[PATCH 4/6] score: Use processor mask in _SMP_Multicast_action
Thu Apr 11 13:45:38 UTC 2019
Processor_mask is the internal data type to deal with processor sets.
 bsps/shared/cache/cacheimpl.h                      |   4 +-
 cpukit/include/rtems/score/smpimpl.h               |  19 +-
 cpukit/score/src/smpmulticastaction.c              |  24 +-
 testsuites/smptests/Makefile.am                    |  11 +
 testsuites/smptests/configure.ac                   |   1 +
 testsuites/smptests/smpcache01/init.c              |  58 ++---
 testsuites/smptests/smpmulticast01/init.c          | 288 +++++++++++++++++++++
 .../smptests/smpmulticast01/smpmulticast01.doc     |  12 +
 .../smptests/smpmulticast01/smpmulticast01.scn     |  54 ++++
 9 files changed, 404 insertions(+), 67 deletions(-)
 create mode 100644 testsuites/smptests/smpmulticast01/init.c
 create mode 100644 testsuites/smptests/smpmulticast01/smpmulticast01.doc
 create mode 100644 testsuites/smptests/smpmulticast01/smpmulticast01.scn
diff --git a/bsps/shared/cache/cacheimpl.h b/bsps/shared/cache/cacheimpl.h
index cb7f02d4ec..dbed9c8a19 100644
--- a/bsps/shared/cache/cacheimpl.h
+++ b/bsps/shared/cache/cacheimpl.h
@@ -329,7 +329,7 @@ rtems_cache_invalidate_multiple_instruction_lines(
 #if defined(RTEMS_SMP) && defined(CPU_CACHE_NO_INSTRUCTION_CACHE_SNOOPING)
   smp_cache_area area = { i_addr, n_bytes };
-  _SMP_Multicast_action( 0, NULL, smp_cache_inst_inv, &area );
+  _SMP_Multicast_action( NULL, smp_cache_inst_inv, &area );
 #else
   _CPU_cache_invalidate_instruction_range( i_addr, n_bytes );
 #endif
@@ -345,7 +345,7 @@ rtems_cache_invalidate_entire_instruction( void )
 #if defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
-  _SMP_Multicast_action( 0, NULL, smp_cache_inst_inv_all, NULL );
+  _SMP_Multicast_action( NULL, smp_cache_inst_inv_all, NULL );
 #else
  _CPU_cache_invalidate_entire_instruction();
 #endif
diff --git a/cpukit/include/rtems/score/smpimpl.h b/cpukit/include/rtems/score/smpimpl.h
index 117b78cb74..6b59b9497d 100644
--- a/cpukit/include/rtems/score/smpimpl.h
+++ b/cpukit/include/rtems/score/smpimpl.h
@@ -249,20 +249,19 @@ void _SMP_Send_message_multicast(
 typedef void ( *SMP_Action_handler )( void *arg );
- *  @brief Initiates an SMP multicast action to a set of processors.
+ * @brief Initiates an SMP multicast action to a set of target processors.
- *  The current processor may be part of the set.
+ * The current processor may be part of the set.
- *  @param[in] setsize The size of the set of target processors of the message.
- *  @param[in] cpus The set of target processors of the message.
- *  @param[in] handler The multicast action handler.
- *  @param[in] arg The multicast action argument.
+ * @param targets The set of target processors for the action.  If @c NULL,
+ *   then the action will be performed on all online processors.
+ * @param handler The multicast action handler.
+ * @param arg The multicast action argument.
 void _SMP_Multicast_action(
-  const size_t setsize,
-  const cpu_set_t *cpus,
-  SMP_Action_handler handler,
-  void *arg
+  const Processor_mask *targets,
+  SMP_Action_handler    handler,
+  void                 *arg
diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
index 0cf675f795..0b9641c3db 100644
--- a/cpukit/score/src/smpmulticastaction.c
+++ b/cpukit/score/src/smpmulticastaction.c
@@ -89,14 +89,12 @@ _SMP_Multicasts_try_process( void )
-  void *arg
+  void                 *arg
   SMP_Multicast_action node;
-  Processor_mask       targets;
   ISR_lock_Context     lock_context;
   uint32_t             i;
@@ -105,29 +103,21 @@ void _SMP_Multicast_action(
     return;
-  if( cpus == NULL ) {
-    _Processor_mask_Assign( &targets, _SMP_Get_online_processors() );
-  } else {
-    _Processor_mask_Zero( &targets );
-    for ( i = 0; i < _SMP_Get_processor_maximum(); ++i ) {
-      if ( CPU_ISSET_S( i, setsize, cpus ) ) {
-        _Processor_mask_Set( &targets, i );
+  if( targets == NULL ) {
+    targets = _SMP_Get_online_processors();
   _Chain_Initialize_node( &node.Node );
   node.handler = handler;
   node.arg = arg;
-  _Processor_mask_Assign( &node.targets, &targets );
+  _Processor_mask_Assign( &node.targets, targets );
   _Atomic_Store_ulong( &node.done, 0, ATOMIC_ORDER_RELAXED );
   _ISR_lock_ISR_disable_and_acquire( &_SMP_Multicast.Lock, &lock_context );
   _Chain_Prepend_unprotected( &_SMP_Multicast.Actions, &node.Node );
   _ISR_lock_Release_and_ISR_enable( &_SMP_Multicast.Lock, &lock_context );
-  _SMP_Send_message_multicast( &targets, SMP_MESSAGE_MULTICAST_ACTION );
+  _SMP_Send_message_multicast( targets, SMP_MESSAGE_MULTICAST_ACTION );
   _SMP_Multicasts_try_process();
   while ( _Atomic_Load_ulong( &node.done, ATOMIC_ORDER_ACQUIRE ) == 0 ) {
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 01076abaa9..38cc87e3c5 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -314,6 +314,17 @@ smpmrsp01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_smpmrsp01) \
 endif
 endif
+if HAS_SMP
+if TEST_smpmulticast01
+smp_tests += smpmulticast01
+smp_screens += smpmulticast01/smpmulticast01.scn
+smp_docs += smpmulticast01/smpmulticast01.doc
+smpmulticast01_SOURCES = smpmulticast01/init.c
+smpmulticast01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_smpmulticast01) \
+	$(support_includes)
+endif
+endif
 if HAS_SMP
 if TEST_smpmutex01
 smp_tests += smpmutex01
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index b3fca201b2..83b5b9fe41 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -60,6 +60,7 @@ RTEMS_TEST_CHECK([smplock01])
 RTEMS_TEST_CHECK([smpmigration01])
 RTEMS_TEST_CHECK([smpmigration02])
 RTEMS_TEST_CHECK([smpmrsp01])
+RTEMS_TEST_CHECK([smpmulticast01])
 RTEMS_TEST_CHECK([smpmutex01])
 RTEMS_TEST_CHECK([smpmutex02])
 RTEMS_TEST_CHECK([smpopenmp01])
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index 313a3df2e4..878a015bf1 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -50,23 +50,14 @@ static void test_action( void *arg )
   ctx.count[rtems_scheduler_get_processor()]++;
-typedef void ( *test_case )(
-  size_t set_size,
-  const cpu_set_t *cpu_set
-static void test_cache_invalidate_entire_instruction(
-  size_t set_size,
+typedef void ( *test_case )( void );
+static void test_cache_invalidate_entire_instruction( void )
   rtems_cache_invalidate_entire_instruction();
-static void test_cache_invalidate_multiple_instruction_lines(
-  size_t set_size,
+static void test_cache_invalidate_multiple_instruction_lines( void )
   uint32_t self = rtems_scheduler_get_processor();
@@ -94,12 +85,9 @@ static void broadcast_test_init( void )
   ctx.count[rtems_scheduler_get_processor()] = 0;
-static void broadcast_test_body(
-  size_t set_size,
+static void broadcast_test_body( void )
-  _SMP_Multicast_action( set_size, cpu_set, test_action, &ctx );
+  _SMP_Multicast_action( NULL, test_action, &ctx );
 static void broadcast_test_fini( void )
@@ -116,8 +104,7 @@ static test_case test_cases[] = {
   broadcast_test_body
-static void call_tests( size_t set_size,
-    const cpu_set_t *cpu_set, SMP_barrier_State *bs  )
+static void call_tests( SMP_barrier_State *bs )
   size_t i;
@@ -125,15 +112,14 @@ static void call_tests( size_t set_size,
   for (i = 0; i < RTEMS_ARRAY_SIZE( test_cases ); ++i) {
     barrier( bs );
-    ( *test_cases[ i ] )( set_size, cpu_set );
+    ( *test_cases[ i ] )();
     barrier( bs );
   broadcast_test_fini();
-static void call_tests_isr_disabled( size_t set_size,
+static void call_tests_isr_disabled( SMP_barrier_State *bs )
   size_t i;
@@ -144,7 +130,7 @@ static void call_tests_isr_disabled( size_t set_size,
     _ISR_Local_disable( isr_level );
     barrier( bs );
     _ISR_Local_enable( isr_level );
     barrier( bs );
@@ -152,8 +138,7 @@ static void call_tests_isr_disabled( size_t set_size,
-static void call_tests_with_thread_dispatch_disabled( size_t set_size,
+static void call_tests_with_thread_dispatch_disabled( SMP_barrier_State *bs )
   size_t i;
@@ -164,7 +149,7 @@ static void call_tests_with_thread_dispatch_disabled( size_t set_size,
     cpu_self = _Thread_Dispatch_disable();
     barrier( bs );
     barrier( bs );
     _Thread_Dispatch_enable( cpu_self );
@@ -180,32 +165,29 @@ static void cmlog(  const char* str )
 static void all_tests( void )
-  uint32_t cpu_count = rtems_scheduler_get_processor_maximum();
-  size_t set_size = CPU_ALLOC_SIZE( cpu_count );
-  cpu_set_t *cpu_set = CPU_ALLOC( cpu_count );
   SMP_barrier_State bs = SMP_BARRIER_STATE_INITIALIZER;
-  /* Send message to all available CPUs */
-  CPU_FILL_S( set_size, cpu_set );
   /* Call test cases */
   cmlog( "Calling test cases. " );
-  call_tests( set_size, cpu_set, &bs );
+  call_tests( &bs );
   cmlog( "Done!\n");
   /* Call test cases with ISR disabled */
   cmlog( "Calling test cases with ISR disabled. " );
-  call_tests_isr_disabled( set_size, cpu_set, &bs );
+  call_tests_isr_disabled( &bs );
   cmlog( "Done!\n" );
   /* Call test cases with thread dispatch disabled */
   cmlog( "Calling test cases with thread_dispatch_disabled. ");
-  call_tests_with_thread_dispatch_disabled( set_size, cpu_set, &bs );
+  call_tests_with_thread_dispatch_disabled( &bs );
   cmlog( "Done!\n");
   /* Done. Free up memory. */
-  _SMP_barrier_Wait( &ctx.barrier, &bs, cpu_count);
-  CPU_FREE( cpu_set );
+  _SMP_barrier_Wait(
+    &ctx.barrier,
+    &bs,
+    rtems_scheduler_get_processor_maximum()
 static void worker_task(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpmulticast01/init.c b/testsuites/smptests/smpmulticast01/init.c
new file mode 100644
index 0000000000..2319582ab6
--- /dev/null
+++ b/testsuites/smptests/smpmulticast01/init.c
@@ -0,0 +1,288 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 embedded brains GmbH
+ * are met:
+#include <rtems/score/smpimpl.h>
+#include <rtems/score/atomic.h>
+#include <rtems/score/threaddispatch.h>
+#include <rtems/sysinit.h>
+#include <rtems.h>
+#include <string.h>
+#include <t.h>
+#include <tmacros.h>
+#define CPU_COUNT 32
+const char rtems_test_name[] = "SMPMULTICAST 1";
+static const T_config config = {
+  .name = "SMPMultiCast",
+  .putchar = T_putchar_default,
+  .verbosity = T_VERBOSE,
+  .now = T_now
+typedef struct {
+  Atomic_Uint id[CPU_COUNT];
+} test_context;
+static test_context test_instance;
+static void multicast_action_irq_disabled(
+  void *arg
+  rtems_interrupt_level level;
+  rtems_interrupt_local_disable(level);
+  _SMP_Multicast_action(targets, handler, arg);
+  rtems_interrupt_local_enable(level);
+static void multicast_action_dispatch_disabled(
+  void *arg
+  Per_CPU_Control *cpu_self;
+  cpu_self = _Thread_Dispatch_disable();
+  _Thread_Dispatch_enable(cpu_self);
+static void action(void *arg)
+  test_context *ctx;
+  uint32_t self;
+  unsigned expected;
+  bool success;
+  ctx = arg;
+  self = rtems_scheduler_get_processor();
+  expected = 0;
+  success = _Atomic_Compare_exchange_uint(
+    &ctx->id[self],
+    &expected,
+    self + 1,
+    ATOMIC_ORDER_RELAXED,
+  T_quiet_true(success, "set CPU identifier failed");
+static void test_unicast(
+  test_context *ctx,
+  void (*multicast_action)(const Processor_mask *, SMP_Action_handler, void *),
+  bool before_multitasking
+  uint32_t step;
+  uint32_t i;
+  uint32_t n;
+  uint32_t self;
+  T_plan(1);
+  step = 0;
+  n = rtems_scheduler_get_processor_maximum();
+  for (i = 0; i < n; ++i) {
+    Processor_mask cpus;
+    uint32_t j;
+    memset(ctx, 0, sizeof(*ctx));
+    _Processor_mask_Zero(&cpus);
+    _Processor_mask_Set(&cpus, i);
+    (*multicast_action)(&cpus, action, ctx);
+    for (j = 0; j < n; ++j) {
+      unsigned id;
+      ++step;
+      id = _Atomic_Load_uint(&ctx->id[j], ATOMIC_ORDER_RELAXED);
+      if (before_multitasking) {
+        if (j == self) {
+          T_quiet_eq_uint(j + 1, id);
+        } else {
+          T_quiet_eq_uint(0, id);
+      } else {
+        if (j == i) {
+        } else {
+  T_step_eq_u32(0, step, n * n);
+static void test_broadcast(
+  uint32_t step;
+  uint32_t i;
+  uint32_t n;
+  uint32_t self;
+  T_plan(1);
+  step = 0;
+    uint32_t j;
+    (*multicast_action)(NULL, action, ctx);
+      unsigned id;
+      ++step;
+        if (j == self) {
+        } else {
+      } else {
+static void test_before_multitasking(void)
+  ctx = &test_instance;
+  T_case_begin("UnicastBeforeMultitasking", NULL);
+  test_unicast(ctx, _SMP_Multicast_action, true);
+  T_case_end();
+  T_case_begin("UnicastBeforeMultitaskingIRQDisabled", NULL);
+  test_unicast(ctx, multicast_action_irq_disabled, true);
+  T_case_end();
+  T_case_begin("UnicastBeforeMultitaskingDispatchDisabled", NULL);
+  test_unicast(ctx, multicast_action_dispatch_disabled, true);
+  T_case_end();
+  T_case_begin("BroadcastBeforeMultitasking", NULL);
+  test_broadcast(ctx, _SMP_Multicast_action, true);
+  T_case_end();
+  T_case_begin("BroadcastBeforeMultitaskingIRQDisabled", NULL);
+  test_broadcast(ctx, multicast_action_irq_disabled, true);
+  T_case_end();
+  T_case_begin("BroadcastBeforeMultitaskingDispatchDisabled", NULL);
+  test_broadcast(ctx, multicast_action_dispatch_disabled, true);
+  T_case_end();
+static void after_drivers(void)
+  TEST_BEGIN();
+  T_run_initialize(&config);
+  test_before_multitasking();
+RTEMS_SYSINIT_ITEM(
+  after_drivers,
+  RTEMS_SYSINIT_DEVICE_DRIVERS,
+  RTEMS_SYSINIT_ORDER_LAST
+static void Init(rtems_task_argument arg)
+  bool ok;
+  T_case_begin("UnicastDuringMultitasking", NULL);
+  test_unicast(ctx, _SMP_Multicast_action, false);
+  T_case_end();
+  T_case_begin("UnicastDuringMultitaskingIRQDisabled", NULL);
+  test_unicast(ctx, multicast_action_irq_disabled, false);
+  T_case_end();
+  T_case_begin("UnicastDuringMultitaskingDispatchDisabled", NULL);
+  test_unicast(ctx, multicast_action_dispatch_disabled, false);
+  T_case_end();
+  T_case_begin("BroadcastDuringMultitasking", NULL);
+  test_broadcast(ctx, _SMP_Multicast_action, false);
+  T_case_end();
+  T_case_begin("BroadcastDuringMultitaskingIRQDisabled", NULL);
+  test_broadcast(ctx, multicast_action_irq_disabled, false);
+  T_case_end();
+  T_case_begin("BroadcastDuringMultitaskingDispatchDisabled", NULL);
+  test_broadcast(ctx, multicast_action_dispatch_disabled, false);
+  T_case_end();
+  ok = T_run_finalize();
+  rtems_test_assert(ok);
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smpmulticast01/smpmulticast01.doc b/testsuites/smptests/smpmulticast01/smpmulticast01.doc
index 0000000000..da6580028f
--- /dev/null
+++ b/testsuites/smptests/smpmulticast01/smpmulticast01.doc
@@ -0,0 +1,12 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smpmulticast01
+directives:
+  - _SMP_Multicast_action()
+concepts:
+  - Ensure that _SMP_Multicast_action() works before multitasking.
+  - Ensure that _SMP_Multicast_action() works during multitasking.
diff --git a/testsuites/smptests/smpmulticast01/smpmulticast01.scn b/testsuites/smptests/smpmulticast01/smpmulticast01.scn
index 0000000000..ea532fdead
--- /dev/null
+++ b/testsuites/smptests/smpmulticast01/smpmulticast01.scn
@@ -0,0 +1,54 @@
+*** BEGIN OF TEST SMPMULTICAST 1 ***
+*** TEST VERSION: 5.0.0.c44199ccea624f31b1116fa2e47d547944e90909-modified
+*** TEST STATE: EXPECTED-PASS
+*** TEST BUILD: RTEMS_POSIX_API RTEMS_SMP
+*** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB e0aec65182449a4e22b820e773087636edaf5b32, Newlib 1d35a003f)
+A:SMPMultiCast
+S:Platform:RTEMS
+S:Compiler:7.4.0 20181206 (RTEMS 5, RSB e0aec65182449a4e22b820e773087636edaf5b32, Newlib 1d35a003f)
+S:Version:5.0.0.c44199ccea624f31b1116fa2e47d547944e90909
+S:BSP:qoriq_e6500_32
+S:RTEMS_DEBUG:0
+S:RTEMS_MULTIPROCESSING:0
+S:RTEMS_POSIX_API:1
+S:RTEMS_PROFILING:0
+S:RTEMS_SMP:1
+B:UnicastBeforeMultitasking
+P:0:0:IDLE:init.c:150
+E:UnicastBeforeMultitasking:N:1:F:0:D:0.001999
+B:UnicastBeforeMultitaskingIRQDisabled
+E:UnicastBeforeMultitaskingIRQDisabled:N:1:F:0:D:0.001999
+B:UnicastBeforeMultitaskingDispatchDisabled
+E:UnicastBeforeMultitaskingDispatchDisabled:N:1:F:0:D:0.001999
+B:BroadcastBeforeMultitasking
+P:0:0:IDLE:init.c:194
+E:BroadcastBeforeMultitasking:N:1:F:0:D:0.001999
+B:BroadcastBeforeMultitaskingIRQDisabled
+E:BroadcastBeforeMultitaskingIRQDisabled:N:1:F:0:D:0.001999
+B:BroadcastBeforeMultitaskingDispatchDisabled
+E:BroadcastBeforeMultitaskingDispatchDisabled:N:1:F:0:D:0.001999
+B:UnicastDuringMultitasking
+P:0:23:UI1:init.c:150
+E:UnicastDuringMultitasking:N:1:F:0:D:0.001999
+B:UnicastDuringMultitaskingIRQDisabled
+E:UnicastDuringMultitaskingIRQDisabled:N:1:F:0:D:0.002000
+B:UnicastDuringMultitaskingDispatchDisabled
+E:UnicastDuringMultitaskingDispatchDisabled:N:1:F:0:D:0.002000
+B:BroadcastDuringMultitasking
+P:0:23:UI1:init.c:194
+E:BroadcastDuringMultitasking:N:1:F:0:D:0.002134
+B:BroadcastDuringMultitaskingIRQDisabled
+E:BroadcastDuringMultitaskingIRQDisabled:N:1:F:0:D:0.002165
+B:BroadcastDuringMultitaskingDispatchDisabled
+E:BroadcastDuringMultitaskingDispatchDisabled:N:1:F:0:D:0.002130
+Z:SMPMultiCast:C:12:N:12:F:0:D:0.125615
+*** END OF TEST SMPMULTICAST 1 ***
2.16.4
