I2C adaption layer driver for libbsd (was: Re: rtems-libbsd build error)
Christian Mauderer list at c-mauderer.de
Wed Apr 17 19:09:48 UTC 2019
First: Please note that I changed the toppic. The old one just didn't
represent the content any more.
Am 17.04.19 um 20:40 schrieb Vijay Kumar Banerjee:
>     >     >     Am 09.04.19 um 18:12 schrieb Vijay Kumar Banerjee:
>     >     >     > Hi,
>     >     >     > I have imported and ported the the drivers in 2
>     pairs(import
>     >     and port)
>     >     >     > of commits
>     >     >     > for each one. Please have a look at this branch
>     https://github.com/thelunatic/rtems-libbsd/commits/tda19988
>     >     >     One detail: You have a commit named "tda19988.c: import from
>     >     FreeBSD".
>     >     >     Please remove the ".c".
>     >     > Noted.
>     >     >     Maybe it would be a good idea to split of the I2C part
>     and put
>     >     it in
>     >     >     front of the other two parts. You can develop and test that
>     >     independent
>     >     >     with a test that just accesses some of the I2C devices
>     on the
>     >     board via
>     >     >     the FreeBSD API and the translation driver discussed below.
>     >     > This is a good idea, I'll import iicbus separately and add
>     the other
>     >     > two on top of it.
>     >     >     > I have also tried running the media01.exe and have seen it
>     >     running
>     >     >     fine
>     >     >     > without
>     >     >     > throwing any exceptions.
>     >     >     > I have used the fb.c and iicbus.c codes from the
>     >     freebsd source. From
>     >     >     > what I
>     >     >     > understand, I think the next big steps would be to
>     write an
>     >     RTEMS
>     >     >     > implementation layer for these portions of the code?
>     And then a
>     >     >     test in the
>     >     >     > libbsd, like media01, to write to the /dev/fb0
>     >     >     > Can you please help me chalk out a rough outline of
>     the next
>     >     set of
>     >     >     > actions? :)
>     >     >     As far as I can tell, there are two possible I2C buses here:
>     >     >     1. The one between the AM335x and the TDA19988.
>     >     >     2. The one directly on the HDMI connector (called
>     HDMI_DSCL and
>     >     >     HDMI_DSDA). I assume that's an I2C bus too.
>     >     >     For 1. the RTEMS driver should be used. You'll need some
>     code that
>     >     >     translates the FreeBSD API to the one used in RTEMS.
>     Basically
>     >     that will
>     >     >     just be a FreeBSD-I2C-driver.
>     >     >     For 2: If that even is an independent I2C bus, you can
>     use the
>     >     driver
>     >     >     provided by FreeBSD. I don't think that it is necessary to
>     >     translate to
>     >     >     the RTEMS API here.
>     >     > I had a look at the iic and iicbus codes in freebsd and the
>     bbb-i2c.c
>     >     > This looks very confusing to me. Are we looking for
>     something like a
>     >     > rtems-iicbus.c in the rtemsbsd that works like a wrapper to the
>     >     bbb-i2c
>     >     > code, and uses the freebsd api of DEVMETHODs?
>     >     Yes correct. Basically it would be necessary to have a I2C
>     device driver
>     >     for FreeBSD that translates to the RTEMS API.
>     >     > I've not been able to figure out at one look, how to relate
>     them and
>     >     > get a wrapper like that. Any suggestions on how to approach
>     this?
>     >     I haven't had a look at the FreeBSD drivers yet. The first
>     part that I
>     >     would have a look at is the description of the user facing
>     FreeBSD API:
>      https://www.freebsd.org/cgi/man.cgi?query=iic&apropos=0&sektion=0&manpath=FreeBSD+12.0-RELEASE+and+Ports&arch=default&format=html
>     >     Nice thing: They use a struct iic_msg that is compatible with
>     Linux's
>     >     struct i2c_msg (according to the man page). We are Linux
>     compatible too.
>     >     Can be a big advantage.
>     >     Then take a look at the simplest i2c driver that you can find
>     in FreeBSD
>     >     that uses the transfer API.
>     >     freebsd-org/sys/dev/drm2/radeon/atombios_i2c.c looks good to me.
>     >     Basically you have to implement the following functions (replace
>     >     radeon_atom... by a useful prefix):
>     >     static device_method_t radeon_atom_hw_i2c_methods[] = {
>     >             DEVMETHOD(device_probe,         radeon_atom_hw_i2c_probe),
>     >             DEVMETHOD(device_attach,
>     radeon_atom_hw_i2c_attach),
>     >             DEVMETHOD(device_detach,
>     radeon_atom_hw_i2c_detach),
>     >             DEVMETHOD(iicbus_reset,         radeon_atom_hw_i2c_reset),
>     >             DEVMETHOD(iicbus_transfer,      radeon_atom_hw_i2c_xfer),
>     >             DEVMETHOD_END
>     >     The iicbus_transfer function seems to get a struct iic_msg as a
>     >     parameter. Now that's really lucky.
>     >     With that you should be able to open the i2c device in RTEMS
>     and just
>     >     pass the structure via the correct ioctl call to the RTEMS driver.
>     >     Basically you just have to pass the bus to use as a parameter
>     to the
>     >     driver. Take a look at some of the other drivers in
>     nexus-devices.h that
>     >     have for example an address as a parameter to see how you can
>     do that.
>     > This gave a good idea of the objective. :)
>     > I had a look at the  bbb-i2c.c code and how it's registering
>     > and setting up the i2c_bus struct with the transfer, set and destroy
>     > fucntions.
>     > I have a question from the fundamentals, the only function
>     > of bbb-i2c.c
>     > <https://git.rtems.org/rtems/tree/bsps/arm/beagle/i2c/bbb-i2c.c#n414>
>     > that is 'accessible' with the header file is am335x_i2c_bus_register
>     > which basically sets the i2c_bus struct
>     > and calls the i2c_bus_register function from the dev/i2c.c .
>     > To use the DEVMETHOD api, we need to be able to call the
>     > transfer, destroy etc. functions of the bbb-i2c.c from the translation
>     > layer in rtemsbsd. How do I #include the bbb-i2c.c in the new
>     > translation driver that I'll write?
>     > Hope my question is stated clearly, please correct me if I'm getting
>     > some fundamentals wrong.
>     You are not fundamentally wrong but slightly off:
>     Regarding the question how you access transfer, destroy, ... of the
>     driver directly: Don't.
>     You basically don't need to have a look at the bbb-i2c.c file of RTEMS
>     for that driver. Where you should have a look is the Linux I2C API
>     (which has been the model for the RTEMS API).
>     Basically your drivers transfer function will do about the following:
>     - Open "/dev/i2c0" (or some other path - that will be a parameter to the
>     driver and has to be stored by probe or attach in some device
>     structure).
>     - Translate the "struct iic_msg" you get as an input to a "struct
>     i2c_msg". Most likely that's just a cast.
>     - Pass that via an ioctl call to the opened bus.
>     - Check return value and translate to the matching return of FreeBSD.
>     - Close "/dev/i2c0"
>     Some of the open / close might could move to attach / detach. But that
>     would be an optimization.
>     That driver will work on any BSP that implements the current i2c API. So
>     it's a generic translation layer.
>     Best regards
>     Christian
> Hi!
> I started writing the driver layer implementation in the rtemsbsd, is
> this going in the right
> direction
> <https://gist.github.com/thelunatic/2d8a2bf2cbead5bf82abe09000afea56> ?
Yes. That's the direction I had in mind.
Regarding that part:
    //XXX: Open /dev/iic0
    strcpy(addr, "/dev/");
    strcat(addr, device_get_nameunit(dev));
Sooner or later that should be received via a parameter. I just had a
look at nexus-devices.h: It seems that there is currently only support
for two kinds of "parameters": memory resources and interrupts.
What would be necessary would be more of a string parameter like they
are available via the device tree interface. This kind of parameters is
normally retrieved in the driver with the OF_getprop_alloc() function.
Problem is: The driver you currently write isn't one that is normally
put into a device tree file. So some other source for the string
parameter is necessary. I'll have to have a more detailed look at how
the parameter could get into the driver in the next few days.
I would suggest to start with a fixed string for now. Assume that it
will somehow appear in the attach function (that would be the location
where such parameters would be parsed most of the time).
>     >     > Can we not totally use the iicbus in the freebsd source?
>     >     We already have a I2C driver for that BSP in RTEMS. If you
>     would use the
>     >     FreeBSD code, they would fight for the hardware. Of course it
>     would be
>     >     possible to replace the RTEMS driver by a FreeBSD one. But
>     that would
>     >     potentially break some applications. Besides that I think that
>     a lot of
>     >     RTEMS BSPs already have an I2C driver so a generic wrapper
>     could be
>     >     helpful for other BSPs too.
>     >     >     > Thanks
