rtems-libbsd build error
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Apr 16 10:54:09 UTC 2019
Am 16.04.19 um 11:28 schrieb Vijay Kumar Banerjee:
> On Fri, Apr 12, 2019 at 9:16 PM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     Am 12.04.19 um 16:26 schrieb Vijay Kumar Banerjee:
>     > On Wed, Apr 10, 2019 at 12:50 PM Christian Mauderer
>     > <christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>
>     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>     >     Am 09.04.19 um 18:12 schrieb Vijay Kumar Banerjee:
>     >     > Hi,
>     >     > I have imported and ported the the drivers in 2 pairs(import
>     and port)
>     >     > of commits
>     >     > for each one. Please have a look at this branch
>     >     > https://github.com/thelunatic/rtems-libbsd/commits/tda19988
>     >     One detail: You have a commit named "tda19988.c: import from
>     FreeBSD".
>     >     Please remove the ".c".
>     > Noted.
>     >     Maybe it would be a good idea to split of the I2C part and put
>     it in
>     >     front of the other two parts. You can develop and test that
>     independent
>     >     with a test that just accesses some of the I2C devices on the
>     board via
>     >     the FreeBSD API and the translation driver discussed below.
>     > This is a good idea, I'll import iicbus separately and add the other
>     > two on top of it.
>     >     > I have also tried running the media01.exe and have seen it
>     running
>     >     fine
>     >     > without
>     >     > throwing any exceptions.
>     >     > I have used the fb.c and iicbus.c codes from the
>     freebsd source. From
>     >     > what I
>     >     > understand, I think the next big steps would be to write an
>     RTEMS
>     >     > implementation layer for these portions of the code? And then a
>     >     test in the
>     >     > libbsd, like media01, to write to the /dev/fb0
>     >     > Can you please help me chalk out a rough outline of the next
>     set of
>     >     > actions? :)
>     >     As far as I can tell, there are two possible I2C buses here:
>     >     1. The one between the AM335x and the TDA19988.
>     >     2. The one directly on the HDMI connector (called HDMI_DSCL and
>     >     HDMI_DSDA). I assume that's an I2C bus too.
>     >     For 1. the RTEMS driver should be used. You'll need some code that
>     >     translates the FreeBSD API to the one used in RTEMS. Basically
>     that will
>     >     just be a FreeBSD-I2C-driver.
>     >     For 2: If that even is an independent I2C bus, you can use the
>     driver
>     >     provided by FreeBSD. I don't think that it is necessary to
>     translate to
>     >     the RTEMS API here.
>     > I had a look at the iic and iicbus codes in freebsd and the bbb-i2c.c
>     > This looks very confusing to me. Are we looking for something like a
>     > rtems-iicbus.c in the rtemsbsd that works like a wrapper to the
>     bbb-i2c
>     > code, and uses the freebsd api of DEVMETHODs?
>     Yes correct. Basically it would be necessary to have a I2C device driver
>     for FreeBSD that translates to the RTEMS API.
>     > I've not been able to figure out at one look, how to relate them and
>     > get a wrapper like that. Any suggestions on how to approach this?
>     I haven't had a look at the FreeBSD drivers yet. The first part that I
>     would have a look at is the description of the user facing FreeBSD API:
>     https://www.freebsd.org/cgi/man.cgi?query=iic&apropos=0&sektion=0&manpath=FreeBSD+12.0-RELEASE+and+Ports&arch=default&format=html
>     Nice thing: They use a struct iic_msg that is compatible with Linux's
>     struct i2c_msg (according to the man page). We are Linux compatible too.
>     Can be a big advantage.
>     Then take a look at the simplest i2c driver that you can find in FreeBSD
>     that uses the transfer API.
>     freebsd-org/sys/dev/drm2/radeon/atombios_i2c.c looks good to me.
>     Basically you have to implement the following functions (replace
>     radeon_atom... by a useful prefix):
>     static device_method_t radeon_atom_hw_i2c_methods[] = {
>             DEVMETHOD(device_probe,         radeon_atom_hw_i2c_probe),
>             DEVMETHOD(device_attach,        radeon_atom_hw_i2c_attach),
>             DEVMETHOD(device_detach,        radeon_atom_hw_i2c_detach),
>             DEVMETHOD(iicbus_reset,         radeon_atom_hw_i2c_reset),
>             DEVMETHOD(iicbus_transfer,      radeon_atom_hw_i2c_xfer),
>             DEVMETHOD_END
>     The iicbus_transfer function seems to get a struct iic_msg as a
>     parameter. Now that's really lucky.
>     With that you should be able to open the i2c device in RTEMS and just
>     pass the structure via the correct ioctl call to the RTEMS driver.
>     Basically you just have to pass the bus to use as a parameter to the
>     driver. Take a look at some of the other drivers in nexus-devices.h that
>     have for example an address as a parameter to see how you can do that.
> This gave a good idea of the objective. :)
> I had a look at the  bbb-i2c.c code and how it's registering
> and setting up the i2c_bus struct with the transfer, set and destroy
> fucntions.
> I have a question from the fundamentals, the only function
> of bbb-i2c.c
> <https://git.rtems.org/rtems/tree/bsps/arm/beagle/i2c/bbb-i2c.c#n414>
> that is 'accessible' with the header file is am335x_i2c_bus_register
> which basically sets the i2c_bus struct
> and calls the i2c_bus_register function from the dev/i2c.c .
> To use the DEVMETHOD api, we need to be able to call the
> transfer, destroy etc. functions of the bbb-i2c.c from the translation
> layer in rtemsbsd. How do I #include the bbb-i2c.c in the new
> translation driver that I'll write?
> Hope my question is stated clearly, please correct me if I'm getting
> some fundamentals wrong.
You are not fundamentally wrong but slightly off:
Regarding the question how you access transfer, destroy, ... of the
driver directly: Don't.
You basically don't need to have a look at the bbb-i2c.c file of RTEMS
for that driver. Where you should have a look is the Linux I2C API
(which has been the model for the RTEMS API).
Basically your drivers transfer function will do about the following:
- Open "/dev/i2c0" (or some other path - that will be a parameter to the
driver and has to be stored by probe or attach in some device structure).
- Translate the "struct iic_msg" you get as an input to a "struct
i2c_msg". Most likely that's just a cast.
- Pass that via an ioctl call to the opened bus.
- Check return value and translate to the matching return of FreeBSD.
- Close "/dev/i2c0"
Some of the open / close might could move to attach / detach. But that
would be an optimization.
That driver will work on any BSP that implements the current i2c API. So
it's a generic translation layer.
Best regards
Christian
>     > Can we not totally use the iicbus in the freebsd source?
>     We already have a I2C driver for that BSP in RTEMS. If you would use the
>     FreeBSD code, they would fight for the hardware. Of course it would be
>     possible to replace the RTEMS driver by a FreeBSD one. But that would
>     potentially break some applications. Besides that I think that a lot of
>     RTEMS BSPs already have an I2C driver so a generic wrapper could be
>     helpful for other BSPs too.
>     >     > Thanks
>     >     > On Tue, Apr 9, 2019 at 5:28 AM Chris Johns <chrisj at rtems.org
>     <mailto:chrisj at rtems.org>
>     >     <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>
>     >     > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>
>     <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>>> wrote:
>     >     >     On 8/4/19 12:30 am, Vijay Kumar Banerjee wrote:
>     >     >     > On Sun, Apr 7, 2019 at 6:24 PM Christian Mauderer
>     >     >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
>     >     >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
>     >     >     >     Am 07.04.19 um 14:50 schrieb Vijay Kumar Banerjee:
>     >     >     >     > On Sun, Apr 7, 2019 at 6:08 PM Christian Mauderer
>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>     >     >     >     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
>     >     >     >     >     Am 07.04.19 um 14:35 schrieb Vijay Kumar
>     Banerjee:
>     >     >     >     >     > On Sun, Apr 7, 2019 at 5:37 PM Christian
>     Mauderer
>     >     >     >     >     <list at c-mauderer.de
>     >     >     >     >     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>> wrote:
>     >     >     >     >     >     Am 07.04.19 um 13:08 schrieb Vijay Kumar
>     >     Banerjee:
>     >     >     >     I don't think that there are a lot of docs for how
>     to test.
>     >     >     Although I'm
>     >     >     >     sure that there are some scripts to run a number
>     of libbsd
>     >     >     tests, I'm
>     >     >     >     not sure where. Maybe in the RTEMS tester but I think
>     >     that is
>     >     >     mainly for
>     >     >     >     the core tests?
>     >     >     The documentation for testing can be found here ...
>       https://docs.rtems.org/branches/master/user/testing/index.html
>     >     >     > so far I know, RTEMS Tester is only for core tests.
>     >     >     The `rtems-test` command checks the for test start and end
>     >     banners.
>     >     >     I am not
>     >     >     sure if libbsd supports the test banners. Maybe it could
>     now with
>     >     >     Sebastian's
>     >     >     movement of the test support code into libtest.
>     >     >     > I'll ask in the devel if there's some way to run
>     libbsd test
>     >     with
>     >     >     the tester.
>     >     >     There is the `rtems-run` command which has similar args to
>     >     >     `rtems-test`. It does
>     >     >     suffer from a limitation I have not fixed which is stdin
>     is not
>     >     >     passed through
>     >     >     to the console of the target. I also think the command has a
>     >     timeout
>     >     >     running,
>     >     >     but I am not sure about this one.
>     >     >     Chris
>     >     embedded brains GmbH
>     >     Herr Christian Mauderer
>     >     Dornierstr. 4
>     >     D-82178 Puchheim
>     >     Germany
>     >     email: christian.mauderer at embedded-brains.de
>     >     Phone: +49-89-18 94 741 - 18
>     >     Fax:   +49-89-18 94 741 - 08
>     >     PGP: Public key available on request.
>     >     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>     des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
