[rtems-test] powerpc/psim: RTEMS_POSIX_API: Passed:560 Failed:14 Timeout:5 Invalid:0 Wrong:0
Joel Sherrill
joel at rtems.org
Thu Apr 11 22:40:36 UTC 2019
On Thu, Apr 11, 2019 at 5:35 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Apr 11, 2019 at 5:16 PM Chris Johns <chrisj at rtems.org> wrote:
>> Hi Joel,
>> Thank you for running these tests and publishing the results.
> :) I'm trying to build up my "rtems-cron" script. Not the fanciest way to
> decide when to test things but it will know how to test them.
> It will eventually run Coverity
> Any advice on knowing in a script if git needs to update a repo or a pull
> updated? I thought this would work but it didn't show the rtems updates
> today:
> git rev-list HEAD...origin/master --count
>> On 12/4/19 8:10 am, joel at rtems.org wrote:
>> > Testing time : 0:10:37.757133
>> > Average test time: 0:00:01.084621
>> > Host
>> > Linux-3.10.0-862.11.6.el7.x86_64-x86_64-with-centos-7.5.1804-Core
>> (Linux rtbf64c.rtems.com 3.10.0-862.11.6.el7.x86_64 #1 SMP Tue Aug 14
>> 21:49:04 UTC 2018 x86_64 x86_64)
>> > Configuration
>> > Version: 5.0.0.ad87de4a67d8ce7e75d0b844efc03b98c3ecda1a
>> > Build : RTEMS_POSIX_API
>> > Tools : 7.4.0 20181206 (RTEMS 5, RSB
>> 9a3e12e5820918057633798c3fe2a1f952fb4e56, Newlib 1d35a003f)
>> > Summary
>> > Passed: 560
>> > Failed: 14
>> > User Input: 6
>> > Expected Fail: 0
>> > Indeterminate: 0
>> > Benchmark: 3
>> > Timeout: 5
>> > Invalid: 0
>> > Wrong Version: 0
>> > Wrong Build: 0
>> > Wrong Tools: 0
>> > Total: 588
>> > Failures:
>> > fsimfsgeneric01.exe
>> > block11.exe
>> > devfs02.exe
>> > rbheap01.exe
>> > termios01.exe
>> > psx12.exe
>> > psxchroot01.exe
>> > psximfs02.exe
>> > psxpipe01.exe
>> > spconfig02.exe
>> > spfatal31.exe
>> > spmountmgr01.exe
>> > spprivenv01.exe
>> > spstdthreads01.exe
>> > User Input:
>> > dl10.exe
>> > monitor.exe
>> > termios.exe
>> > top.exe
>> > capture.exe
>> > fileio.exe
>> > Benchmark:
>> > whetstone.exe
>> > dhrystone.exe
>> > linpack.exe
>> > Timeouts:
>> > fsrfsbitmap01.exe
>> > dl08.exe
>> > dl09.exe
>> The `dl.*` test timeouts look like the test is running too long and if
>> you have
>> a number of tests running at once this could be the reason.
> When run by hand, dl08 passes with this much time used:
> real 0m7.194s
> user 0m5.997s
> sys 0m0.703s
> dl09 is less. Those aren't very long. I don't know why they timeout with
> the tester.
> fsrfsbitmap01 is over 4.5 minutes of host CPU time and stuck here:
> 23. Cleared bit still set: bit = 126
> Testing bitmap_map functions with zero initialized bitmap control pointer
> Allocate most of memory - attempt to fail while open bitmap - expect
> ENOMEM
> I will let it continue overnight but this one is either hung or needs
> tweaking to
> consume most of memory a single large allocation and then force the the
> rfs bitmap error.
Of course it failed as soon as I sent that email.
ENOMEM
*** FATAL ***
fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
exception vector 3 (0x3)
next PC or address of fault = 0x0001980c
saved MSR = 0x0000a072
It had consumed over 5 minutes of host time when that happened.
This fault was in rtems_bdbuf_read() in the true case of this if:
if (rtems_bdbuf_is_read_ahead_active (dd))
doing chain operation.
--joel
>> I see a couple of possible solutions, adding timeout control to the tests
>> which
>> rtems-test can see of I can drop the loop count to 10. The loop count is
>> the
>> simplest.
>> The loop lets me see a repeating set of addresses being used so I can
>> check for
>> leaks.
> I don't think that's the issue. The dl tests run quickly by hand.
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190411/d76b4040/attachment.html>
