rtems-libbsd build error
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Apr 17 18:40:45 UTC 2019
On Tue, Apr 16, 2019 at 4:24 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Am 16.04.19 um 11:28 schrieb Vijay Kumar Banerjee:
> > On Fri, Apr 12, 2019 at 9:16 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > Am 12.04.19 um 16:26 schrieb Vijay Kumar Banerjee:
> > > On Wed, Apr 10, 2019 at 12:50 PM Christian Mauderer
> > > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>
> > <mailto:christian.mauderer at embedded-brains.de>>> wrote:
> > > Am 09.04.19 um 18:12 schrieb Vijay Kumar Banerjee:
> > > > Hi,
> > > > I have imported and ported the the drivers in 2 pairs(import
> > and port)
> > > > of commits
> > > > for each one. Please have a look at this branch
> > > > https://github.com/thelunatic/rtems-libbsd/commits/tda19988
> > > One detail: You have a commit named "tda19988.c: import from
> > FreeBSD".
> > > Please remove the ".c".
> > > Noted.
> > > Maybe it would be a good idea to split of the I2C part and put
> > it in
> > > front of the other two parts. You can develop and test that
> > independent
> > > with a test that just accesses some of the I2C devices on the
> > board via
> > > the FreeBSD API and the translation driver discussed below.
> > > This is a good idea, I'll import iicbus separately and add the
> other
> > > two on top of it.
> > > > I have also tried running the media01.exe and have seen it
> > running
> > > fine
> > > > without
> > > > throwing any exceptions.
> > > > I have used the fb.c and iicbus.c codes from the
> > freebsd source. From
> > > > what I
> > > > understand, I think the next big steps would be to write an
> > RTEMS
> > > > implementation layer for these portions of the code? And
> then a
> > > test in the
> > > > libbsd, like media01, to write to the /dev/fb0
> > > > Can you please help me chalk out a rough outline of the next
> > set of
> > > > actions? :)
> > > As far as I can tell, there are two possible I2C buses here:
> > > 1. The one between the AM335x and the TDA19988.
> > > 2. The one directly on the HDMI connector (called HDMI_DSCL and
> > > HDMI_DSDA). I assume that's an I2C bus too.
> > > For 1. the RTEMS driver should be used. You'll need some code
> that
> > > translates the FreeBSD API to the one used in RTEMS. Basically
> > that will
> > > just be a FreeBSD-I2C-driver.
> > > For 2: If that even is an independent I2C bus, you can use the
> > driver
> > > provided by FreeBSD. I don't think that it is necessary to
> > translate to
> > > the RTEMS API here.
> > > I had a look at the iic and iicbus codes in freebsd and the
> bbb-i2c.c
> > > This looks very confusing to me. Are we looking for something like
> a
> > > rtems-iicbus.c in the rtemsbsd that works like a wrapper to the
> > bbb-i2c
> > > code, and uses the freebsd api of DEVMETHODs?
> > Yes correct. Basically it would be necessary to have a I2C device
> driver
> > for FreeBSD that translates to the RTEMS API.
> > > I've not been able to figure out at one look, how to relate them
> and
> > > get a wrapper like that. Any suggestions on how to approach this?
> > I haven't had a look at the FreeBSD drivers yet. The first part that
> I
> > would have a look at is the description of the user facing FreeBSD
> API:
> https://www.freebsd.org/cgi/man.cgi?query=iic&apropos=0&sektion=0&manpath=FreeBSD+12.0-RELEASE+and+Ports&arch=default&format=html
> > Nice thing: They use a struct iic_msg that is compatible with Linux's
> > struct i2c_msg (according to the man page). We are Linux compatible
> too.
> > Can be a big advantage.
> > Then take a look at the simplest i2c driver that you can find in
> FreeBSD
> > that uses the transfer API.
> > freebsd-org/sys/dev/drm2/radeon/atombios_i2c.c looks good to me.
> > Basically you have to implement the following functions (replace
> > radeon_atom... by a useful prefix):
> > static device_method_t radeon_atom_hw_i2c_methods[] = {
> > DEVMETHOD(device_probe, radeon_atom_hw_i2c_probe),
> > DEVMETHOD(device_attach, radeon_atom_hw_i2c_attach),
> > DEVMETHOD(device_detach, radeon_atom_hw_i2c_detach),
> > DEVMETHOD(iicbus_reset, radeon_atom_hw_i2c_reset),
> > DEVMETHOD(iicbus_transfer, radeon_atom_hw_i2c_xfer),
> > DEVMETHOD_END
> > The iicbus_transfer function seems to get a struct iic_msg as a
> > parameter. Now that's really lucky.
> > With that you should be able to open the i2c device in RTEMS and just
> > pass the structure via the correct ioctl call to the RTEMS driver.
> > Basically you just have to pass the bus to use as a parameter to the
> > driver. Take a look at some of the other drivers in nexus-devices.h
> that
> > have for example an address as a parameter to see how you can do
> that.
> > This gave a good idea of the objective. :)
> > I had a look at the bbb-i2c.c code and how it's registering
> > and setting up the i2c_bus struct with the transfer, set and destroy
> > fucntions.
> > I have a question from the fundamentals, the only function
> > of bbb-i2c.c
> > <https://git.rtems.org/rtems/tree/bsps/arm/beagle/i2c/bbb-i2c.c#n414>
> > that is 'accessible' with the header file is am335x_i2c_bus_register
> > which basically sets the i2c_bus struct
> > and calls the i2c_bus_register function from the dev/i2c.c .
> > To use the DEVMETHOD api, we need to be able to call the
> > transfer, destroy etc. functions of the bbb-i2c.c from the translation
> > layer in rtemsbsd. How do I #include the bbb-i2c.c in the new
> > translation driver that I'll write?
> > Hope my question is stated clearly, please correct me if I'm getting
> > some fundamentals wrong.
> You are not fundamentally wrong but slightly off:
> Regarding the question how you access transfer, destroy, ... of the
> driver directly: Don't.
> You basically don't need to have a look at the bbb-i2c.c file of RTEMS
> for that driver. Where you should have a look is the Linux I2C API
> (which has been the model for the RTEMS API).
> Basically your drivers transfer function will do about the following:
> - Open "/dev/i2c0" (or some other path - that will be a parameter to the
> driver and has to be stored by probe or attach in some device structure).
> - Translate the "struct iic_msg" you get as an input to a "struct
> i2c_msg". Most likely that's just a cast.
> - Pass that via an ioctl call to the opened bus.
> - Check return value and translate to the matching return of FreeBSD.
> - Close "/dev/i2c0"
> Some of the open / close might could move to attach / detach. But that
> would be an optimization.
> That driver will work on any BSP that implements the current i2c API. So
> it's a generic translation layer.
> Best regards
> Christian
> Hi!
I started writing the driver layer implementation in the rtemsbsd, is this
going in the right
direction <
https://gist.github.com/thelunatic/2d8a2bf2cbead5bf82abe09000afea56> ?
> > > Can we not totally use the iicbus in the freebsd source?
> > We already have a I2C driver for that BSP in RTEMS. If you would use
> the
> > FreeBSD code, they would fight for the hardware. Of course it would
> be
> > possible to replace the RTEMS driver by a FreeBSD one. But that would
> > potentially break some applications. Besides that I think that a lot
> of
> > RTEMS BSPs already have an I2C driver so a generic wrapper could be
> > helpful for other BSPs too.
> > > > Thanks
> > > > On Tue, Apr 9, 2019 at 5:28 AM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>
> > > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>
> > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>>> wrote:
> > > > On 8/4/19 12:30 am, Vijay Kumar Banerjee wrote:
> > > > > On Sun, Apr 7, 2019 at 6:24 PM Christian Mauderer
> > > > <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
> > > > > Am 07.04.19 um 14:50 schrieb Vijay Kumar Banerjee:
> > > > > > On Sun, Apr 7, 2019 at 6:08 PM Christian Mauderer
> > <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
> > > > > > Am 07.04.19 um 14:35 schrieb Vijay Kumar
> > Banerjee:
> > > > > > > On Sun, Apr 7, 2019 at 5:37 PM Christian
> > Mauderer
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>>> wrote:
> > > > > > > Am 07.04.19 um 13:08 schrieb Vijay
> Kumar
> > > Banerjee:
> > > > > I don't think that there are a lot of docs for how
> > to test.
> > > > Although I'm
> > > > > sure that there are some scripts to run a number
> > of libbsd
> > > > tests, I'm
> > > > > not sure where. Maybe in the RTEMS tester but I
> think
> > > that is
> > > > mainly for
> > > > > the core tests?
> > > > The documentation for testing can be found here ...
> > https://docs.rtems.org/branches/master/user/testing/index.html
> > > > > so far I know, RTEMS Tester is only for core tests.
> > > > The `rtems-test` command checks the for test start and
> end
> > > banners.
> > > > I am not
> > > > sure if libbsd supports the test banners. Maybe it could
> > now with
> > > > Sebastian's
> > > > movement of the test support code into libtest.
> > > > > I'll ask in the devel if there's some way to run
> > libbsd test
> > > with
> > > > the tester.
> > > > There is the `rtems-run` command which has similar args
> to
> > > > `rtems-test`. It does
> > > > suffer from a limitation I have not fixed which is stdin
> > is not
> > > > passed through
> > > > to the console of the target. I also think the command
> has a
> > > timeout
> > > > running,
> > > > but I am not sure about this one.
> > > > Chris
> > > embedded brains GmbH
> > > Herr Christian Mauderer
> > > Dornierstr. 4
> > > D-82178 Puchheim
> > > Germany
> > > email: christian.mauderer at embedded-brains.de
> > > Phone: +49-89-18 94 741 - 18
> > > Fax: +49-89-18 94 741 - 08
> > > PGP: Public key available on request.
> > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
> > des EHUG.
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190418/32e21303/attachment-0001.html>
