Per_CPU_Perform_jobs( Per_CPU_Control *cpu );
 #endif /* defined( RTEMS_SMP ) */
diff --git a/cpukit/include/rtems/score/smpimpl.h b/cpukit/include/rtems/score/smpimpl.h
index 6b59b9497d..a501339176 100644
--- a/cpukit/include/rtems/score/smpimpl.h
+++ b/cpukit/include/rtems/score/smpimpl.h
@@ -51,11 +51,11 @@ extern "C" {
 #define SMP_MESSAGE_TEST 0x2UL
- * @brief SMP message to request a multicast action.
+ * @brief SMP message to perform per-CPU jobs.
  * @see _SMP_Send_message().
-#define SMP_MESSAGE_MULTICAST_ACTION 0x4UL
+#define SMP_MESSAGE_PERFORM_JOBS 0x4UL
  * @brief SMP message to request a clock tick.
@@ -157,11 +157,6 @@ static inline void _SMP_Set_test_message_handler(
   _SMP_Test_message_handler = handler;
- * @brief Processes all pending multicast actions.
-void _SMP_Multicast_actions_process( void );
  * @brief Interrupt handler for inter-processor interrupts.
@@ -195,8 +190,8 @@ static inline long unsigned _SMP_Inter_processor_interrupt_handler(
       ( *_SMP_Test_message_handler )( cpu_self );
-    if ( ( message & SMP_MESSAGE_MULTICAST_ACTION ) != 0 ) {
-      _SMP_Multicast_actions_process();
+    if ( ( message & SMP_MESSAGE_PERFORM_JOBS ) != 0 ) {
+      _Per_CPU_Perform_jobs( cpu_self );
diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
index 0b9641c3db..2288dbe939 100644
--- a/cpukit/score/src/smpmulticastaction.c
+++ b/cpukit/score/src/smpmulticastaction.c
@@ -1,91 +1,151 @@
- * Copyright (c) 2014 Aeroflex Gaisler AB.  All rights reserved.
+ * SPDX-License-Identifier: BSD-2-Clause
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * Copyright (C) 2019 embedded brains GmbH
+ * are met:
 #ifdef HAVE_CONFIG_H
-  #include "config.h"
+#include "config.h"
 #endif
 #include <rtems/score/smpimpl.h>
-#include <rtems/score/isrlock.h>
-#include <rtems/score/chainimpl.h>
+#include <rtems/score/threaddispatch.h>
 #include <rtems/score/sysstate.h>
-typedef struct {
-  Chain_Node          Node;
+typedef struct Per_CPU_Job {
+  struct Per_CPU_Job *next;
   SMP_Action_handler  handler;
   void               *arg;
-  Processor_mask      targets;
-  Atomic_Ulong        done;
-} SMP_Multicast_action;
+  Atomic_Uint         done;
+} Per_CPU_Job;
+  ISR_lock_Context  lock_context;
+  Per_CPU_Job      *job;
+  _ISR_lock_ISR_disable( &lock_context );
+  _Per_CPU_Acquire( cpu, &lock_context );
-typedef struct {
-  ISR_lock_Control Lock;
-  Chain_Control    Actions;
-} SMP_Multicast_context;
+  while ( ( job = cpu->Jobs.head ) != NULL ) {
+    cpu->Jobs.head = job->next;
+    _Per_CPU_Release( cpu, &lock_context );
+     _ISR_lock_ISR_enable( &lock_context );
-static SMP_Multicast_context _SMP_Multicast = {
-  .Lock = ISR_LOCK_INITIALIZER( "SMP Multicast Action" ),
-  .Actions = CHAIN_INITIALIZER_EMPTY( _SMP_Multicast.Actions )
+    ( *job->handler )( job->arg );
+    _Atomic_Store_uint( &job->done, 1, ATOMIC_ORDER_RELEASE );
+static void _Per_CPU_Try_perform_jobs( Per_CPU_Control *cpu_self )
-  ISR_lock_Context      lock_context;
-  uint32_t              cpu_self_index;
-  SMP_Multicast_action *node;
-  SMP_Multicast_action *next;
+  unsigned long message;
-  _ISR_lock_ISR_disable_and_acquire( &_SMP_Multicast.Lock, &lock_context );
-  cpu_self_index = _SMP_Get_current_processor();
-  node = (SMP_Multicast_action *) _Chain_First( &_SMP_Multicast.Actions );
+  message = _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED );
-  while ( !_Chain_Is_tail( &_SMP_Multicast.Actions, &node->Node ) ) {
-    next = (SMP_Multicast_action *) _Chain_Next( &node->Node );
+    bool success;
-    if ( _Processor_mask_Is_set( &node->targets, cpu_self_index ) ) {
-      _Processor_mask_Clear( &node->targets, cpu_self_index );
+    success = _Atomic_Compare_exchange_ulong(
+      &cpu_self->message, &message,
+      message & ~SMP_MESSAGE_PERFORM_JOBS, ATOMIC_ORDER_RELAXED,
+      ATOMIC_ORDER_RELAXED
-      ( *node->handler )( node->arg );
+    if ( success ) {
-      if ( _Processor_mask_Is_zero( &node->targets ) ) {
-        _Chain_Extract_unprotected( &node->Node );
-        _Atomic_Store_ulong( &node->done, 1, ATOMIC_ORDER_RELEASE );
+static void _SMP_Issue_action_jobs(
+  const Processor_mask *targets,
+  SMP_Action_handler    handler,
+  void                 *arg,
+  Per_CPU_Job          *jobs,
+  uint32_t              cpu_max
+  uint32_t cpu_index;
+  for ( cpu_index = 0; cpu_index < cpu_max; ++cpu_index ) {
+    if ( _Processor_mask_Is_set( targets, cpu_index ) ) {
+      Per_CPU_Job      *job;
+      Per_CPU_Control  *cpu;
+      job = &jobs[ cpu_index ];
+      job->next = NULL;
+      job->handler = handler;
+      job->arg = arg;
+      _Atomic_Store_uint( &job->done, 0, ATOMIC_ORDER_RELAXED );
+      cpu = _Per_CPU_Get_by_index( cpu_index );
+      if ( cpu->Jobs.head == NULL ) {
+        cpu->Jobs.head = job;
+      } else {
+        *cpu->Jobs.tail = job;
-    node = next;
+      cpu->Jobs.tail = &job->next;
-  _ISR_lock_Release_and_ISR_enable( &_SMP_Multicast.Lock, &lock_context );
+      _SMP_Send_message( cpu_index, SMP_MESSAGE_PERFORM_JOBS );
-static void
-_SMP_Multicasts_try_process( void )
+static void _SMP_Wait_for_action_jobs(
+  const Per_CPU_Job    *jobs,
+  uint32_t              cpu_max,
+  Per_CPU_Control      *cpu_self
-  unsigned long message;
-  Per_CPU_Control *cpu_self;
-  ISR_Level isr_level;
-  _ISR_Local_disable( isr_level );
+      const Per_CPU_Job *job;
-  cpu_self = _Per_CPU_Get();
-  message = _Atomic_Load_ulong( &cpu_self->message, ATOMIC_ORDER_RELAXED );
-  if ( message & SMP_MESSAGE_MULTICAST_ACTION ) {
-    if ( _Atomic_Compare_exchange_ulong( &cpu_self->message, &message,
-        message & ~SMP_MESSAGE_MULTICAST_ACTION, ATOMIC_ORDER_RELAXED,
-        ATOMIC_ORDER_RELAXED ) ) {
+      while ( _Atomic_Load_uint( &job->done, ATOMIC_ORDER_ACQUIRE ) == 0 ) {
+        _Per_CPU_Try_perform_jobs( cpu_self );
-  _ISR_Local_enable( isr_level );
 void _SMP_Multicast_action(
@@ -94,33 +154,24 @@ void _SMP_Multicast_action(
   void                 *arg
-  SMP_Multicast_action node;
-  uint32_t             i;
+  Per_CPU_Job      jobs[ CPU_MAXIMUM_PROCESSORS ];
+  uint32_t         cpu_max;
+  Per_CPU_Control *cpu_self;
+  cpu_max = _SMP_Get_processor_maximum();
+  _Assert( cpu_max <= CPU_MAXIMUM_PROCESSORS );
   if ( ! _System_state_Is_up( _System_state_Get() ) ) {
     ( *handler )( arg );
     return;
-  if( targets == NULL ) {
+  if ( targets == NULL ) {
     targets = _SMP_Get_online_processors();
-  _Chain_Initialize_node( &node.Node );
-  node.handler = handler;
-  node.arg = arg;
-  _Processor_mask_Assign( &node.targets, targets );
-  _Atomic_Store_ulong( &node.done, 0, ATOMIC_ORDER_RELAXED );
-  _Chain_Prepend_unprotected( &_SMP_Multicast.Actions, &node.Node );
-  _SMP_Send_message_multicast( targets, SMP_MESSAGE_MULTICAST_ACTION );
-  _SMP_Multicasts_try_process();
-  while ( _Atomic_Load_ulong( &node.done, ATOMIC_ORDER_ACQUIRE ) == 0 ) {
-    /* Wait */
+  cpu_self = _Thread_Dispatch_disable();
+  _SMP_Issue_action_jobs( targets, handler, arg, jobs, cpu_max );
+  _SMP_Wait_for_action_jobs( targets, jobs, cpu_max, cpu_self );
+  _Thread_Dispatch_enable( cpu_self );
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index 878a015bf1..e9cee1eec5 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -126,12 +126,15 @@ static void call_tests_isr_disabled( SMP_barrier_State *bs )
   broadcast_test_init();
   for (i = 0; i < RTEMS_ARRAY_SIZE( test_cases ); ++i) {
+    ISR_Level        isr_level;
     barrier( bs );
     ( *test_cases[ i ] )();
     barrier( bs );
diff --git a/testsuites/smptests/smpmulticast01/init.c b/testsuites/smptests/smpmulticast01/init.c
index 2319582ab6..e599a78bde 100644
--- a/testsuites/smptests/smpmulticast01/init.c
+++ b/testsuites/smptests/smpmulticast01/init.c
@@ -59,11 +59,14 @@ static void multicast_action_irq_disabled(
   void *arg
   rtems_interrupt_level level;
   rtems_interrupt_local_disable(level);
   _SMP_Multicast_action(targets, handler, arg);
   rtems_interrupt_local_enable(level);
+  _Thread_Dispatch_enable(cpu_self);
 static void multicast_action_dispatch_disabled(
2.16.4
